Question about Lexmark X2470 All-In-One InkJet Printer
New cartridge I put a new cartridge in but the printer doesn't recognise it. I compare the it with the original one and it looks a bit different althogh it's the same lexmark 1 cartridge. Can you help pleaes?
Posted on Sep 28, 2008
I have a Lexmark X6690 and bought new Lexmark print cartridges today - Black and Colour. The printer is recognising the colour cartridge but not the black one. Driving me nuts!! Please help x
Try to reseat the black cartridge. If that doesn't help, try to clean the cartridge nozzles. On the printer operator panel > press Setup button > Maintenance > Clean Cartridges > Ok. Your printer will then print a page, forcing ink through the nozzles to clean them. Try to print again. You may also try to insert a different known working black cartridge to determine if the other is faulty. If your new cartridge is faulty, return it to the purchase store (if within return period) or contact Lexmark technical support for assistance.
May 27, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Epson nx400 doesn't recognize ink cartridges
First of all let cartridge in the printer.... Then press Start.. it will say cartridge not recognised... then remove all cartridge (do not turn off printer).. then wait for 15 minutes...then again put cartridges in head... then press start..start...start..It will recognise on 2 to 3 tries.. Works on Epson TX210,200,410...If u want to be recognised then do not turn off printer...
Aug 13, 2010 | Epson Stylus NX400 InkJet Printer
Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
My D145 HP all in one Officejet doesn't recognise new colour cart
hi penned2you, when you say that you have installed new colour cartridge, is it a new refilled cartridge or an original from the manufacturer? cause if it is refilled then most of the time depending on the level of ink that was in it... the printer will not accept it, when you say you have tried different ones, do you mean different empties that were in there before? cause if it is then the printer will not accept them either. to get them to be accepted you have first know that the printer stores 3 cartridges in memory and so you have to let it read for eg. the colour catridge #i, then #2 then #3, after cartidge #3 is inserted then colour #1 will now be accepted. the same goes for the black if you're using original cartridges then these steps dont apply... the only thing i know of to rectify the problem is to clean the printer cartridge contacts and then cleaning the carriage contacts. if done correctly it should work. if not then give me some more info on your situation, casue i would suspect that the printer itself maybe damaged (if it is infact you have inserted more than one different new original cartridges) if these intructions helped in any way please rate it and also to let me know how it turns out.
May 09, 2009 | HP OfficeJet D145xi All-In-One InkJet...
In March of 2007 Epson started putting a different chip in some of their cartridges so that refill companies couldn't refill them. My printer is a CX8400 just purchased last Oct but manufactured Dec of 2007. The date they changed the cartridges was March of 2007. You must then buy cartridges Original OEM or find a company that has cartridges for before that date or after depending on when your printer was made. Look at the bottom of the printer for little clock dials and you can determine the date of manufacture. On mine the first number was the year and the second the month. Check ink companies online to see if this applies to your printer. Some ink companies don't mention this or just send you the wrong ones.The older cartridges will not work in the newer models.
Jan 22, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Ink Cartridge problem
The 6310 takes a #95 tri-color cartridge. #901 is for Officejet 4500 and 4600 series printers.
Dec 22, 2008 | HP Officejet 6310 All-In-One InkJet...
Wont recognise new colour cartridge
Leaving the cartridge out for an extended period is never a good idea, but it shouldn't be fatal. Make sure you put the photo cartridge in the black slot - not the color one. If the problem persists, you might want to reload the driver for that printer from the website.
Oct 21, 2007 | Lexmark P4350 All-In-One InkJet Printer
Will not recognise new ink cartridge
This is not a driver issue. You say that you have used this printer for years, if this is so then chances are the printhead has finally gone. If this is the case then not matter what cartridge you put in it wont be recognised. A new printhead is anywhere between £75-£95 and not very easy to fit. It looks like its time for a new printer. Printhead Info:
Dec 25, 2006 | Epson C64 InkJet Printer
Lexmark X2470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
