Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 starts up on its own!!
I'm having a bunch of issues with my Dell, re. startup and shutdown.
It started with it booting up on its own from switched off. I don't have wake on LAN or wake on USB enabled - it just does it.
Then, just yesterday it started booting up on its own and immediately shutting down after a couple of seconds. Finally, it shut down and wouldn't restart. A long hard push of the on/off button would fire it up but it would shut down again after a couple of seconds. Fans kick in and HD whirrs but only briefly.
I opened the case and gave everything a clean but it didn't help. Then I went out and when I came back it had started up fully and was working fine. :$
The system is obviously shaky. Any ideas?
  • 1 more comment
  • kamsiuzo Sep 01, 2008
    pc cannot open web page
  • Him Up North Oct 03, 2008
    I changed power supply, power cable and power strip - still same problem. And then...
    I took the side off and had a root around. I disconnected the ribbon cable from the power button panel to the mobo. When switched on at mains, the PC booted right up. Of course, with the power button disabled, I can't switch it on when powered down, nor can I use the two USB ports at the front. But it has shown the nub of the problem.
  • tarek_mw Nov 26, 2008
    I have almost the same problem. I completely removed the front panel, which includes the power switch and the usb ports. I just connect the panel for less than a second. I push the button on and immediately remove it. The computer started to work. I worked for more than a month with no problems. then the same started to happen again: it works for a few minutes and just turns off. sometimes it can be booted again and sometimes not. looks like a heat thing but the fan works well. any suggestions.
Hi All,
I had the same problem - shutting and restarting over and over again. When called Dell, they said it is most likely the motherboard and will need changing. I personally suspected that it has something to do with the power supply.
I was right. I replaced the 305W power supply with a 370W one. Problem solved with just £25 and a trip to Maplin.
Let me know if this helps.
Posted on Jan 24, 2009
I had the same problem, tried changing the PSU but no change and the old PSU checked out fine on a power test unit.
Turned out to be the switch panel with USB and audio connectors being defective. Try changing this and you should be OK
Posted on Nov 14, 2008
    Scholar:
  • 152 Answers
Check the power cable for some defect. It may have been twisted and the wires inside broken. Try using an alternate power cable and see how it goes.
Posted on Sep 01, 2008
I'm looking for advice on how to reboot a dell dimension 5150
You can reboot by Operating system , Click start>Restart
OR
you can press power button for few seconds, it will power off, & then you can press power button.It will start booting up...
Thanks for choosing Fixya
Mar 16, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Haii.. i got a dell dimension 5150 pc desktop the problems is always when i boot time ,its shows a blue screen thats tells the system have to shutdown and check ur hard disk,i have changed the hard disk...
Boot machine then press F8 till u see Advanced Boot options, then go into Safe Mode with Networking and follow instructions on the link below to turn off Auto Reboot on Blue Screen.
http://www.tunexp.com/tips/maintain_your_computer/disabling_blue_screen_of_death_auto-reboot/
Then, get BlueScreenViewer application to Debug what is causing it.
http://www.nirsoft.net/utils/blue_screen_view.html
Do a Find on the site for the word 'Download'
Sep 25, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My computer is running very slow it is a dell dimension 5150 pc desktop and it takes 5 full minutes to load at least.. help? 2/3 of the desktop space is being used.. I dont know if it's because of that..
Go to Start --> Run, type "msconfig".
Go to the tab labeled "Startup", and disable all the items on that list.
Make sure you are not on the "SERVICES" list.
Jan 21, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 4600 will not reboot. I have to turn it off, unplug the power, push the On/off switch for a moment, let it set for 15 min then it will reboot. I have recently upgraded from 256kb ram to 1gb,...
from what you describe, they system will not shutdown. So try the following:
  1. Boot to safe mode (F8 at boot) and then see if the system will reboot from the safe mode.
  2. Boot to the Safe Mode again, Start RUN MSCONFIG, edit the startup group, (Basically uncheck all the items in the startup tab) reboot in the normal mode then see if it shutsdown. If it shutsdown normally, then start adding items back one at a time until you identify the items that were causing the items.
Jan 12, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension 5150 will not start!
This is related to Hardware.
There might be a lose Ram of data cable connection on Motherboard.
This type of issue is also seen when the there is dust accumulation on Process Fan and CPU fan resulting in over heating.
This might also be due to malfunction of a motherboard.
The third reason could be that SMPS his not working.
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 boot up difficulties - just goes to the Dell screen and then nothing - a little blinking white dash in the upper left corner. I usually hit f12 to boot from there, but it seems that...
try to run diags, press f12 when booting the choose utility partiton. check for any error on your HDD but it seems like its an OS issue so all you need to do is to uninstall and reinstall your OS
Sep 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My 5150 is not booting
sounds as if you have a hard drive issue and i would start there first by seeing if you can connect the hard drive to another pc and pull it up if you can than you have other issues
Sep 02, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 no sound - please help
You should be able to download the original driver files from Dell Support Drivers & Downloads.
However, this may be worth a try:
Go to Start --> Run, and type in services.msc.
A window will pop up with a list of services. Scroll down to Windows Audio. Right-click
and click on Properties.
Make sure that "Startup type" is set to automatic. Also, make sure, under "Service
status," start is selected.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
DVD/CD ROM problem (Dimension 5150)
you cleared the bios settings by removing the battery.
Go into the dell bios at startup F2
make sure it sees the cd rom drive
then save and exit
should fix the issue
Jan 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
559 people viewed this question
Alun Cox
