Washing machine fills in the water but does not start the wash cycle
My washing machine starts to fill in the needed water but straight away stops after that. The wash cycle does not proceed. The agaitator does not move. Even if I change the wash cycles nothing happens. Please assist ASAP
  • 5 more comments
  • president123 Sep 01, 2008
    ginko, the model of the washing machine is Electrolux EW1013i. It's a fromt Load Washing machine. Please help. Thanks.
  • Anonymous Jan 02, 2009
    Machine fills water, but doesn't run the cycles even moving the timer manually.
  • lary 1 Jan 19, 2009
    washer fills with water agitates for about 1 min, then adds more water agitates and it does this over and over if i move knob to spin nothing happens.
  • Anonymous Mar 19, 2014
    fills up with water but will not start the washing cycle
  • Anonymous Mar 28, 2014
    on starting the wash cycle on cold water, no water enters the washing machine at all. the machine rotates but no water enters.
  • Anonymous Mar 29, 2014
    fills with water but will not start the wash cycle
  • Anonymous Apr 01, 2014
    I washed four towels and the machine stopped at 1 hour and 19 minutes. It now keeps filling and trying to wash , never moving form the 1 hour and 19 minutes position. It won't let me change the program. It also rattles when you turn the inside of the machine
  • Washing Mach... Master
  • 19,396 Answers
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    • wayne fox Nov 09, 2012
      Can the water level switch also work the other way in the fact that the drum of the front loader fills with water and continually fills unless you physically shut off power. If left to run it would overflow through the dispenser tray for detergent!
    My hoover 500mb 5.0kg washing machine fills up fine at start of cycle then just washes for a bit then just stats to fill up and wont stop till I stop it
    I had a similar problem and not sure whether my solution would help you.It was to do with the position of the waste pipe.It should raised about 2ft. ,looped before discharged into the washing machine tee.when the discharge hose is lying on the floor there's a possibility that the water is filling up and going straight out.By raising it you are letting it fill up and presumably triggering the water level sensor.Hope this helps.
    May 29, 2017 | Hoover Washing Machines
    Washing machine Hotpoint Aquarius WMF740
    Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
    May 04, 2015 | Washing Machines
    My Maytag Performa washing machine will not stop filling with water and start the next cycle
    you need to unplug it from the power when it does that to see if it stops filling. That will tell you if it is a valve issue or a problem with the controller
    Feb 09, 2013 | Washing Machines
    My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Water won't cut off when filling... Hoover Galaxy A6834
    Hi Steveb6723 ,Just read your posting.Now here is a little test I need you to preform so I can tell if the problem is your water valves or your pressure switch system.Now 1st turn it to a normal cycle and only select the cold fill.Pull the knob out so it starts to fill.Now turn the machine off at the power point,Does the water stop filling straight away?If it does select hot fill and pull the knob.When it starts filling on hot water turn the power off again and see if the water
    stops straight away.Please reply and tell me if the hot or cold water continued to flow when the power was off.Looking forward to your reply.
    Jun 24, 2010 | Washing Machines
    F&P washing machine:GW709 doesn't cut out when filling
    could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
    Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Doesnot stop filling water
    To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
    To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
    Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
    Washing Machines Logo
    3,828 people viewed this question
    Top Washing Machines Experts
