Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
Memory card incompatible
Thanks for prompt response.Does this mean that despite the SD Memory Card fitting perfectly,all SD Cards are not comaptible? Could there be a problem with the printer itself,which does however print emails etc perfectly??
  • wbamick Sep 02, 2008
    Thanks.Will do as you suggest as this would seem to be the only slot that does not function properly.
    Genius:
  • 2,785 Answers
Your sd card slot may have problem plz ask your local vendor to check it.
Posted on Sep 02, 2008
Hi i got a 32 gb sansa fuze memory card.. like 2 weeks ago. from buy.com and well today i got my sansa fuze white player. the memory card will not fit into the player. I would like to get a memory card...
From your description, you seem to have bought a regular SDHC (secure digital high-capacity) card. A Sansa Fuze can only accept micro SD or micro SDHC cards. For buying a new card, I would suggest this card from newegg.com. As for other things you mentioned: No, the card you bought is not meant for cameras only, the only reason your device uses micro SD/SDHC cards is because it is a smaller device. The 4 on your card signifies that it is class 4 which is the card's speed classification.
Jul 12, 2011 | SanDisk 1GB microSD Memory Card
Card not initilized? what does this mean?
It means the card has not been formatted, or that the camera doesn't recognise the format, but that might not be the full story. You don't say whether this is a new card or one you used before. I'm going to assume this is a new card (otherwise, it means the card has become corrupted or there is a camera fault).
The first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then the card may be incompatible. Formatting deletes anything already on the card.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
If it is a new SD card, then maybe it is actually an SDHC card. "SD" cards larger than about 1GB are usually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible
Jan 22, 2011 | Fuji FinePix A330 Digital Camera
I have purchased a 4GB SD-HC memory caard for my pentax optio s6. when istalled the card, the screen was turned on ok, but could not perform any function. Few minutes later a "memory card error"...
The Optio S6 works with SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible. You need to use SD cards, 2GB and smaller.
Jan 13, 2011 | Cameras
I own a Panasonic Lumix DMC-FZ10, but have never been able to use it because of a 'memory card error'. the camera is brand new. despite trying other SD cards, i an unable to shift this error. any...
This camera should be able to use any SD card of 1GB or less capacity. If you have been trying to use larger capacity cards, that will be your problem (larger cards are actually SDHC, which fit the same slot but are different electrically). If the cards you have been trying are smaller than that, then there is most likely a fault.
These cameras come with a memory card that will work with them (it is very small capacity). If you have tried to use that one and it won't work, then return the camera under warranty.
Dec 25, 2010 | Panasonic Lumix DMC-FZ10 Digital Camera
What does "memory card error" mean
It usually means that you are using an SDHC card in a camera that only understands SD cards. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
If that isn't the problem, it may mean that your card needs formatting or has become corrupted, which will be fixed by formatting it. Formatting deletes everything on the card.
If that isn't the problem, then there may be a fault with the card or camera.
Dec 09, 2010 | Canon PowerShot A530 Digital Camera
Does not work with 8mb memory card. Why not please? Canon A540. Problem occurs when change a 2mb card for a 8mb card. Have not tried anything to fix problem
The A540 is designed to work with SD cards. Your 8GB card (I assume you really mean gig, not meg) is actually an SDHC card (SDHC stands for Secure Digital High Capacity). While SDHC cards will fit into SD slots, they will not work in SD devices. You need to keep using SD cards, 2GB and smaller.
Aug 23, 2010 | Canon PowerShot A540 Digital Camera
Why can't I get pictures off of an 8gb but I can off of a 2gb chip?
Some cameras cant manage/format large size memory cards as they where not made to handle that size. Check your user manual which should tell you the maximum size memory card your camera will take.
Aug 04, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
I purchased a new memory card (sandisk sdhc ) it will not format?
Get a new camera :-)
Seriously, the Z740 is designed to work with SD cards, not SDHC cards. While SDHC cards will fit into the camera, they will not work. You need to buy SD cards 2GB and smaller.
Jul 26, 2010 | Kodak EasyShare Z740 Digital Camera
Tried to download software for r4 micro sd card 4gb sh but does'nt work.comes on the ds loading ,works fine with 2gb sd card,any ideas? thank's colin
Hey there Colin,
The original R4 card only works with Micro-SD cards up to 2GB in size. To use Micro-SD cards up to 32GB, you need to buy the newer R4 SDHC card or a Nintendo DSi comaptible card. Check out R4 Cards / R4 DS Cards from DSCardWorld.com or NDS-Gear.com (NDS-Gear is probably better if you live in Europe or Canada as their shipping's slightly better internationally).
Oct 14, 2009 | SanDisk 2GB microSD Memory Card
Problem getting HP Photosmart to recognize digital camera memory card
From what read of the specs, the C6100 does not support SDHC cards, only SD cards. SD cards top out at 2GB; what you have is technically an SDHC (High Capacity) card, which does not work in SD devices.
Jul 22, 2008 | HP Photosmart C6100 All-In-One Printer
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
