I can speak from the flooring and finish work realm of fasteners and I must say once you go pneumatic, you will NEVER regret the transition. Not only is it more efficient, it is also very helpful on the intricate detail side of things. It eliminates the need for a third hand when dealing with tight spots as well. The only drawback to air is that winter conditions tend to take their toll on airlines and fasteners attached to them by causing them to run sluggish. Keep the air warm if you can and it helps.
For every nail that a normal human with a hammer could hand drive on his best day, a pneumatic nailer would drive and set twelve! That is no exaggeration. Although there is no need to go this fast, a reasonable speed would allow you to be 400 to 800 percent more productive. Nailing large subfloors and roof decks is a breeze. Hours worth of work becomes minutes.
All air tools need regular, sparing application of tool oil to maintain the seals and minimize moisture damage. With the tool disconnected from the air line, drip one or two drops of air tool oil -- NOT motor oil or any solvent -- into the air connector. Position the tool so the air connector is up, allowing the oil to run down into the tool.
I don't have that same model but my gun started doing something similar a while back. I was able to disassemble the head of the gun and found that the hammer or piston that drives the nail had rounded itself off and wasn't able to make good contact with the nail head. Instead it pushed itself on top of the nail and got wedged. It's nearly impossible to see the stuck nail or dulled piston head without taking it apart. Hopefully this will help.
Your gun uses 30 -34 degree
clip head paper tape. Order a sample of the nail below. It may work on your gun. These are offset full round head with paper tape. Safe way to test if nails will work is to remove the head of the gun and insert nails into rails. Push down on the driver with wood handle of hammer to eject nail. This will test for jamming or two nails trying to eject and cause jam. Look down barrel to see if the head is alighed correctly or too far from centerline of driver.
Try removing stuck nails without taking apart gun. Remove remaining nails from rails. Use long piece of allen wrench or similar hard steel and grind the end to allow for jamed nail (I use a broken driver blade ground slightly thinner to allow for stuck nail). Use heavy brass or copper hammer to push driver up to top of cylinder. If after a couple of heavy blows the driver does not move, remove the head of the gun and pull out the cylinder and place the body of the gun on plywood. This will protect the head from damage. Good luck
This electric nail gun does not have much power. Try shorter nails and softer wood. You need a pneumatic nail or staple gun for medium or heavy work. I have both a nailer and stapler and neither are very good.
Yes, because there is less risk of splitting the wood grain when using a nail gun than when using a hammer, nail guns are especially useful in delicate projects such as the application of indoor trimming. A nail gun sets the nail in one motion, reducing the chance of slips and bumps that can ruin delicate woods. Most models also include a rubber safety nose to protect the wood from friction.
