Question about HP Jornada 548 Pocket PC
HP548 internet access via USB/Serial
Is it possible to access the internet when the Jornada 548 is docked (Serial or USB)? Avantgo does, so is it just a question of configuring the Internet Explorer connection settings? (How to select '57600 Default PC Connection or 'USB Connection?)
adib
  • 450 Answers
SOURCE: Jornada 548 won't print to IR on hp 450 mobile printer
the ipaq automatically adjusts for daylight savings but the PC does not. On your PC double click on clock, click on Time Zone tab and then on that screen you will see the box that needs to be checked. also check that both PC and IPAQ are set to same time-zones.
Posted on Sep 12, 2005
adib
  • 450 Answers
SOURCE: USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
adib
  • 450 Answers
SOURCE: Jornada 680 won't sync over network
Hi. Put your desktop ip-address into your network card wins-address field (on your Jornada) Works for me :)
adib
  • 450 Answers
SOURCE: AC Adapter Buzz Noise
The jornada 548 power adapter should not be buzzing - it should be very quiet.
SOURCE: Cannot access secure sites using Internet Explorer on HP Jornada 720 running HPC 2000
Download and install HPCTweaks2k2v06.exe then apply the "identify PIE as IE 6.0"
Posted on Aug 01, 2008
Having a hard time installing USB sync cable from hp jornada 540 to win xp pro sp3 hp desktop.......already installed ms activesync!!!!!!!!! hp win xp pro sp3 desktop says failed to connect to the...
If you do a new, clean install of XP in 2018, one would be missing hundreds of updates from Microsoft that would be very hard if not impossible to get. Some of those updates might apply to software that you want to use in conjunction with Windows XP. And if it is an older PC, you might not be able to find driver support for the particular make/model, and XP might not have the drivers you need. How many times have you heard someone say, "I just reinstalled XP, but now I am missing drivers?"
This could be part of your trouble, because even if your XP updated all the way up to April 2014, you could still be missing HP updates provided by HP/Microsoft through Windows Update.
Since Microsoft has not supported XP since April 2014, I would recommend not using it anymore in 2018.
Jan 29, 2018 | HP Jornada 540 Pocket PC
I cant figure out how to connect my jornada to my pc.. can you help?
Are you connecting from dock to USB on computer, or serial to USB via a USB-serial adapter? UBS-serial adapters are notorious for not recognizing attached serial hardware. What kind of errors are the Jornada and the computer throwing? Can you give any specific error numbers?
If you are connecting using the serial cable to a serial port on your computer you need to make sure that the Jornada is trying to connect to the correct COM port (and that the computer is allowing connections through the correct COM port). Do this by:
1. Open Device Manager (R-Click on My Computer - Properties - Hardware - Device Manager)
2. Expand the "Ports (COM)" plus sign
3. Beside each COM port's name it will say (COM#) - the # tells you which port the COM is
4. Go into ActiveSync and open Connection Settings (in the File menu in ActiveSync 4.5 - the latest)
5. Make sure all the check boxes are checked and that the correct number COM port is selected in the drop down menu under "Allow connections to one of the following:"
6. Connect your Jornada via the serial cable, make sure the Jornada is on and connected to power cable (I have had more success with the power on - may or may not affect your problem)
7. Click the "Connect..." button in ActiveSync. The Jornada should be detected.
If your computer has an infrared port you could try that, I have had a lot of success with infrared connections with my Jornada. Also, try installing ActiveSync on another computer that has a serial port and try connecting the Jornada to that computer. It may be a problem with your computer.
An older version of ActiveSync should not make a difference. The facilities are the same, just slightly rearranged.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Computers & Internet
Hp jornada 720 handheld pc
Try a older version of active sync. 3.0 or 3.1
heres 3.1
http://www.tucows.com/preview/32548
Feb 17, 2008 | HP Jornada 720 Pocket PC
Avantgo
I am unsure myself after looking at this Pocket PC software matrix. Today I use AvantGo in my HP Jornada under PPC2000, but it seems it is not installed in the PPC 2002 software according to this matrix. Maybe there is a download you have to do, or settings for your server access you have to make?
Sep 13, 2005 | Dell Axim X5 Pocket PC
Sep 12, 2005 | HP Jornada 548 Pocket PC
Sync problem w/outlook contact
I use my 548 to keep my work and home versions of Outlook syncronised. I have about 70 contacts stored. Three suggestions.. 1) Do you have enough free memory? Emails can take up megabytes, and for that reason I choose not to sync emails. 2) Are all of your contacts in the same Contacts folder? I have two contacts folders on my home Outlook, one for me and one for my wife, I only sync my contacts to my 548. 3) In Activesync, click on Options, Sync options, contacts, settings and make sure that "Syncronize all contacts" is checked
Syncro Jornada 525
You can buy a USB cable for your Jornada. HP and thrid party vendors sell them. I bought one that has a cigarette lighter adapter to charge the Jornada also.
Sep 12, 2005 | HP Jornada 525 Pocket PC
Sep 12, 2005 | HP Jornada 520
Time off by one hour
a pocket PC that still runs. wow. a blast from the past, 2000.
16 years it works ok , then today it fails?
you need to set time zones. and if you have DST , day light savings time in your unstated locations.
finding a manual on anything that old is problematic to you and most other helpers,
good luck with that.
Apr 12, 2017 | HP Jornada 548 Pocket PC
HP Jornada 548 Pocket PC Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
