Hardware & Accessories Logo
Posted on Jul 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to wire a ceiling lamp but the lamp connection has 2 wires: a brown and a blue and the electricl fixture in the ceiling has 3 wires...how do I connect them?
Anonymous
Level 2:
Habit-Forming:
  • Expert 102 Answers
  • Posted on Jul 31, 2011
Anonymous
Expert
Level 2:
Habit-Forming:
Answers
102
Questions
Helped
22494
Points
197
The other wire is for the ground of it,usually the color of the ground is green..You will connect to two wires for the supply for ceiling lamp.Any of those wires except for the ground.
1helpful
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
I am trying to install a ceiling fan and from the ceiling I have a copper white and black wire. Now from the fan itself there is a black blue and white wire. Not sure where to connect the copper wire.
Good question, proper wiring is a crucial virtue that needs to be one hundred percent accurate.
Three wires showing from the ceiling lamp fixture harness, positive, negative, and ground.
The negative wire is the white wire,
The Hot wire (positive) is the wire of brighter color than known negative,
220V AC (alternating current) home wiring to(" duplex outlet switch, GFI switch, single/dual pole light switch, lamp fixtures,") the Hot wire or lead, is normally Black, the lighter color, or White is neutral or neggative,
Neutral wire (completes circuit) allows current flow to continue through to other parts of house, Alternating current.
The Ground wire is usually wrapped in green color, or unmarked copper.
The copper wire from the ceiling will need to be grounded to the metal bracket on the new light fixture, a gold or silver screw, sometimes tagged with green, is the proper grounding location, Any place on Metal not attached to ceiling bracket, Ground should be attached to metal on fan,
White wire from Fan is neutral, Negative.
Black wire from Fan is Hot Wire, Positive,
If Blue wire from Fan is Not Manufacture spliced, Meaning no Copper is exposed, Wire is not used, Blue wire is NOT ground,
If Fan has a light, Voltage from Hot Black wire will supply both light and fan functions,
Safety First.
flip off breaker switch to the room fan is being installed.
Doubble Check
Black^Black wire connection is secure.
White^White neutral wire connection is secure.
Ground is fastened securely to metal or wrapped under a screw.
Using splice caps is recomended, The plastic shell encloses the wire connection ensuring No stray copper is exposed, limits possibility of cross wiring.
Google the brand of fan being installed, and Check wire color code, and wiring diagram, Info good to have, and checking twice will only guarantee Lamp Fixture Install Well Done.
(Blue wire may be there for installing multiple ceiling fixtures in a loop circuit, so all controlled by same light switch.)
Enjoy Your New Fan,
Jos
Thoughts&Comments, encouraged [email protected]
Mar 26, 2017 • Dryers
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
1helpful
2answers
I need a diagram to install a Westinghouse 3-way light switch (#77052) on a lighting fixture on the bottom of a ceiling fan. I did not do the removal of the light fixture so I don't know how it was wired...
If by a 3-way switch, you mean a switch with 4 steps of brilliance: off, low, medium, and high when used with a 3-way bulb. The black wire of the switch is connected to incoming power wiring hot wire. Most often also black. The red switch wire connects to the center contact of the lamp socket. The blue wire connects to the small pin connection that is physically between the center connection and the screw shell of the lamp socket. The screw shell is connected to the incoming white wire of the house wiring.
6helpful
Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
Chain to light does not work
Most paddle fans that come with a light kit (or provisions to add one via plug / jack later) provide at least 3 wires (most times 4 though) that will need to be connected to the house wiring. Those wires are:
1) Green, or Green with a Yellow stripe - this is the grounding wire and is connected to the grounded metal junction box or other ground wires.
2)White - this is the neutral wire and is connected to both the fan motor and light fixture.
3)Black - this wire connects to the fan motor. This wire along with the white wire completes a circuit for the fan.
4)Blue - this wire connects to the light fixture. This wire along with the white wire complete a circuit for the light fixture.
Ideally, the junction box in the ceiling has a neutral, ground and both an unswitched power source *and* a switched power source. An unswitched source is always on (regardless of any switch's position) while the switched source is controlled by one or more switch(es) near a door(s). Use a meter or tester to determine which wires are switched (probably black or red) and unswitched (probably black but may be red, too). Label them or orient them in such a way that you'll remember which is which. Turn the power off.
Connect the paddle fan's blue wire to the switched wire, the black wire to the unswitched wire(s), the white wire to the other neutral (most likely white wire(s) and finally, the ground wire to the rest of the ground wire(s). Turn power back on.
Wiring in this way allows the light fixture to be controlled by the wall switch(es) and the fan by the pull chain on the fixture. Turn the wall switch on and pull the chain until the light turns on. You can remove the long chain once the switch turns the light on and off so it is not accidentally shut off at the paddle fan later. Change the fan speed from high to low and eventually off with the chain.
If you only have a switched or unswitched power source in the ceiling, you'll have to connect both the black and blue paddle fan wires to whichever type power you have in the ceiling (switched or unswitched). If you're using a switched sourced, that switch will have to be left on in order for the fan or light to work.
If you have wired in any of these methods already, it could be that the switch for the fixture has failed, and should be replaced with a like-type switch.
I hope this helps!
Leviton Dimmer Switch wiring and ceiling wiring for new kitchen table light fixture
I recently purchased a Leviton Dimmer switch which has a brown lead. This switch is to replace 1 of 2, 3 way switches that control the ceiling light in my kitchen. My problem is the new dimmer switch has 4 leads including a brown one which has me confused. I have installed and replaced numerous dimmer switches without difficulty. Please help.
Ceiling fan wires
is the old fixture still installed?
1helpful
Hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
