Question about Fuji Finepix A370 Digital Camera
OPERATION JAMMED. THE MESSAGE ZOOM ERROR COMES UP ON THE SCREEN AND THE ZOOM DOES NOT WORK .NO PHOTYOGRAPH CAN BE TAKEN AND THE CAMERA IS STUCK IN FULL ZOOM.
    Genius:
  • 1,239 Answers
Hi..
sir please restore the factory setting,s.. if i is not in the warrenty preiod..
Posted on Sep 01, 2008
  • ABHISHEK.C
    ABHISHEK.C Sep 06, 2008
    THANK U SIR..
    HAVE A NICE DAY.
Camera zoom does not work
that is an error condition on the lens
take it back its jammed
Apr 19, 2014 | Fuji Film FinePix JX500 14 Megapixel...
I've bought a new samsung pl121 camera & taken a
Your camera is obviously defective. It may have been a return and resold to you. In any case, you should return it immediately....this problem will only get worse.
Aug 20, 2011 | Samsung Cameras
The zoom did not operate normally insert the battery again and turn the camera on. if the camera does not op normally do not put excessive pressure on it and contact the service center i got this error...
The solution is very simple.
you are going to remove the battery (while this screen is on) as the command screen tells.
And your camera should function properly.
I tried it and it worked.
NB; Do not try to close your camera then remove the battery.
Remove it while the camera is still on.
Jun 04, 2011 | Samsung ES30 Digital Camera
We have a message coming up saying "zoom error"
If the camera was operating properly before the zoom error then the most common problem to a stuck lens is dirt getting stuck between the two lens barrels. There are a few fixes for this none are guaranteed to solve the problem and should not be attempted if the camera is under any type of warranty. They include removing the batteries for a few minutes, reinstalling the batteries with fresh once with full power, turn the camera on while holding the the zoom button. Another method is to see if you can provide extra power to the focus motor by having the LCD screen turned off. There my be a button that allows you to switch from the viewfinder to the LCD screen switch to the viewfinder and try several times to focus (just point the camera at different distant objects) and attempt to focus the camera. I hope this gives you the results you need because the other suggestions may further damage the camera and are only a (last resort) thing. One is with the camera turned on tap the body on a counter or table edge while trying to zoom the lens obviously in the opposite direction to where it's stuck. The last is to gently push the lens in with the palm of you hand while zooming in. All these are just suggestions and carry no guarantee of working and may further damage the camera. The biggest cause of this problem is dust from a camera bag or some other environmental condition like sand from a beach.
Jan 24, 2011 | Fuji FinePix S1000FD Digital Camera
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
I have a fuji finepix S1000FD camera and it wont function. The screen has gone blue and there is a message saying zoom error. Have taken batteries out and left for a while ... tried this a few times,...
will the lens move in and out as normal? or is it stuck?
If it will move then the internal lens assembly has a problem.
If it won't move then that is causing the problem.
Will require internal inspection by someone who knows cameras
Dec 11, 2009 | Fuji FinePix S1000FD Digital Camera
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Mar 28, 2009 | Fuji FinePix S1000FD Digital Camera
A500 Zoom Error
Your lens assembly has become jammed due to impact or contamination. You can try GENTLY manipulating the extended lens using slight side to side pressure and twisting motions back and forth. Sometimes this will free a component which has jammed out of alignment. Be VERY careful you can easily damage the lens further if you do not use extreme caution. If this method is going to work it will take minimal force to free the components. If this does not work you will need to find a service center to take the camera apart and re-set the internal components in the proper alignment. David Millier Advance Camera Repair
Feb 24, 2007 | Fuji FinePix A500 Digital Camera
Fuji Finepix A370 Digital Camera Logo
164 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
