Question about Palm Tungsten E Handheld
Why will Tungsten E not HotSync with Star Key?
My new Tungsten E will not Hot Sync with the Star Key. When I hit the Star Key, I get a calculator instead. Any idea why?
    Master:
  • 473 Answers
Go to apps -- then prefs -- then change your button assignment.
Posted on Sep 12, 2005
Can't hotsync replacement t5 ; I dropped my working T5 and have not been able to hot sync my backup unit.
If the new one won't pick up your old files you need to go onto the desktop app and export the data. then create a new id on the new palm. It should now hotsync with the new blank id. Now go back to the desktop and import the files from the other id. Hotsync again and you should have them on your palm.
Mar 19, 2010 | Palm Tungsten T5 Handheld
Can't transfer infor from palm to desktop
Try going to the Palm home page (www.palm.com) and reinstalling the desktop software. Once you have it reinstalled then do a hotsync. I had the same problem and this worked for me. Hopefully it will clear the problem.
Best wishes.
Sep 13, 2009 | Palm Tungsten E2 Handheld
I cannot sync my Palm Tungsten E with MS Outlook.
  1. Step 1 Install the Palm Tungsten software. This software is required in order to sync Palm Tungsten with Outlook Express. To install the software, place the CD-ROM in your PC and follow the on screen instructions.
  2. Step 2 Use the HotSync cable included with your Palm to plug into the USB port of your PC. You will then plug the other end of the cable into your Palm Tungsten.
  3. Step 3 Open the HotSync Manager program on your PC through the "Start" menu or clicking on the icon. You can manage the different programs available for synchronization through this program. Select Microsoft Outlook as one of the applications that you want synched onto your Palm Tungsten.
  4. Step 4 Turn on the Palm Tungsten. You will see a star icon on the menu of your PDA. Tap this star with your stylus to start syncing Microsoft Outlook Express. A dialog box will appear on your PC during the process to know the progress of the synchronization.
  5. Step 5 Unplug the cable from your PC and Palm Tungsten once the sync is completed. As the Palm resets, you will now notice that Microsoft Outlook Express is available on the PDA.
Jun 25, 2009 | Computers & Internet
Hot synch to new computer
If you right click on the hotsync icon in your status bar, you can set each of the sync options to "handheld overwrites desktop." That should stop you losing data.
Dec 03, 2007 | Palm Tungsten T5 - Multilingual Handheld
Can not find an available Com port for Hotsync
Right click on the Hotsync icon in the taskbar (usually at the bottom-right hand corner of the screen) and select "USB" sync, while unchecking "Serial" or "Com" options. Then, initiate the hotsync from your palm handheld, rather than computer. Hopefully this will help!
Oct 07, 2007 | Palm Tungsten E Handheld
Unable to hotsync with my computer
Also, if you have a new Tungsten E2 and there is no important data, I would hard reset it and then when you sync it, select the old profile of the previous Palm to see if that works.
The new Palm you have, is it a Tungsten E2 as well?
The profiles don't always carry over between different models.
Sep 07, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Hot Sync with desktop and laptop computers
it is possible but if I well understood u wanna hot sync with ur laptop calendar and contact from ur Tungsten E, (that is having updated data from ur office computer). you can in fact synchronize verything there with ur laptop, and make ur hand held over write ur whatever is in ur laptop, for this u need to install the PDS and go to the hotsync manager on ur system try, go to custom and and on the list of conduits go to contact and change the action to hh overwrite desktop, (do the same for calendar) DON"T FORGET TO CHECK THE OPTION : MAKE AS DEFAULT. U can of course disable the rest except the system conduit. Never forget to set the conduits u change to set as defaults. Like this, u must have always updated data on ur hand-held, for this, u need to keep synchronizing with ur office computer. good luck,
Sep 12, 2005 | Palm Tungsten E Handheld
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Sep 11, 2005 | Palm Tungsten T3 Handheld
I have a blinking star/starburst animated graphic in the top left hand
it's an alarm Iget that a lot. tap on it. it opens an alarm. Then you can clear it. It's a feature!
Sep 11, 2005 | Palm Tungsten E Handheld
Palm Tungsten E Handheld Logo
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
