Question about Canon FAX-JX200
Refilled cartridge how can i reset the fax in order to be able to use refilled cartridges? the fax is stand alone, is not connected to a computer, is there an option to do this from the fax machine? thanks in advance!
  • 1 more comment
  • Meeka_4561 Sep 01, 2008
    I am not sure how to connect my ansering machine
  • documentor Mar 07, 2009
    The refilled cartridge gives the message "ink volume unknown" and the
    fax machine refuses to work. Is there any way to overcome this?
  • cristian1968 May 07, 2009
    I reffil the cartridge and I see this "ink vol unknown"
    Help pls
  • 37 Answers
Press stop for 5 sec after changing the cartridge
Posted on May 23, 2009
How can i reset the fax in order to be able to use refilled cartridges
Posted on Dec 02, 2008
Printer has operated troublefree in the past. Now the wireless con nection is off and will not reset.
Have you tried this?:
Touch Settings - Tools - Restore Factory Defaults
Aug 02, 2014 | HP Officejet Pro 8600
Had the cartridge filled instead of buying a new one. I was told at costco that the printer sometimes shows low ink when it's filled to check the manual there is an option that needs to be changed. I...
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed
Another thing which is mentioned at their support site is quote:
If you have refilled the cartridges you got along with the printer, you can't reset them. 23 and 24 are not meant to be refilled. They are what Lexmark call "return program cartridges"- they can't be refilled, you can send them back to Lexmark ( that's why they are called "return cartridges"). You need to buy either 23A and 24A or 34 and 35, those cartridges are refillable.
Here is a link to Lexmark, with a list of cartridge compatibility for your printer:
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=x3550
If you find my answer helpful, please vote. Thank you!
Nov 16, 2010 | Lexmark X8350 All-In-One InkJet Printer
I have installed a refillid cartridge into Samsung fax machine SF-375TP and I get message"Install ink cartridge".What must I do in order to get machine to start working again?
Many cartridges DO NOT respond well to being refilled, and if you don't use a manufacturers ink cartridge. And if you don't you will get that message.
Sometimes you can reset the "Chip" in the cartridge, yes, there is one in there too, especially so it cannot be refilled by a third party,
There is NO simple way around this, "They" want you to buy NEW inks each time, and NOT refill, it sux huh?
www.crowson-ward.co.uk/media/pdf/Samsung%20SF375TP.pdf
Manual above.
www.futuregraphicsllc.com/lit/instructions/CLPCRSTECH_ud.pdf
Above is a link on resetting the cartridge.
Aug 04, 2010 | Samsung Office Equipment & Supplies
I am using refills and my printer won't
Your printer will always think that refills for this cartridge are "empty" because there is no way to reset the ink levels on this type of cartridge. However, if the cartridge is not working you should be able to get a replacement from the refiller you purchased from. There are a few scenarios as to why the cartridge would print in his test printer and not yours. If they printed test pages from a stand alone printer, this does not make sure the electronics are functioning on your cartridge. If they used a test printer (CT-16, shoptester, etc..) it may be that the TSR is out on your cartridge.
Sep 29, 2009 | HP DeskJet F4180 Inkjet Color All-In-One...
Trying to get my fax printer to work
Do a google search for this product. I found the specs on this machine. hp fax 1010. In the specifications it does not have print option.
looks like this machine is a stand alone fax and can be used as a copier. I do not believe that it can be connected to your computer.
Jun 02, 2009 | HP 1010 Plain Paper Inkjet Fax
No automated fax receiving with refilled cartridge
You need to reset the chip on the cartridge for it to work properly.
Mar 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer will not recognize a refilled cartridge
this is a bit hard because.....what model is your printer? Is your printer hooked up to a computer or stand alone? Usually you can press and hold the cancel button for around 10sec or until is clears and this will let the printer use a refilled cartridge but you will not be able to moniter the ink levels.. the printer will remember that the cartridge you are trying to use is empty already but you can continue printing until the printing becomes faded and then you know you need to refill.
Jan 28, 2009 | Canon Pixma MP450 All-In-One InkJet...
Refilled ink
Try checking under maintenance or ink settings, sometimes if the cartridges have been refilled they are not reset correctly and the ink level checking fails to work. There is sometimes and option to ignore these for refilled or compatible cartridges.
Control Panel
--> Printers and Faxes
--> Right Click on the Printer ICON and select Properties
--> Look for a "Maintenance" or "Tools" Tab across the top click one
--> Look for an option for "In" or "Ink Settings"
and click on one of these options to run
If you cannot find that then Try going into Control Panel
--> Right Clicking on your printer
--> Look for an option for "Cleaning" or "Deep Cleaning"
Jan 25, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
X5470 Lexmark printer
i refilled my lexmark 24 color cartrgide but now the printer does not want to read the cartridge, any help on resetting the thing before i chuck it trew the window
Nov 12, 2007 | Lexmark X5470 All-In-One InkJet Printer
Canon FAX-JX200 Logo
1,467 people viewed this question
old marine
old marine
