Question about Sony DSC-T7 Digital Camera
DSC-T7 Magnify Mode
Question for anyone with a T7. RE: the magnify mode. Is this mode similar to the macro function in that it only allows focus from 1cm to 20cm (13/32 inch to 7 7/8 inches)? I thought it was intended to blow the image up on the screen when using manual focus. Am I missing something here? -- Marvin
    Master:
  • 551 Answers
Hello, Don't mix magnifier mode and expanded focus mode. Magnifier mode is simply a short AF range operating mode, like a kinda super-macro. Whether you selected mag/macro/normal, the camera operates always same except that the focussing range limits are changed accordingly by the S/W. The lens itself is capable of focussing from 1cm to infinity anyway. Expanded focus is used on some still and video cameras to assit manual focus because the LCD's resolution is lower than the CCD's. It can be seen as a workaround for the lack of optical reflex viewfinder (Sony cams ar not dSLRs, including HDR-FX1!). So the center area of the pic is "digitally zoomed" to make sure you can adjust a sharp focus of the point of interest in your frame. However it has nothing to do with macro shooting, and works at any distance within the lenses focussing range. Hope having helped
Posted on Sep 12, 2005
Macro function
The difference will be that it should allow you to focus closer then normal. I own a macro lens with a switch like that, normally it focuses to 4.5 ft minimum. But if i'm zoomed up to 100mm, i can flick the switch to allow me to focus up to 3 ft away.
Jun 03, 2012 | Sigma 70-300mm f/4-5.6 DG Lens
When zooming in for a close shot it will not focus
When using the tele, the closest you can be to a object is probably more that one meter. If you need to get closer you should switch to macro mode.
Oct 01, 2009 | Canon PowerShot SD850 IS Digital Camera
Macro mode and date imprint
In Macro mode, you have to hold the shutter release down halfway and hold it until the focusing system has time to work, then take picture.
Date/Time stamp on image only works in Postcard mode.
Jan 20, 2009 | Canon PowerShot A95 Digital Camera
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
How do you go from zoom to macro?
From my experience, many zoom lenses that have a macro feature simply kicks into macro mode when the lens is in fully zoomed position. Remember, macro is used to take pictures of something (usually like a flower, insect, etc.) and to magnify it several or many times larger than it really it is. And as a result the subject is huge and sharply focused with a very blurry background. Another thing to keep in mind is that there is usually a focusing limit for the lens in terms of how close one can focus a subject in MACRO zoom mode. In other words, you (the lens) may have to be at least a foot or more away from the subject in order to automatically focus sharply. On this note, if you have manual focusing capability, you should be able to take pictures in macro zoom mode from even shorter distance from the subject, resulting in more larger than life pictures!
I Can Fix it
Sep 03, 2008 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
Canon S5 IS. I am having problems with Macro shooting. As I look through view finder, object seems in focus, but when I press focus lock button (halfway) the image jumps out of focus.
Dear Stefan:
Barring a malfunction with your len's autofocusing mechanism, the problem that you're experiencing is likely due to the limitations of the camera's focusing / zoom range in Macro mode.
You didn't say what ranges you were shooting from but basically, in order to get proper focus, you must first make sure you're within the proper lens to subject distance for the macro mode that you've chosen.
There are two macro modeson the S5, Macro and Super Macro. Macro shooting is done only within the ranges of 3.9 inches to 1.6 feet from your subject. SuperMacro mode (which is entered into by simply pressing the Macro button for one second) will only focus within the ranges of 0 inches to 3.9 inches. So if you are in either of these modes and stray from their focusing ranges, your camera won't focus properly.
Another issue that you may be dealing with is the very limited zoom range in Macro/Super Macro Modes. The zoom is basically meant to be set toward the maximum wide angle end of the zoom range. There is a yellow indicator bar below the Zoom Bar in the viewfinder that indicates the Out-Of-Zoom range in which the zoom basically can't be used. As you may see, only the first 10% or so of the zoom range is useable.
It might be that you could possibly be wavering in and out of the two macro mode focusing ranges and/or zooming into the Out-Of-Range zone during your session. Either can cause a similar effect such as you are describing. It's hard to say without actually being there.
To test this out I would simply set my camera on a tripod or other stand at a known fixed distance from the subject, set the camera to the macro mode indicated by that distance (either MACRO or SUPERMACRO), zoom out to the widest focal length and take the shot to see if it is clear or not.
If so, your camera probably has no problem. If it is still not focusing properly you might want to send it into the service center for a diagnostic. There is no charge to diagnose a problem with your camera and if nothing is found to be wrong you will only be out of the shipping charges spent to send the camera in to the service center. If a repair is needed, it can be done at that time.
Hope this helps you.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon Cameras
Camera will only focus in macro mode
Check house not inadvertently set it to macro. If it has manual focusing try to reset the focus collar - check the manual for something you may have overlooked Failing all that look up the Fuji Tech Support team in the website
May 24, 2007 | Fuji FinePix S7000 Digital Camera
Canon Powershot S2 IS Super Macro mode
Make sure your camera isn't zoomed in (full telephoto) The camera can't handle both full zoom AND super macro. Don't forget super macro goes from Zero to 20cm from the lens. Zoom completely out and you should be able to see something within that range. The biggest complaint I've heard about the S2 IS is if you take closeups of bugs the chances of the bug crawling onto your lens is pretty good.:-) Be very carefull of blocking light with the lens at extreme closeup too. Although the flash squelches well to allow for closeups it can leave a nasty shadow. If you're really serious about macro you'll find a ring flash would come in handy. BMW
Jul 13, 2006 | Canon PowerShot S2 IS Digital Camera
H1 out of focus above 7xzoom?
HI, are you sure that there is no conversion lens setting activated in the setup menu? It sounds like that to me. These modes limit the ranges. I hope it will help, otherwise you will have to bring it back.
Sep 12, 2005 | Sony Cyber-Shot DSC-H1 Digital Camera
Sony DSC-T7 Digital Camera Logo
112 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
