Question about Handspring Treo 300 Handheld
Treo 300 Charge/Hot Sync Problem
When I try to charge my phone, it acts like it's trying to sync, and when I try to sync it, nothing happens.
  • 84 Answers
SOURCE: Battery Charge
if it still has warranty, yes take it to sprint if does not try get a charger but before you buy it check if it will work on your phone.
Posted on Feb 11, 2008
0 characters
1 Points
Palm cantro keeps hot syncing can not use my phone
this has also happened to mine like yesterday, dont remove the battery mine wont turn back on now, try letting it charge overnight withoout touching it at all
Oct 23, 2009 | Palm Treo 500 Centro
I tryed charging my palm centro with the USB cord and the red light came on but it didnt charge what do i do?
your laptop is plugged in right? I would check the battery options on your laptop.
Aug 30, 2009 | Palm Treo 500 Centro
My palm 755 wont hot sync
Restart your Palm Treo 744p. Take out the battery from the phone for more than 3 min and put it back in. Switch on the phone and then try to Hot sync Again. Hopefully it will work. I am assuming that you installed the Palm Desktop software came with the phone on your computer
I have same problem once in a while when i try to hotsync with new comp and this trick always worked for me.
Nov 17, 2008 | Palm Treo 755p Smartphone
Treo 755p Getting Stuck During HotSync
If you have another computer you could try installing the software on that to see if the Treo will sync.
This would determine if it's a computer problem or if it's your Treo.
When you unchecked the datebook to sync after uninstall/reinstalling, was it able to sync then?
I have had other palms get hung up to a certain point during the sync, but uninstalled the program or disabled it from syncing like you tried and it usually works.
Sep 24, 2008 | Palm Treo 755p Smartphone
Battery Charge
Feb 11, 2008 | Handspring Treo 300 Handheld
Hot sync
Try reseting the palm.
Jan 02, 2008 | Palm Treo 680 Smartphone
Unable to place a call or receive a call on treo 650
May I know since when the problem occur and what's happen if you tap phone application?
Nov 07, 2007 | Palm Treo 650 Handheld
Haldheld Sync
Need more details, DFerr. You need to have Act! Link 2.0 to work with Act! 5, Act! 6 or Act! 2000. How are you trying to sync it? What version of Act! do you have? You might want to puarchase companionlink express from www.companionlink.com.
May 29, 2007 | Palm Treo 650 Handheld
When I hot Sync my Treo 650, my tasks hot sync fails
I changed so that the desktop over-rides the handheld and the hot sync went through. This is not the way I perfer this, but it worked. I have not switched it back to sync the files yet to see what would happen.
Sep 11, 2005 | Palm Treo 650 Handheld
Sync doesn't sync with Calendar, then Hot Sync crashes
Try Creating a New profile from Start Control Panle > Mails > show profile > Add profile > After Adding the profile set the new profile as default
Try deleting the partnership by disconnecting the device and opening and deleting the partnership.
Plug your device back and try to sync
This should work
Handspring Treo 300 Handheld Logo
23 people viewed this question
Top Handspring PDAs Experts
yadayada.
yadayada.
fgg3
ray gallant
Are you a Handspring PDA Expert? Answer questions, earn points and help others
