Question about HP Jornada 568 Pocket PC
Jornada 568 Sync Problems
Two days ago, my Jornada 568 stopped syncronizing with my pavilion 9871 PC. I use Active Sync 3.5 Build 12007, and Windows XP. I didnt have any problems and two days ago, when I put the Jornada in the Cradle, I got an error message saying USB Device Not Recognized. Since then I've followed every instruction on HP and Microsoft web site, including reinstalling XP from scratch, with no luck.
    Master:
  • 450 Answers
All you have to do: Select Device Manager, select "Universal Serial Bus controlled". Re-install the USB driver from Active-Sync CD. That's it.
Posted on Sep 12, 2005
SOURCE:
Replaced " Jornada" to " iPAQ" - How to keep/recovery all datas
So if you sync your old one to OUTLOOK on your PC, I would simply install the new Activesync and create a new partnership for your Ipaq and the data should be transferred.
Sep 14, 2005 | HP iPAQ RX3715 Pocket PC
How to activate daylight saving mode on Jornada 568?
The PDA toy, 17 years old now, who uses something this old?
in what country, DLS varies by country and state
and the rules changed here, in 2005. (wiki it)
it's winter here, in USA< so.. you are on other half of earth. (lower)
most computers made for 42 years, , ALL use a RTC chip
same chip as in a wrist watch( close to same, very close)
this chip does all that magic even to the level of a
perpetual calendar ! wiki that.?
so the BIOS can set (all real PCs) all that and the OS too.
when you change the OS time and date it then goes to the
BIOS RTC page and changes it there so they are in sync.
they Sync, up,
I do not know where Any OS stores time, after all it be different in all 100's of OS made, and your old relic PDA , gawd knows.
your manual for Jornada
tells you on PAGE 13, when you reset the Jornada, or or run it the first time, it asks for time city and time zone.
what makes you think this toy device even does daylight saving time, (it have to do every city on earth to do that , no easy thing)
on a real computer here, we can set our clock to WWV time.
via the WWV or WWVH, radio site, here, "atomic time"
then it sets you per the daylight savings (bit set selection)
That is how it works best on a real PC. or notebook.
maybe your Toy PDA is set this way (page 101)
Using ActiveSync, you can synchronize information in Microsoft Outlook
or Microsoft Exchange on your desktop PC with information in Pocket
Outlook on your hp Jornada."
but wait MS shut all that down long ago......
I googled for you and found very little on the RTC functions of you PDA. (but it is too old now, really)
the manual only has very little on topic, (so is limited in features)
http://www.hp.com/ctg/Manual/bpia2371.pdf
my guess is you are looking for something that DOES NOT EXIST.
seem so, no? not in the official book
HP forum zero hits.
google zero hits.
last Jornada sold on ebay for $5 ,gets you 7 of them,
71cents (USD) each, less than 1 PEACH, here
they are not considered here, just trash.
Dec 14, 2017 | HP Jornada 568 Pocket PC
Sync problem w/outlook contact
I use my 548 to keep my work and home versions of Outlook syncronised. I have about 70 contacts stored. Three suggestions.. 1) Do you have enough free memory? Emails can take up megabytes, and for that reason I choose not to sync emails. 2) Are all of your contacts in the same Contacts folder? I have two contacts folders on my home Outlook, one for me and one for my wife, I only sync my contacts to my 548. 3) In Activesync, click on Options, Sync options, contacts, settings and make sure that "Syncronize all contacts" is checked
Sep 12, 2005 | HP Jornada 548 Pocket PC
Can't synch, only connects as guest
I have had this happen to me at work. You need to backup your Jornada on the computer that works to sync (VERY IMPORTANT) and then hard reset the Jornada (which wipes it clean). Make sure that you put the name back into the Jornada identification (it will be wiped out by the hard reset). Then try to synch on the computer that can't synch except as Guest now. It should sync fine. Then you will need to sync on the computer that works to sync to restore the backup file. Then you will be back to normal. It is a pain. I don't know why it happens but I know this solution worked for me. Let us know if it works for you.
Sep 12, 2005 | HP Jornada 568 Pocket PC
Active sync and Outlook xp
Maybe i should help, because i was solving similar problem with C-Series handheld from Compaq, which is almost the same. I am using Active sync 3.0 as the newer versions didnt work properly and i got no problem...
Deleted Items Sync
did u empty ur deleted items folder in outlook if u did to stop it from syncing the e-mails open up active sync and go to tools options and then uncheck the e-mail
Sep 12, 2005 | HP Jornada 565 Pocket PC
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
Operating system upgrade?
The Jornada 568 has its OS in masked ROM. There is not an upgrade available.
How to open my Jornada 568?
RTM
read the manual.
why not learn to use google, and search for your service manual
hint, its not at HP support ended what 7years ago.
its 16 years old now. why fool with something this old.?
if it works leave it be... no parts now. from HP, only used parts.
many used part are bad.
leaving one thing, google search,
The HP books exit on the web, (not HP)
here is a close match, btw, first google hit,, shock !
http://www.manualsdir.com/manuals/96365/hp-jornada-520.html?page=2
Feb 22, 2018 | HP Jornada 568 Pocket PC
HP Jornada 568 Pocket PC Logo
138 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
