Question about Hotpoint Aquarius WF000 Front Load Washer
Replace rear bearing(s)?
Hi i have a wf000 washing m/c and want to know if it is possible to replace the rear bearing(s) at home? i have some limited experience, but dont want to get the m/c stripped only to find special tools are needed.
  • Mick Bishop Sep 01, 2008
    Thanks jsrock516 the info is v.helpful.
    the full number (as listed inside the door) is as follows...WF000P 39108859
    hope this helps.
  • 5,911 Answers
It is possible to replace the rear bearings in one of these front loaders without the use of any special tools. The bearings, however, on MOST of the these model washers have the bearings molded into the rear outer tub shell. That is, the bearings are not removable and you are required to replace the entire tub shell. I is a crappy design. I am not sure with yours, because you did not post a COMPLETE model number. I could not locate any information with the heading you posted this under. I have a pretty lengthy write up that explains this process of replacing a rear drum bearing if you decide to perform the repair yourself. The following link is provided:
Read through the link thoroughly. It is a rather long process, but I have successfully assisted several other consumers with this process on several occasions. You will need plenty of work space, like a garage or patio, and I would recommend an electric drill with socket and/or screwdriver attachments to make the process of removing nuts and bolts much faster. This job normally takes a trained professional about 1 1/2 to 2 hours to complete. I've done many of them and found that it goes faster with assistance. If you decide to go through this repair, please post back with an accurate model number, and I may be able to assist you with locating recommended parts. I hope you find this information helpful. Let me know if you have questions.
Posted on Sep 01, 2008
It is not spinning
check belt, remove top, (2 screws at rear), belt sits on plastic disc at rear of the drum, if not there it may have come off/ snapped. remove 2 screws in plastic cover and remove cover at bottom rear. if belt is there u'll probably need a new one. There may be other issues.
if it doesn't spin manually then probably need to replace bearing. clean filters etc first may be something simple. large black tube under drum to rear beside drainage. remember could get messy. if this doesn't allow for turning then probably bearings need replaced. u'll know if there is evidence of grinding on the disc that the belt sits on if bearings need replaced.
if turns manually and belt is still on almost certainly electrical/ motor issue. check using voltmeter to see if power getting into motor, if not u'll have to know how to fault find. if power getting to motor then could be brushes or burnout
probably a few more things but these are most common
Jan 08, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Cant find bearings for wf000 for the washing maching hotpoint
Morning Tina.
Please look at your model # again.
There is a webdite to check out.
I know they will have your part.
They will assist you greatly
Jul 25, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Replace drum bearings on hotpoint aquarius wf000g
You really don't want to know how but here it is. The bearing is located in the rear shell and is not removable the rear shell has to be replaced which means removing the tub assembly from the machine and completely disassembling. With 30 years of appliance repair the last one I did took about 3 hours.
Feb 25, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Drum not turning otherwise heating and completing wash sounds like a bad rear bearing problem.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Noisy motor
the best thing is to get a new motor from hotpoint website hope this helped
Mar 23, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Wf000 aquarius
if the drum moves slightly up and down then your bearings are in need of replacing u can also check this by going to the back and taking the little cover of in the centre of the back check around the centre of the spider wheel if there is a mucky water mark then they do need replacing this will cost from £90-£150 to replace love
Nov 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Noisey washing machine
i had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Oct 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Are you talking about the main tub bearing?If so I dont recommend replaceing this bearing,because the problem will only keep repeating itself.
May 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
80 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
