Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Lots of problems, repair or replace?
my printer has many problems. the document feeder doesnt feed, all my print outs have solid black lines on them (this isnt ink residue), it wont print documents horizontally......is it repairable (if so-where?) or does it need to be replaced?
    President:
  • 2,072 Answers
I would honestly replace it. The machine is not overly updatable, there will be no new firmware or drivers in the future for it.
What you are explaining would cose several hundred dollars with parts and labor.
You can go onto Xerox and look up a dealer in your area for service. But figure on starting at $75 for the call, plus some aditional time. And most likely, just thinking normal maintenance parts, I would guess $200 to $300 for parts.
Posted on Sep 01, 2008
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
My lexmark x544 gets a black line down the page when i put it in the tray feeder. What do I do?
Is the black mark in the same place on all print outs? If so, it could be that the paper feed rolls may be dirty.
Oct 16, 2014 | Lexmark X544dn All-In-One Laser Printer
Printed copy will not feed out line by line and finally will not feed the printed page. How to get it to work properly?
There could be something blocking the paper path that's not allowing the paper to not go all the way through the feeder. Try to open the printer and access the cartridge area. Remove the cartridges. Check for any foreign objects blocking the paper path. Rebrick your printer by removing the power adapter (black box found on the back of your printer where the power cord is plugged in) and then re-plug after 30 seconds. When your printer turns back on, re-insert your cartridges. Then try print your document again to verify that the problem is fixed.
Nov 10, 2011 | Lexmark X73 All-In-One InkJet Printer
I have a Canon MP730 and it has always worked great - until. I ran out of black ink and replaced tank. Tried to align the print head, but none of the black samples are even close to being a solid color -...
Hi There,
I believe that the printer head which feeds the ink dried out and clogged at the ink dispersal point. I'd suggest you take it to your nearest printer service capable repair center and just have them unblick the clog.
Regards,
Selk
Mar 25, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Copies are being printed with a line vertically down the side of the page. Only happens when copying using the hopper.
If it's a thin, sharp line, it's just a blob of ball-point pen ink on the scanner glass. Lift the lid, and you'll see the narrow strip of glass that the scanner uses when you feed a document through the feeder. Clean that with a rag dampened with window cleaner, or, better yet, alcohol. Even a dot of ink too small to see will show as a solid black line on anything you copy, scan, or fax via the doc. feeder.
Don't use so much cleaner that it runs under the glass.
Nov 10, 2010 | Brother MFC 7420 All-In-One Laser Printer
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Ricoh C21SF Automatic Document Feeder (ADF)
Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
http://www.websitetoolbox.com/mb/copierquestions
Sep 25, 2008 | Ricoh Aficio SP-C210SF Printer
Automatic feed
Try these parts  FM2-0015-000 and  FC5-0009-000 and FL2-0006-000 (roller and sep pad).  They're not real easy to replace.  It would be a lot easier to replace the whole feeder unit.
Oct 19, 2007 | Canon imageCLASS D780 All-In-One Laser...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
50 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
