Question about Toshiba Satellite Pro 490CDT Notebook
Won't turn on
I plug in the laptop and the light indicates that it is plugged in and the battery is charging. But when I try to turn it on, the battery light turns off and the light showing it is plugged in turns orange and starts blinking. I took out the battery but it still does the same thing. Any suggestions?
I plugged in the laptop and let it charge for an hour, and then it worked fine. I guess the battery was too low or something.
Posted on Sep 02, 2008
My coolpix L810 won't turn on. Green light comes on but goes out. Can't see screen. Lense was frozen but plugged into computer and closed.
have the battery full charge? sometime the battery is not charged although the charging indicator is full charge, maybe the battery is shorted out.
May 04, 2013 | Nikon COOLPIX L810
When I put it on the charger it indicates that it is charging but when I take it off it won't turn on at all.
Hello! Does it turn on when you have the charger plugged in? If so, you have a dead battery. The laptop maybe indicate that battery is charging, but if she is dead, it won't give you enough power to turn on. Try that!
If it works with a charger on, you need to replace the battery. Need any more help?
Apr 03, 2013 | Computers & Internet
Dell latitude won't charge
The internal battery may need replacement, especially if you have had this Notebook for several years
Mar 22, 2013 | Dell Latitude D600 Notebook
My laptop not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
PLEASE HELP!! I am going on a business trip tomorrow and ALL of my requisite files are on my Dell Latitude D610 that won't power on. PROBLEM: once I removed it from my docking station at work, it won't...
When you say you "tried turning it on with the battery removed", did you leave it plugged into the wall with the charging adapter at the time? Please clarify that you tried to use it while plugged in without the battery and it would not power up? When you plugged it in without the battery, was the green charging light on? Or did you get no power light at all?
With your battery in, try using a different outlet to plug into. Plug it into another outlet and when the green charging light comes on press and hold your power button on your keyboard and do not release it for 30 to 45 seconds. Tell me if this boots up the pc even if just for a moment?
There are three lights on your keyboard that should come on when the laptop is plugged in and turned on. One is the power light, the other is the battery charging light and the last one is the hard drive indicator that looks like a round cylinder on the picture. Tell me when you plug it into the outlet and the battery charge light is on, does the hard drive light come on and/or flicker when you try to power up the laptop? How many lights come on when you press and hold down the power button with the cord plugged into the wall?
Jan 09, 2011 | Dell Latitude D610 Notebook
Won't turn on. Battery is plugged in and lit. n
Try removing your battery pack. Then connect the power adaptor (even without the battery) and connect is directly to the power outlet. If it powers up, then the battery pack might be defective or totally drained.
If the battery is just totally drained, simply place the battery to the laptop. Do not turn the laptop on. Plug the power adaptor to the laptop and plug it to the power source. If you see that the charging LED is blinking in your laptop, then just leave it charging up to 5 to 8 hours.
Never use a laptop on battery mode while it is plugged in to a power source. This is the number 1 reason why laptop batteries don't last longer.
Jun 06, 2010 | Sony VAIO Notebook
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
I have a toshiba laptop, and in the last few weeks something weird started happening. When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries,...
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Jan 04, 2009 | Computers & Internet
Toshiba Satellite Pro 490CDT Notebook Logo
213 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
