Question about Microsoft Windows XP Professional
Previous problem with Zone Alarm
Until a few weeks ago I had Zone Alarm installed, then because I was suddenly unable to access the Internet, due I was told, to Microsoft doing something that they shouldn't have done, I had to uninstall it and instal a different firewall. I preferred Zone Alarm and I wish to re-install,it but only if the previous problem has been dealt with and is unlikely to re-occur.
Please can you advise me
  • 1 more comment
  • donfox35 Sep 01, 2008
    It Is curous that you claim that my ZA was not set up properly, it certainly was - by a professional and had been peforming perfectly for 3 years until Microsoft did something daft, my concern is to ensure that it will not happen again! Can you reassre me?
    Solution #2 thewomble was the answer that I needed - (thank you) - not ginko jumping to wrong conclusions.
    For the record (and I emphasise this) my ZA was set up correctly - by a pro' - and as I know that it is not a Microsoft product I did not seek their advice and I switched to another firewall once I had taken advice from colleagues who had sffered the same problem and worked out what was happening. Hopefully this is something that Microsoft will anticipate in future.
    I shall however make further enquiries here in the UK tho' before I decide whether or not to re-install ZA.
  • donfox35 Sep 02, 2008
    Thanks ginko for the helpful info' I shall be discussing this with colleages and see where we go from there.
    The tragedy is that Microsoft can afford to be so arrogant, it is not exactly constructive for such a major industry - I can only assume that it will become worse as they go on - which they will do at their peril, they have only to look at the history of the arrogance of certain aspects British Industry and its sad consequences for us all. When they come unstuck, as thet undoubtedly will, it will be a catastrophe for them - and us!
    However, as pointed out I did not contact Microsoft at all w.r.t this, I eventually got in touch with Fixya (because a colleage who had initially contacted ZA was away on business), and it was the womble that told me what I needed to know in the first instance - that ZA had issued an update to fix the problem. As this is the case we shall see what happens next- could be good.
    Thanks again,
    donfox35
    Problem Solver:
  • 8 Answers
When microsoft did their latest update (#3) ZA didn't work correctly. ZA bought out an up-date that fixed the problem.
Posted on Sep 01, 2008
  • Microsoft Master
  • 19,396 Answers
The problem occurred because ZAwas not setup properly.
Once you do not chose to block any software that is needed for your network or for your system, the firewall won't give you any trouble.
Just ensure that you authorize all vital software full access through the firewall.
You can download Zone Alarm by clicking here then chosing 'download now'
Do not forget to vote the solution.
Many thanks,
  • 4 more comments
  • Ginko
    Ginko Sep 01, 2008
    The reason why they asked you to remove ZA and work on a different Firewall is because it is not a Microsoft product and they are not trained to solve problems or setup Zone Alarm.
    For the rest, majority of firewalls do the same things.
    Many thanks
  • Ginko
    Ginko Sep 01, 2008
    Reassure what?
    A firewall it is not something that you fix or setup once for all.
    A firewall must be adapted continuously when you change network settings or install new software.
    And sure, setting up a firewall on a personal computer is a user level operation, you need to learn how to set it up by yourself.
    I cannot see how you can keep doubting about what is told you on this simple matter.
    Why do you ask me , or Microsoft guys, if you think you know the problem already .
    The solution is all above, read also Zone Alarm help to understand what a firewall is and how it works.
    Regards.
  • Ginko
    Ginko Sep 01, 2008
    I mean a firewall keep changing its settings each time you install a new software, and ask you what to do, all you have to do is grant access to programs and devices that must be trusted, like your router or modem internet connection.
    For the rest ZA does the same thing as the built in Windows firewall, only it has a more colored and user friendly interface.
  • Ginko
    Ginko Sep 01, 2008
    Regarding it happening again, yes , it can happen at any time , if by mistake you do not grant firewall access to the component and processes necessary for your local network.
    Now that you know how to fix the problem this should not be such a big worries.
    Whenever there are network troubles, first thing to do is stopping the firewall.
    Regards
  • Ginko
    Ginko Sep 01, 2008
    Listen mate I spent 20 years working on local networks, all I can tell you is that if the update suggested has stand alone setup it will work the same as ZA installation.
    I am here to help you , not to put in discussion my knowledge or Microsoft technician competence, I am sure the guys over there know better than you, and probably someone knows better then me.
    If you need help, the worst you can do is refusing experts tip at start, you get nowhere.
  • Ginko
    Ginko Sep 01, 2008
    Regarding the problems with Microsoft operative system and its updates I wan to tell you one list thing that can be in some way enlightening.
    Everybody (me included) is annoyed with microsoft problems with other software.
    The fact is that Microsoft bulds and sells the most popular Operative System (OS).
    The OS (windows), is the basic environment on wich all software run and is installed.
    Microsoft never adapt the operative system to any other software, they do not give a toss about ZA, Adobe, Firefox, or any foreign make software. It is the software that must adapt to Windows, with a continuous work from softwarehous programmers, Microsoft just keep going on is way.
    It is Microsoft that built the little universe in which you (or Zonealarm) moves when you use your computer.
    If you noticed a problem between Windows update and ZA you must write to ZA programmers, not to uncle bill. I am sure they will appreciate.
    PS: unless your computer froze or returned an error message, your problem was still a matter of settings, due to MS Update or not. this is true, believe me or not.
    Cheers
Unable to start IE8.... and now unable to restore system (vista)
Just use Firefox, Safari, AOL, Opera or other browsers.
Jan 12, 2010 | Microsoft Internet Explorer 8
Suddenly Pandora Won't Work Anymore on the iTouch
Try removing Pandora and reinstalling it from scratch.
Jul 05, 2009 | Apple iPhone Smartphone
Cannot sign-in or change myyahoo with zone alarm extreme security
Check for Active-X and Java Controls in the Internet Options. Assure that everything is set to Prompt and then work backwards from there to increase security.
Apr 28, 2009 | Computers & Internet
Viper 791 XV Automatic Start Not Working
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Nov 17, 2008 | Viper Security and Remote Start System...
All of a sudden can't access the same sites as yesterday
Oh i see,
well, try to open your MY Computer... at the top in the address bar. try to type in the same website which is inaccessible. and then hit enter on the keyboard...
you should be able to see that page.... if yes...... your browser is hijacked!!!
Re-install it and your done
was i help ful enough?
I had the same problem, now i have none...............
how?
login to....
http://primustel.blogspot.com
Good Luck
Nov 13, 2008 | Microsoft Internet Explorer 7
No internet connection through routers (broadband AND wireless)
Try to disable any firewalls on your computer. If you already have internet details showing, there's something blocking your connection which is possibly a firewall. Turn off the Windows firewall as well as Norton, Mcafe, Zone Alarm and the like if you have one.
Nov 01, 2008 | D-Link AirPlus DI-524 Wireless Router
Windows xp
hey budy me aso treated this sort of problem in recents with some of mine clients..buddy this is a virus attack which is common now a days...mccaffe update of july season is helpful to iradicate that one for sure..n please remove the zone alarm n go for it.it will work for u.
gud lukkkkkkkk
Jul 16, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
