Question about Indesit W 123 Front Load Washer
Indesit widl102 I have the above washing machine, the washing machine works but it will not spin around, so it wont drain or anything. Can someone please advised me on this
  • Jzip Sep 11, 2008
    Our washing machine ill do part of the cycle but wont drain & spin = its only 10 months old
  • optimom Sep 30, 2008
    think i overloaded my indesit today. now it won`t spin. please help. Optimum
  • 3,741 Answers
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Aug 24, 2009
  • 36 Answers
The drive belt is broken. a lowes or home depot will replace it for you at a very cheap price. thank you for using fixya
Posted on May 01, 2009
  • 209 Answers
SOURCE: indesit w113 washing machine
check heating element (rear of drum at the bottom) for open circuit, replace if needed, occasionally the timer will start to click round continuously, indicating the machine has a fault, the machine shuts down waiting for the water to heat up, elements available at most appliance shops but you may need to order specially?
Posted on Sep 02, 2007
bono1
  • 32 Answers
SOURCE: Not Spinning or Draining !
Hey there
well from what I can understand here you need to check first 2 things
1) Check that the hose that is connected to the machine is empty and that there's nothing blocking the water.
2) another possiblity is that your Pump isn't working.
saince i don't knwo the model I can't tell what kind of pump you have, if you have direct pump is should be abouve the motor, it' pretty easy to inspect it and look at it, it may be blocked from all kind of junk (coins.....) another option is that the pump blades are worn out so it's not pumping ( i don't think its your case since your washer is prettry new)
Hope this helps
Bono
Posted on Mar 24, 2008
futureloginn
  • 734 Answers
SOURCE: I have an Indesit washing
hi there,
* If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt.
* If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper
repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation
the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub
* Is there hot water coming through the proper hose? If not, check to see if the screen inside the
water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the
fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so,
completely replace it.
Posted on Dec 12, 2008
BIKER T
  • 909 Answers
SOURCE: Hi.I have a indesit washing machine model W103.It
I would say, place a voltage tester on the pump motor wires and see if there is power to the pump. If there is, replace pump as it is defective.(very common problem). If not, your timer is unfortunately needing replacement. Let me know.(This is on the drain cycle when testing).
Posted on Oct 06, 2009
beltronic205
  • 1474 Answers
SOURCE: WIDL102 indesit washer dryer not working properly
check heater element/ should read about 32ohmns on multimeter if not reading replace,if ok replace stat
Posted on Apr 07, 2010
WASHING MACHINE WONT DRAIN OR SPIN
did you get a solution as i now have this problem
Jun 08, 2010 | Washing Machines
Apr 03, 2010 | Indesit W 123 Front Load Washer
My washing mashine wont spin or drain
hi there,
it sounds like the drain is blocked, check the drain access at the front
for any debris/or coins that may have been left in the pockets of garments, have a good rake around and use a torch, the machine will not spin without pumping out the surplus water so there lies your problem blocked tubes or a faulty water pump.
Feb 15, 2010 | Indesit W 123 Front Load Washer
Indesit widl102 washer dryer has 2 led lights flashin
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little.
Not a true fix just a work around.
best to you.
Nov 30, 2017 | Indesit W 123 Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washing machine wont spin
Your machine may not be receiving adequate voltage to start. Make sure your machine is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your machine. Also, refrain from using an extension cord to plug your machine in.
Dec 03, 2008 | Indesit W 123 Front Load Washer
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Washing machine wont do anything
rotating timer knob indicates that there is a fault, obviously, so its a case of going through a checklist, based on info given, check in this order, outlet pump, for open circuit, then heater element for open circuit, then maybe the water valves, you have given little information for me to go on as an engineer, please understand, the more you say the more detail we can give ..... ok cheers with looking for the fault, best of luck and work safe
Dec 21, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
337 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
