Question about HP Jornada 820
Jornada 820 and Wireless
Long story short, my boss pulled an 820 out of the closet, blew the dust off it and gave it to me. I replaced the batteries in it and it's all working cool and syncing and everything else. I have an 802.11b network at home and am trying to get this to work, and it's not. Google searches turned up a Compaq iPaq driver, which downloaded ok, but doesnt seem to work. Am I wasting my time, or is this possible? :)
    Master:
  • 450 Answers
It is possible, but you need a notebook PC Cards (PCMCIA) that supports Windows CE 2.11. Most Compact Flash wireless LAN cards need Windows CE 3.0.
Posted on Sep 12, 2005
The thermal fuse keeps blowing
If you pull it out of closet and replace fuse and it works even after turning off again etc for several times--something is happening when it gets put back---did you disconnect venting connection when you pulled it out?
Dec 17, 2012 | Estate EED4400WQ Dryer
HOW TO STOP DUST BUILDUP IN AC CLOSET
Seal closet with caulk or mastic or foam.including top, sides, platform and around base of unit. If base is not sealed it can pull from outside of closet through door. If base is sealed but top and sides of closet are not then return air can pull from inside closet from attic or inside walls. Either will turn your door casing into a filter.
Aug 31, 2012 | Ruud Heating & Cooling
Columbia Telecommunications Group 2-way watch - battery needed
A close but not a perfect match....
Columbia FRS22-WH L301 Li-ion 3.7 Volt 500 mah Rechargeable Battery
Battery code L301
1 7/8" by 1 5/32" by 1/4
Contacts are on the flat side - 3/16" from the wide edge and 1/16" from the long edge
Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features
***Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820***
Best replacement battery for FreeTalker Walkie-Talkie RD-810, RD-820, RD-008, RD-820.
Crafted with latest Lithium-Ion technology, it is intended to delivers long lasting talk times.
This Li-Ion based battery provides power in a thin, short and light package, fits the compatible
Walkie-Talkie model perfectly. It has power capacity of 600mAh, which allow you constantly talking
for 3 hours. standby time up to 3 days. It is absolutely an ideal choice that you won't be sorry
for getting.
Features:
* Battery Type: Standard Li-Ion Battery(Model: RD43048)
* Capacity: (600mAh)
* Voltage: 3.70 V
* Talk time: 3 hours. Standby time: 3 days.
* Color: black
* Dimension(L*W*H): 4.6x3x0.5mm
* Weight: 0.015Kg
Compatible Model:
RD-810, RD-820, RD-008, RD-820 FreeTalker Walkie-Talkie
Jun 17, 2008 | Columbia Telecommunications Group FRS 22...
Manual and battery charger needed
I'm still looking for the manual (?).. it's more of a pamplet as I recall.
The battery charger is...
AC/DC Adapter Model 0750200DF
Specs are:
120 V AC 60 Hz to 7.5 /v 200ma
If you can't find the right adapter, you can probably get one of the universal adapters that will work.
I also recommend that you replace the batteries with "Brand New Original Pair Battery For FreeWalker RD-810, RD-820, RD-008, RD-820 Features
for getting."
Much more talk time than the original batteries.
Dec 07, 2007 | Columbia Telecommunications Group FRS 22...
Memory
There is the extended battery pack adds an MMC slot and leaves the CF slot open... So you could use the CF for the Wireless LAN and the MMC for extra memory...
Sep 12, 2005 | HP Jornada 567
Dust under Jornada screen
Well, you should not even try to clean it. Contact your local Jornada support and they will get the unit to repair, This is a in warranty thing, so you don??t have to pay anything.
Jornada 680 won't sync over network
Hi. Put your desktop ip-address into your network card wins-address field (on your Jornada) Works for me :)
Sep 12, 2005 | HP Jornada 680 Pocket PC
Jornada 820 - WiFi cards HELP
Can you try inserting the card and resetting the unit with the reset button. When the unit is back up got to start>programs>communications>remote networking then make a new connection. Choose dial up connection and select your card.
Sep 12, 2005 | HP Jornada 820
HP Jornada 820 Logo
122 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
