Question about Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit
Nail Gun support
Is it better to use a nail gun then a normal hammer for delicate work?
    President:
  • 2,712 Answers
Yes, because there is less risk of splitting the wood grain when using a nail gun than when using a hammer, nail guns are especially useful in delicate projects such as the application of indoor trimming. A nail gun sets the nail in one motion, reducing the chance of slips and bumps that can ruin delicate woods. Most models also include a rubber safety nose to protect the wood from friction.
Posted on Sep 01, 2008
Misfires new gun
If your using refills that have wire holding the nails together.
Check to see if bits of wire, debris is collecting in around the striking hammer. I switched to paper and never looked back. Must have gone through 5k worth of nails and rarely jams. Other things to check,
1. Check the striking hammer, make sure it is not bent or damaged.
2. Check air pressure, Low pressure can cause jamming, misfires.
3. If the tool needs pneumatic oil, 2-3 drops before you start good rule of thumb.
4. Check spring return. Sufficient pressure must be maintained or the nails will not feed properly. Misfires, incorrect feed, jamming etc.
I had a Hitachi brad nailer and it was horrible. Fire 1 brad nail would jam or misfire. Did everything I could think of nothing worked. Put it up, got a Rigid brad nailer and never looked at the Hitachi again. :)
Sometimes you just get a lemon! (PS I understand you have a framing nail gun. Brad nail gun above is used for an example)
Hope this helps
Mar 24, 2014 | Hitachi KNR90AE Round Head Framing Combo...
The nail gun will not shoot
I don't have that same model but my gun started doing something similar a while back. I was able to disassemble the head of the gun and found that the hammer or piston that drives the nail had rounded itself off and wasn't able to make good contact with the nail head. Instead it pushed itself on top of the nail and got wedged. It's nearly impossible to see the stuck nail or dulled piston head without taking it apart. Hopefully this will help.
Oct 18, 2012 | Arrow ET200 Electric Brad Nail Gun
How do you remove the front hub to remove the stuck nail
If a nail is stuck between the driver and nose of the gun, you will need to forcefully push the driver back into the gun. Remove the head and cylinder and place the body of the gun on piece of plywood with nose pointing up. Using very sturdy steel rod, hammer the driver down. The steel rod needs to be slightly thinner than the driver to allow for the stuck nail. I use a broken driver ground thinner on the side that will need to bypass the stuck nail. Careful when striking hard steel with hammer, could spinter (I use a heavy brass hammer). Good luck
Nov 01, 2011 | Stanley Bostitch F21PL Nailer
Problem: Nail jam due to improper degree of nails Question: How do I take apart the nail gun so as to get the jammed nails out?
Try removing stuck nails without taking apart gun. Remove remaining nails from rails. Use long piece of allen wrench or similar hard steel and grind the end to allow for jamed nail (I use a broken driver blade ground slightly thinner to allow for stuck nail). Use heavy brass or copper hammer to push driver up to top of cylinder. If after a couple of heavy blows the driver does not move, remove the head of the gun and pull out the cylinder and place the body of the gun on plywood. This will protect the head from damage. Good luck
Jul 13, 2011 | Stanley Bostitch Nail Gun
8 penny nails are stuck in gun. How do you get them out?
If the nails are stuck in the rails, remove the rails and fish them out. If a nail is stuck between the driver and nose of the gun, you will need to forcefully push the driver back into the gun. Remove the head and cylinder and place the body of the gun on piece of plywood with nose pointing up. Using very sturdy steel rod, hammer the driver down. The steel rod needs to be slightly thinner than the driver to allow for the stuck nail. I use a broken driver ground thinner on the side that will need to bypass the stuck nail. Careful when striking hard steel with hammer, could spinter (I use a heavy brass hammer). Good luck
May 03, 2010 | Dewalt D51844 Framing Nailer
Can i use any brand coil nailes in my nv 45ab2 coil nailer
Yes. Roofing nailers all use about the same size and spacing on coil nails. You will find that Harbor Freight is about 1/2 the price of Home Depot or Lowes for those nails.
-Jim
Oct 17, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Arrow ET200 nail gun only put nails in 1/8 of inch.
This electric nail gun does not have much power. Try shorter nails and softer wood. You need a pneumatic nail or staple gun for medium or heavy work. I have both a nailer and stapler and neither are very good.
Jul 23, 2009 | Arrow ET200 Electric Brad Nail Gun
Nail Gun question
For every nail that a normal human with a hammer could hand drive on his best day, a pneumatic nailer would drive and set twelve! That is no exaggeration. Although there is no need to go this fast, a reasonable speed would allow you to be 400 to 800 percent more productive. Nailing large subfloors and roof decks is a breeze. Hours worth of work becomes minutes.
Aug 27, 2008 | Irwin 12" Bar Clamp Multi Position Jaw
Nail Guns comparison
Aug 27, 2008 | Arrow Elec Brad Nail Gun Kit
Delicate problem
Aug 27, 2008 | Arrow No. ET100 Electric Heavy Duty Nail...
Dewalt Heavy Duty 2 Brad Nailer Compressor Combo Kit Logo
167 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
john h
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
