Question about Dishwashers
Diswasher wont turn back on after being moved - DW Omega 908
Diswasher wont turn back on after being moved - DW Omega 908, I have cheched power - OK, orange light on at front but not playing the dishwashing game.
Can someone help Please.
Regards
Damian
  • 706 Answers
Have you checked the door interlock switch to make sure it is not disabling the wash cycle?
Posted on Sep 01, 2008
Did not fully drain and will not turn back on
Might have blown fuse.
Check for obstructions in drain line -- the pumped line from pump under DW to drain. Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Nov 27, 2013 | KitchenAid Dishwashers
I have Frigidaire FDB956RBC1 diswasher. I have to turn off the water to fix the faucet. When I turned the water back on, water did not go to the diswasher when I used it. The diswasher runs normal except...
FRIDG... EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Frigidaire FDB956RB Built-in Dishwasher
Kenmore dishwasher will not fill with water model no 630.1609406. It will run a full cycle but not fill. Water was temp shut off to replace kitchen sink and now dishwasher won't fill with water. No fill...
First, are you sure that the machine is not filling?
I go on calls all the time for this problem and it turns out than the machine fills but the wash motor does not run.This leaves soap in the bottom of the DW so it looks like it did not fill with water. This is a common problem in dishwashers that have not been run for a few months, and is quite common after a remodel. If it IS getting water, the motor is probably stuck. If it is Not getting water the first step is to locate the "over fill" float inside the dishwasher. This will be a round sort of mushroom looking thing on the floor of the machine near the door on the right or left. Make sure it moves freely up and down. It will only move about 1/4 inch but If it is stuck up, the machine will not fill. If float is O.K. then check the water source. Turn of water to DW. Remove the kickplate under DW door and disconnect the waterline from fill valve (should be on front left side of unit). Run waterline into bucket then turn on the water. If you don't get water call your plumber. If you get water then you need to check the fill valve. Connect a volt meter to the 2 wires on the fill valve. Start DW. First the diswasher should start draining, then it will start filling. At this point (a few minutes into the cycle) you should see 120v AC at the fill valve. If you do see 120v Ac, replace the valve. If you don't , then turn off the machine and check the float switch. This is located under the DW right under the mushroom thingy. The switch should have continuity when the DW is empty. If there is no continuity then replace the switch.
Mar 29, 2010 | Dishwashers
Zanussi DW 908 door mechanism is faulty. The counter balance has failed. How can this be resolved?
You need to remove both side panels to allow you to gain access to door counterbalance springs. Visually see what is broken or come off of allignment then rectify.
Sep 17, 2009 | Dishwashers
Diswasher kitchenaid KUDI01ILBL6 press start, nothing happens
sounds like either a control board issue or a keypad issue.. if you turn he power off and turn it back on and it works for a min then the fuse is fine..
Sep 02, 2009 | KitchenAid Dishwashers
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Whirlpool Dishwasher,serial number 330251002448 wont stop beeping
The main controller appears to be very confused or failed.
To test, fully remove power from the diswasher for at least 90 seconds. Power back on and test. If the same behaviour is seen, the controller card has almost certainly failed. A service call is the next step to repair.
If you reply, please include the model number of your Whirlpool Dishwasher. Good Luck!
Mar 30, 2009 | Dishwashers
Fridge not cooling properly set all the way to coolest setting freezer seems to be cooling ok
check coils underneath may be dirty, if frost in frz. back wall then you have a defrost problem. make sure door was not left open (accidently). make sure door closing properly and gasket is sealing properly. check to make sure light turns off when door closed. hope this helps if not contact us with any additional info. needed. thank you for your time.
ALL BRANDS APPLIANCE REPAIR
5008 W. LINEBAUGH AVE # 8
TAMPA FL 33624
OFFICE # 813-908-2002
FAX # 813-908-5559
WEBSITE allbrandsappliancerepair
EMAIL custmomerservice@allbrandsappliancerepair.com
Jul 11, 2008 | Whirlpool Refrigerators
Printer deskjet 3650
change your cartridge.
but i think your printer got more problems.
Mar 27, 2008 | HP DeskJet 3650 InkJet Printer
INDESIT DW S 60
check and make sure the door switch is activating
Jan 03, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwashers Logo
383 people viewed this question
Top Dishwashers Experts
