Question about Ricoh Aficio 450 Copier
The 391 code problem
The copier brings this code after a few copies are made and you have to restart the copier again,its messing up alot please someone advice on what to do.
  • Ricoh Master
  • 2,794 Answers
SC 391 is image storage address error. Development BIAS leak. Charge AC output error.
Should be checked out by a technician. It could be a few things going on with it.
Posted on Sep 01, 2008
Error code e000007-0000
Try cleaning it or your ink is out. I know someone who had this problem. He said it was a pain to clean the nozzles on the printer not the ink jet.
Nov 11, 2014 | Office Equipment & Supplies
Minolta Di3510 cannot make copies error code Co500
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
Jul 30, 2012 | Minolta Di3510f Bizhub Copier
Hi iheanyippaul,
I see you concern, I believe you will need to check your toner if it is placed properly inside the machine seems that it is not locked/latched in its place to be able to print properly reason why you get a blank paper and black dust when printing.
Remove the Toner and re insert it again making sure the toner is set properly inside and also make sure the correct toner cartridge is installed, an incorrect or incompatible toner can cause issue of not getting to print anything on the paper or possibly not fit inside the machine correctly.
I hope this helps.
Have a nice day,
Jul 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
Hi I wanted to reset my account it is called Ronniedonny i wanted to reset it because my little sister accident pressed the wrong kingdom i wanted and messed up alot of other things but now i have a code...
My little brother played with my account and sold and bought a lot of the wrong things for my kingdom and now it is all messed up and i can't do anything about it because it says it has been disabled. Can someone please help and thank you for your assistance.
Feb 07, 2011 | A Thinking Ape Kingdoms at War
Error Code: 39,003.40:133671 Yesterday the copier/scanner would not work. I shut the printer down and restarted it and received the above error code. I shut the printer down again and restarted it and...
this is a scanner problem that can be associated with the scanner lock under the scanner bed. make sure the lock is in the 'unlocked' position. it is easy to move this when lifting the scanner bed to reload the ink blocks. if this does not solve the problem you may have to replace the scanner assembly. hope this helps.
Aug 19, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Sharp AR-M550U get error code:F2-31
F2-31 is related to the image process control for the drum. The drum sirface is read by the image density sensor - if it has a problem doing so then it will give this code. Possible causes could be a bad/old/worn drum or the drum is not being cleaned properly by the drum blade. To run the processor control adjustment do the following : press the "P" key then "*" key then "C" key then "*" key again. this will bring you into service mode. (warning : please do not make any other adjustments in this mode as you can do some serious damage to your copier). then type 44 and press start key then 2 and start key again. Once it is finished running restart the copier. If this fails you need to look at the drum and possibly change it.
Feb 06, 2010 | Sharp AR-M550U Copier
H400 error
it is problem heater unite
reset code is
C photo C photo press 14 by copy quantity key press printkey then show 01 or other code press up & down key 00 press print key
Jul 27, 2009 | Sharp AR-168S Copier
Stops printing
try cleaning the connectors to the chips of your toner, transfer unit.
Apr 11, 2007 | Minolta magicolor 2200 DeskLaser Printer
Ricoh Aficio 450 Copier Logo
487 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
