Rubber seal rubbing/melting away after one week
Followed all the instructions to set up machine (to the letter), however the rubber seal has worn down leaving the residue on clothes.
A technician came out to look and said it was nothing we had done and we recieved a new machine. However after just 4 days the same problem has accured. Now Hotpoint are coming to take a look.
Has anyone heard of this happening before and if not could someone tell me if this is something a washing machine should be doing. I my mind its not. Now I have grey rubber residue all over my washing and cannot put said washing in tumble dryer as it would melt!! Help me please.
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
SOURCE: Washing Machine smell
The problem comes from the design of the front load washers. There is always a little water left in the tub after the machine is used. Running a bleach load will deal with the mildew until the machine is used again. I leave the door open when I am not using my washer, and this does help.
Posted on Sep 05, 2008
docjohn174
  • 943 Answers
SOURCE: Clothes smell like mildew
HI thanks for your question. My solution is 1 cup of vinegar, per wash load. In time, will solve your problem.thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
  • 3 Answers
SOURCE: Ariston "Margarita 2000" Model AL129X [front load washing machine] - Clean sludge from door seal.
I don't think it is easy to remove it, but you can clean it with white spirit or something similar.
Posted on Oct 29, 2008
  • 5 Answers
SOURCE: what does de mean on the display of the washing
de means your door isn't closed completely.
The moldy smell is really common with this machine, and maybe all of them, but I have the LG TROMM and was ready to throw away all of my towels. Here's a solution I found that helped alot. First, Clorox makes a solution just for front-end loading machines. You run it through on a cycle with no clothes, that helps to clean it out.
I ran my towels through on the cotton/towel cycle on HOT, with nothing more than white vinegar filling the detergent dispenser. After that, I then ran them through again with just a bit of soap and fabric softener. They came out soft and smelling like new.
I read recently that we all use WAY too much soap in both our washers and dishwashers, even though that's what's recommended in the directions. Excess soap in clothes that doesn't get rinsed out will begin to smell moldy. So I now use about 1/4 of what the directions call for, and they come out fine. I have found, however, that I need to repeat the vinegar cycle once every few months. I think the problem is inherent in that model machine.
And that rubber seal? Disgusting! I clean it out regularly, but when it's full of water after every load of clothes, what do they think is going to happen??? You'll find that Clorox cycle will clean the seal pretty well, though. Good luck!
Posted on Apr 05, 2010
Testimonial: "Thank you so much. You were right - this has helped with the smell. I have had this machine for 2 years now & only just started having this problem. "
It,s leaking
Hi, it could be a number of things like a rubber hose connection that's maybe started to leak underneath or the door seal has a worn part rubbed away by the clothes or just a seal has broken. Its best to get it looked at as you don't want water into the electric's.
Feb 12, 2016 | Washing Machines
My front door which opens outward freezes shut, how can I fix this problem?
Spray some cooking spray on the rubber seals around the car doors and then rub it with a paper towel. The doors freeze because of snow melting into the seals and freezing overnight; the cooking spray oils should protect against that melting water. You can try also some silicone spray.
Feb 10, 2015 | Refrigerators
Drum stopped rotating at end of cycle smell burning rubber
There are two likely reasons for the rubber smell - either the drum belt has melted and snapped or the drum seal has rubbed too much and melted. Most likely cause would be poor drum bearings or consistent overload of washing. I am assuming this is a front loader as you have not provided any details of make or model.
Sep 26, 2014 | Washing Machines
Washer maytag front loading 4000 series assembled and runs but iwith two problems.1) residue on inner surface of door window..lint like oily paste ..gasket rubbing on inner drum?? meaning main rubber
The fault seems to be that the main seal is rubbing against and is thus producing the oily residue on the window. Now the fault seems that the drum is rubbing due to POOR ALIGNMENT or poor BEARING settings.
You need to check the PLAY on the drum and if this shakes a bit then the assembly must be reset with correct aligment and the drum must move without rubbing the rubber seals.
Check this link; replacing bearings
Jan 14, 2013 | Maytag Washing Machines
How can I clean the melted rubber seal from a Bialetti Top Espresso Machine?
I scraped off as much melted rubber as possible - using my thumb nail - then used a product called Goo Gone to melt the remaining rubber. I put Goo Gone on an old cloth and rubbed off the remainder of the rubber - again with my thumb nail.
Jan 08, 2013 | Bialetti 20-9 Stove Top Espresso Machine
I lose pressure in the brake peddle after i stop.
The push rod rubber ( oil seal ) on your brake cylinder was worn out or tear or melt or with small hole,located at the back of the hydro back. In your wheel there are rubber (oil seal) inside the piston that usually worn out long term use. Once you replace the rubber you need 2 person to adjust the pressure. First engine Start, 1 is in the Driver seat pump the brake and then the other 1 releasing the air in the fitting.
Aug 16, 2011 | Car Audio & Video
Black marks appearing on towels. Look like marker, smudged.
hi.
it could be the seal on the front of the drum starting to break down.
clean the seal at the front of the drum that seals the door. then rub a white cloth/towel around the seal
if there are any marks left by the seal then the rubber compouds are starting to break down and the seal needs to be replaced.
please feel free to ask for detailed instructions on changing this seal if you need them
Apr 13, 2011 | Frigidaire GLTF1670A Front Load Washer
Oil seals are always leaking and always replaceable for only 2 weeks
the rubber seals are rubbing on very scored machined metal tearing up your new seals. remove and inspect what part the seals are applied to and get back to me
Mar 05, 2010 | 1995 Isuzu Pickup
Smoking washing machine
Switch it off before you burn your house down
The drum support sounds to have either cracked or come loose allowing the drum to run on the door gasket
The friction will cause the rubber to melt and burn hence the smoke.
Get a service person out to it asap
Jun 14, 2009 | Whirlpool GSC9455 Top Load Washer
Washing Machines Logo
165 people viewed this question
Top Washing Machines Experts
