Question about Cell Phones
Conect bluetooth headset
I cant seem to be able to connect my sagem blue-tooth headset h2 which i got free with my sagem 511x i cant connect it to the phone or my ps3
please help
  • 69 Answers
SOURCE: Connect trueblue bluetooth headset to Samsung Eternity cell phone
hold your finger on the call button on your blutooth device for around 6-10 seconds, this should make a couple of lights flash, when it does this it is active and ready to pair uo, then search, it will ask you for a code, usually they are generic and are prob the following 1234-12345-1111-11111-0000-00000-5555-55555 eiter one of these should work
Posted on Jan 01, 2009
SOURCE: Nexus bluetooth lost code to pair with new phone
Posted on Apr 23, 2009
SOURCE: passcode for hands free parrot bluetooth device
For the Parrot Minikit- that attaches to the visor. The default is 1234
Posted on May 28, 2009
SOURCE: bluetooth conection
Make sure You have a Bluetooth device on your laptop[of course that is necessary].Now i recommend you to use WIDCOM bluetooth software.It is theeee best for bluetooth device handling.
Also make sure that the bluetooth device on your samsung blackjack is working.That can be done by asking your friend having a bluetooth enable phone to search for your mobile via bluetooth,be sure you turn on your bluetooth device on your mobile and make it visible to others.
Make sure after intalling the software (WIDCOM) the drivers are successfully intalled.Then pair it with your mobile.So simple isn't it
Please rate me my name is Karatela
Posted on Dec 05, 2007
  • 2427 Answers
you have to activate blue tooth connectivity on your phone
Posted on Dec 31, 2007
How can I conect to my HTC wildfire when searching my phone cant find my plantronics Many thanks
You have to put your blue tooth device into discovery mode,Most blue tooth manufactures use the power button by holding it down for 6 to 10 seconds when turning the device on,then when you are searching they will pair ,now you will be asked for a pin or pairing code.Most blue tooth device manufactures use a factory pin pairing code they are as follows 0000,1234,1111,or 9999 i hope this helps
Feb 19, 2011 | Plantronics Explorer 230 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Conect my blue ant blue tooth to my phone
hi i am giving a website which will provide you the details how to connect your bluetooth headset to your mobile
Dec 17, 2010 | Parrot Ck3400ls Bluetooth Lcd Car Kit With...
I need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
Jul 12, 2008 | Motorola Mobility Bluetooth Hands Free...
Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
Jul 01, 2008 | Motorola Mobility HS850 Consumer Headset
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone. will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Bluetooth Pairing
the pin code reuired is the one set up by your bluetooth headset manufacturer. Check your user manual for the headset for the correct code to use.
Nov 11, 2007 | Motorola Mobility RAZR V3
Blue tooth
Most phones that support bluetooth have a "headset" or "hands-free" profile that the device must be in for the bluetooth headset to work. Can you confirm that your device is in this profile?
Jun 06, 2007 | Motorola Mobility PC850 Wireless Bluetooth...
Cell Phones Logo
51 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
