Print cartridge missing or not detected the cartridge is installed it has just been replaced
  • Megan13 Mar 21, 2009
    My HP Photosmart C4280 is cheap but perfectly adequate. I haven't over-used or abused it.It has reasonably new ink in it and not the cheap stuff.   I did a few letters and 2 colour photos 2 days ago and before I could continue I got the message, "Print Cartridges missing or not detected."
    1)  I checked that the ink cartridges had not come loose.
    2) I checked the wires.
    3) I re installed the printer ..  .....  no joy.
    Genius:
  • 2,120 Answers
Genuine HP cartridge?
Posted on Sep 01, 2008
Lexmark 352dn 31 missing or defective cart
The 31 error message means that the printer is detecting the toner cartridge is either faulty or not installed properly. You might need to replace your toner cartridge.
Nov 12, 2012 | Lexmark E352dn Laser Printer
I get the message that the print cartridge is missing or not detected. Have tried taking cartridges out and putting them back in, replacing with new cartridges
What you could try is to remove both ink cartridges and close cover.
Turrn off printer and unplug from electrical outlet.
Wait at least 15 minutes for printer to reset.
Plug back in printer, turn on and wait until printer stop .
Install both ink cartridges.
Jan 11, 2011 | HP Photosmart C4180 All-In-One InkJet...
I have installed colour cartridge 351XL and black 350 cartridge but my printer still says Print cartridges missing or not detected
Have you removed the shipping tape from the print cartridge? It covers the print head on the cartridge to protect them so they won't leak ink.
Nov 01, 2010 | HP Photosmart C4280 Aio Printer
Print cartridges missing or not detected message
I tried to solve this problem but still persist
Mar 22, 2010 | HP Photosmart C4280 Aio Printer
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Printer won't print-says color cartridge is missing and it is there
Just a shot in the dark, was it a refilled ink cartridge. I know HP has a problem detecting the remanufactured cartridges from time to time. And too, if it is not refilled cartridge perhaps you just have a bad cartridge.
Oh, of course Julie remembered to pull the tape off of the bottom of the ink cartridge, correct?
Hope this did some good, please leave rating,
thank you kindly.
Apr 27, 2009 | Lexmark X2470 All-In-One InkJet Printer
Keep getting message "Print cartridge(s) missing or not detected"
If these are new cartridges then you can try wiping the contacts and the pins with a dry paper towel then re install them. do not us tissue as some of them have lotion on them. If these are remanufactured cartridges return them for an exchange.
Mar 21, 2009 | HP PhotoSmart C4280 Laser Printer
Printer 4355show in message
may i know if the INK that you are using is a HP genuine ink cartridge??if it does clean the copper contacts on the printer and try to check also if the ink cartridge that you are trying to insert is the compatible ink cartrdiges of the PRINTER
Sep 03, 2008 | HP Officejet 4355 All-In-One InkJet...
Can't install lexmark x4530...get spooler subsystem app has encountered a problem,etc.
Print Cartridge(s) Missing
The following print cartridges appear to be missing, not detected, or incorrectly installed:
Cartridge on Right
Cartridge on Left
May 21, 2008 | Office Equipment & Supplies
Light is flashing
check cartridge compatibility first:- HP Deskjet 810c HP15................black cartridge compatibility HP 23 ....................colour cartridge compatibility Issue ---A print cartridge is missing. Solution Install the missing cartridge. Issue --The printer detects a faulty, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. 2. Make sure the correct print cartridges are installed. Click here to go to the printer/cartridge compatibility chart. 3. Replace or reinstall the print cartridges. 4. Close the top cover of the printer. Issue ---The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution Clean the contact points on the cartridges with a dry, lint-free cloth. 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth. NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Use a dry, lint-free cloth to remove the moisture from the contacts. 5. Insert the cartridges back into the printer. 6. Close the top cover. 7. Try printing again.
Sep 11, 2007 | HP DeskJet 810c InkJet Printer
75 people viewed this question
jasbo
jasbo
