Thanks to you all. I tried to boot after discharging the bettery. It worked.
Have u Reset ur bios ?
if display not come yet
then u have to remove ur mother board outside from cabinet
& remove all connection {because sometime board getting short ground}
only connect ram, processor & fan ,smps
& recheck give the power it will work or take new ram & check it best of luck
regards,
Ashu
Onboard video or a pci card and and what is the brand and model of the monitor
Robert
Remove the ram & reinstall it again
I have removed the RAM and reinstalled it multiple times, but in vain.
The display screen is blank.
I have the Same Problem; No Display
I have Intel D102GGC2
Intel Pentium D 3.02 Ghz
Corsair 1Gb DDR2
Seagate 160GB Sata
NO CDROM, FLOPPY, PCI CARD OR PCI-X Card
My computer was running fine, I usually use it to use Internet and do my work (Photoshop CS3 and Visual Studio
2005)
A few weeks back I booted my computer and it showed that "NO BOOTABLE DEVICE ATTACHED" I just plugged the Hard
disk cables out and then pluggd them back in which solved the problem, then after that day I have had the same
problem of NO BOOTABLE DEVICE ATTACHED 5 times. Last night I turned my computer on, had to download a file
through torrent, so I just started the download and went to watch TV, when I returned aftr hours (The file was
of 1GB and I have a slow connection) to see how much progress has been made and I was SHOCKED to see that the
screen was rubbish, there were colour lines everywhere and I could not see anything clearly on the monitor
screen, I just pressed the restart switch, it restarted and ran fine, but after 5 minutes the dreaded Blue
Screen appeared (it was also not displayed correctly) I mean it is the blue screen but there were red lines all
over the screen and it seemed like some DISPLAY problem. I then turned off the computer. After a while I
powered it on and there was NO DISPLAY and NO BEEP. The power light was on but the hard disk light was blinking
at a rate of once in one second.
I dis-assembled the whole computer, took everything out, cleaned it and assembled it back again and walla, the
computer worked fine but only for 15 minutes and again the Blue Screen with RED LINES came.
Now I am stuck with it, I cannot understand what is wrong with it, the hard disk is running (Spinning), All fans (I have two fans one on the casing and one is of processor), The restart button does not seem to work and after pressing the power button it seems that the computer turns on but there is no display, PLease hel me.
Thanks for any help in advance.
P.S. The monitor is fine
what does show up on the screen... or is the screen blank ?
Robert
