Question about HP LaserJet 1020 Printer
Printing issues Hello, Can you please help me. When printing I have a vertical empty line down the middle of the page where there is no print. The vertical empty line is the same width as a letter when using times roman font size 12. I have tried cleaning the printer, changed the toner and check if there is any fluff, dust etc and do not know what else I can do. Please, Please help Many thanks Kelly Harris Three Counties Law LLP
  • 26 Answers
Hi
it seems that cleaninig is required to the printing roller. it would be slight difficult to open it and clean for you.
you should get it serviced by some professional.
Posted on Sep 01, 2008
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
Savin 9935DPE is printing one thick vertical balck line down the copy or print pages. About 2 of every 3 pages printed. What's wrong?
are you printing from Doc feeder or glas?? if from feeder then try to make a copy from the glass, does it still do it? yes problem is with drum.
No? problem is with the small scanning glass to the left, look carefully see if any spots or lines on the 1inch glas --- clean it
Sep 05, 2012 | Savin 9945dpe 9935dpe 2035dpe 2045dpe...
Hp Laser Jet P2055dn printing black line down the middle
The line in the middle of the page is caused by a damaged or worn fusing assembly in the printer. Here is a link to an article showing this issue on the Laserjet 2100 printer and how to replace the fuser unit. Your printer just needs to have the fuser replaced, it is part number RM1-6405 and is available from Amazon
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Jul 19, 2012 | Ricoh Aficio CL3500N Laser Printer
Unwanted line down centre of page
you need to reassemble image unit and clean completely
if you dont know how to do just bring it your printer to technicians
Jan 06, 2010 | Samsung CLP-510 Laser Printer
Hi, I have a Brother 7820N and every time we print, we get a vertical smudge down the middle of the page. The machine is printing, but this awful "smear" lined each page printed. Any assistance is...
I would try a new print cartridge. There should be a cartridge cleaner built into the machine settings. Also the ink reservoir might need to be cleaned.
Jul 31, 2009 | Brother MFC-7820N Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Hp 2420 vrtical line in page
This issue can be due to fuser. I am sure you have changed the toner cartridge.
To confirm its a fuser issue, please perform the following:
1. Try printing a configuration page from tray 1, pull the top cover, as soon as the media is 60-70% inside the printer.
This would stop the paper before reaching the fusing assy.
2. Remove the paper and check if the line exist.
If exists, fuser is not faulty.
If it does not, then transfer roller, laser/scanner assy is faulty
- If fuser is faulty, perform the cleaning page as following
1. go to configure device > print quality > create/process cleaning page
perform cleaning page 5-6 times, however, if the line is due to fuser, then fuser needs to be changed.
Let me know the next update.
- Nikhil
Nov 21, 2008 | HP LaserJet 2420 Printer
Problem with printing smoothly
Hi morshi. I found a potential solution to your problem with your 5610 printing vertical lines at HP.com:
Vertical black lines or streaks
It's hard to tell from the rest of your message what other problems you're describing. I did find a troubleshooting page at HP that shows how to address general print quality problems:
Problem with quality of copies
If those links don't solve all of your problems, the Color printing issues page for the 5610 at HP has numerous other solutions:
I know the name of that last link may seem misleading since you haven't described color printing issues, but the links on that page offer different general print problems and their solutions.
Good luck.
Sep 30, 2008 | HP Officejet 5610 All-In-One InkJet...
SAMSUNG SCX 4100 PRINTING PROBLEM
I am facing the same issue, but its related to Copy (not Print).
The carriage/CCD Light in the scanner is stuck in its original position, causing a scanner error, and all I get are 3/2 vertical lines on the page. Some time I also get an empty page out.
Jan 29, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Vetical lines printing on page
If the lines are blue, check the color PCU.
Oct 25, 2007 | Ricoh Aficio CL3500N Laser Printer
HP LaserJet 1020 Printer Logo
107 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
