Question about Nokia N73 Cellular Phone
N73 in water
I dropped my phone in water for like 1 sec. i have took out my sim car, battery and memory card. the screen on my phone has water droplets. I have been tryin 2 take my phone cover off but dont know how to. What should i do?
  • bev90 Sep 01, 2008
    Where are the locks in the cover?
    i ve tried usin a narrow screwdriver at the bottom of the fone but it doesnt lift the rest of the cover.
Go to youtube and search how to open the fone from their it will give you full details and instuctions!!!
Posted on Oct 20, 2008
  • 26 Answers
Hi
there are some locks in the cover. try to remove the cover with your nail. dont put in the battery untill you are sure that your phone is free of water and moisture contents.
Posted on Sep 01, 2008
  • Rehman Ahmed
    Rehman Ahmed Sep 01, 2008
    hello dear
    below is the proceedure i found some time ago and also performed successfully. you need two cards like credit cards and a screw driver. be carefull.
    1- Take front faceplate off by inserting card 1 between housing and silver key. As you pull up, take card 2 and slide it on the side of the phone prying the clips off.
    2- Unscrew these 6 screws at the edges with the T6 screwdriver and release the 4 clips surrounding the LCD screen.
    3- Slip the little black frame off of the LCD screen, and lift the screen. You should now see a screw. Removing this screw removes the back cover.
    4- That’s it! Put your new faceplate or housing in and figure out how to put things back by following the directions here in reverse order.
    gudluck
My samsung Im pression touch screen is not always working....is there a quick fix for this(ie. battery) or will i need to send it for repair....if it needs repair, what is the cost range?
try to do these steps, and bring your phone back to it's factory settings. make sure to remove your sim and memory card. please take a note that if your phone is under warranty, you may choose not to follow this, hence bring your phone to your nearless service center.
to make a hard reset...
1. switch off your phone
2. remove your battery
3. remove sim and memory card
4. reinsert battery and switch your phone on
5. while your touchscreen is working, type the code
*2767*3855# to set it back to its factory settings.
6. after a successful hard reset, remove battery and reinsert sim and memory card, reinsert battery and switch on and check.
7. play with your phone by doing reconfiguring it to your settings and check.
Feb 25, 2010 | Samsung SGH-A877 Impression Cell Phone
I dropped my cell phone in the water
http://www.fixya.com/support/r3771170-phone_water_damage
Oct 08, 2009 | Motorola Mobility RAZR V3
I ALSO HAVE THE SAME
Hi Friend,
Please follow the below steps,
1.Switch off the mobile.
2.Remove the battery,sim card and the Memory card
3..Hold the Switch ON button for 20 secs
4.Replace the Battery and the Sim card after 20 secs,
5.Now switch ON the mobile .
6. after it has ON check it wither its working then replace the memory card
Regards,
Ayyasam
Aug 27, 2009 | Nokia 6030 Cellular Phone
My nokia was working fine then its screen went blank and now it is doing nothing....totally dead...help
Hi Friend,
Please find the below mentioned steps and kindly follow the steps,
2.Remove the sim card,battery and memory card.
3.Hold the switch on button for 20 to 30 secs,
4.After that replace the sim card and the battery.
5.Now switch on the mobile,
6.After it has switched on now replace the memory card.
Regards,
Ayyasam
Aug 26, 2009 | Nokia N95 Cellular Phone
The phone turns on then the screen goes white
Hi Friend,
The problem may be because any software my got hanged or any virus may create this problem so kindly check it out.
Or you may try the below steps,
2.Remove the battery,sim card and the memory card
3.Hold the Switch ON/OFF button for 20 to 30 sec's
4.Now Replace the battery and the Sim card
5.After it has Switched ON,replace the Memory Card.
Check and revert back
Thanks and revert back
Regards,
Ayyasam
Jul 31, 2009 | Nokia 6500 Slide Cellular Phone
Wet cell phone-blank screen
Well it depends on the type of screen you have in the phone. Some have edges that can split open and lose the fluid that projects the picture so your best bet is to just replace the phones screen, if every thing else works fine
May 31, 2009 | Cell Phones
Maybe rzr v3m; black screen after dropping phonein water
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Apr 29, 2009 | Motorola Mobility RAZR V3x Cellular Phone
LG PHONE STUCK ON EMERGENCY DOWNLOAD
I had the same problem!! This might help: 1. Take out the battery, SIM card, and memory card (if applicable). 2. Let the phone sit in the sun for a couple of days. 3. Put the SIM card back in the phone and plug the phone charger into the phone. 4. When prompted, insert the battery into the phone 5. When battery is fully charged, remove the charger and depress the call button simultaneously.
I tired this and the phone is now working!!! Also, I do not seem to have lost any of the features!
Good Luck!!!
Jan 27, 2009 | LG Vu CU920 Cellular Phone
W810i took a bath!!!!!!
is should have hardware damage since it has been expose to water. you have to send it to service center to get it fix.
Jul 22, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Nokia N73 Cellular Phone Logo
49 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
