Question about LaCie (300770) 250 GB Hard Drive
Powering up my Lacie ethernet disk 250
When I press the blue button to switch on my Lacie ethernet disk 250, the blue light flashes and I can hear the disk clicks on. After 3 seconds the disk turns off. What can be the problem? and how can I solve it?
  • Anonymous May 26, 2009
    I had the same problem and this did the trick. Thanks for the advice. You are a lifesaver.
When I had this problem it turned out to be the power supply unit. Lacie replaced it - if you are out of warranty you can buy them for about £25 - and this solved the problem.
Posted on Oct 16, 2008
Hello. I have a LACIE EDMINI-V2 that won't start, no disk noises, no light from led in front button, nothing. I have dismantled the box, connected the disk drive to my PC and its ok, measured the 5V and...
I owned one just like this and the power supply failed at about 1 year. It turns out it's a fairly common problem. Since you have the device open, does the controlboard/motherboard look burnt at all?
If it is not damaged, you may be able to buy a replacement power supply here: http://www.lacie.com/products/range.htm?id=10030
If it is damanged, then you may still be under manufacturer warranty, contact Lacie here: 503-844-4503 sales@lacie.com
Please leave feedback for this answer, thanks.
Mar 09, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie edmini 250 GB will not power up
sounds like a faulty power circuit within the external housing. remove all screws and the drive from its housing. you now hold in your hand an internal hdd. remove all jumpers, if any are present, and install this drive on the same cable as your master hdd. now when u boot up to my computer window, you will see two hdd named C: and D:
Jul 01, 2009 | LaCie (300770) 250 GB Hard Drive
Fan keeps going, blue light always on, clicking noise
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Jun 28, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Dead hard drive
Try unplugging the usb connector and plugging it back in. Your pc shouls recognize the installed component automatically. Also, some external hard drives work like normal pc's do: hold the power button in longer until something happens. Hope this helps.
May 24, 2009 | LaCie (300770) 250 GB Hard Drive
Keep Losing Connection
try replacing the cable to it - ive notice once that is done dos not disconnect
Dec 31, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie 500gb external drive
The disks inside the HD are not spining. The creaking noise is the HD trying to start. Next time when it does start transfer all the files ASAP cause your drive is about to die.
rmatheson@wowway.com
Sep 30, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Problem with Ethernet big disk (1to)
http://www.lacie.com/support/support_manifest.htm?id=10224&guideid=10627
If the web administration can not be accessed.
The button on the front of the drive can be pressed in a specific sequence.
Switch OFF the Ethernet Disk by holding the button until it begins flashing in a pattern. Release the button, and it will shut off shortly afterward.
Press and hold the power button. After a few seconds the light should begin to blink. Release the button.
Quickly after releasing the button (within ~3 seconds), the LED will blink, but at a different rhythm. Press and hold the button again.
The light will switch to a third rhythm. Release the button. It is now using the factory-installed firmware.
Regardless of the method used, all users and shares on the system are lost. The data is still on the drive, however. To restore the data, recreate the users and shares with their original names (through the Users, and Shares tabs, respectively.)
Aug 08, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Can't restart, can't connect
Please check the smps this type of problams are coming whaen smps is not working corrctley than cheack with ram slots also please verfiy the whare the problam is check one be one
Jul 21, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie 250GB: Power (blue) light flickers when pushed, nothing happens
Sound very much like ypur disk is fried. Slim to zero chance of recovery.
Aug 26, 2017 | LaCie Big Disk (LAC300966U) 1024 GB Hard...
Hard drive won't start up at all
Knowing LaCie the drive might need to be connected to a computer, or need a new battery.  If it is not the battery, try connecting the drive to your computer via ethernet or USB  and you might be able to get the data off of it
Jan 02, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie (300770) 250 GB Hard Drive Logo
324 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
