Question about Dell 1700n Laser Printer
Light blinking I have Dell 1700n laser printer, when I connect to power don't work and all lights flashing. please , tell me about the soulution
  • 2 more comments
  • smarie29 Sep 01, 2008
    after that what i will do
  • rshoe Oct 08, 2008
    I have the same problem...when I press the continue button twice, I get the load/remove paper light and error lights flashing
  • wayne churchill May 11, 2010
    When you press the continue button twice i need to know what lights are still on/flashing
    All flashing lights indicatea service error, you need to press the continue button twice to get the secondary code, with that i should be able to tell you what the problem is.
  • 300 Answers
The Controller card is faulty
Posted on Sep 18, 2008
I have the same problem and will give the answer: I've pressed the continue button twice, and now there are two flashing lights: the "load/remove paper" and the "Error". Thank you for helping me/us!
All of the lights are flashing on my Dell 1700 printer
Try to rest your printer by doing the following...
Trun the power off and then unplug the power cord from the back of the printer. Leave it unplugged for about 45 seconds or so and then plug it back in. Turn the power on and you should be back to normal
Nov 13, 2010 | Dell 1700n Laser Printer
My Dell 1720 copies tells me it has stopped because the photoconductor kit has stopped working. I just replaced everything and keep getting the same error.
If the drum cartridge has not been replaced, it must be replaced before resetting the counter to avoid damaging the printer.
  1. Power off the printer.
  2. Open the front door.
  3. With the front door open, hold down the Continue button while powering on the printer.
  4. Keep holding continue until all lights start flashing then release the button.
  5. Once only the Error light is on, close the front door.
  6. At this point Continue, Ready/Data, Toner Low, and Load Paper should all be lit.
If the previous set of steps did not go as described then do not continue. Please complete the previous set of steps again.
  1. Wait for the printer to make a sound as though it is about to print something. (This may take a minute.)
  2. Press Cancel 4 times SLOWLY (1 second between presses) to cycle through lights until ONLY the Toner Low light is on. (It may take more than 4 presses.)
  3. Press and hold Continue until all the lights cycle through and go back to Toner Low
  4. Cycle power on the printer.
  5. Press and release the Continue button to print out the settings page. Under Cartridge Information it should read Photoconductor: 0K
Aug 04, 2010 | Dell 1700n Laser Printer
We have a Dell 1700 at our office and the drum light is flashing and the page prints out stating the photoconductor kit is at the end of its useful life - so we ordered a new one. We received and installed...
There is nothing on the photoconductor unit to 'tell' the printer that it is new, you have to do this yourself, by following the photocinductor reset procedure (it's in the manual, or
Dell 1700
RESETTING DRUM PAGE COUNTER
1) Leave the power on, insert toner cartridge, and leave door open
2) Press the cancel button and hold till the leds flash
3) Release cancel button and close toner cartridge door
May 12, 2010 | Dell 1700n Laser Printer
HP 1700n laser printer. Won't reset.
Hi, first; lets’ start from scratch. Turn off your (Computer), turn off the (Printer), unplug the printer from the power outlet; do not make any changes to the computer. Disconnect (all) the printer cables from the computer; reconnect the cables to the computer, and plug in to power outlet. Turn on the computer (first), turn on the printer. Go to; Control Panel, (Hardware and Sound), click Printer; if the Printer is present; click to open, Properties, click (Drivers): Update Drivers. Restart computer. Thanks paul7of9
Jan 12, 2010 | Dell 1700n Laser Printer
Dell 1700n error light after print job.
double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
May 11, 2009 | Dell 1700n Laser Printer
Error light stays on
Clear the Error Log: a. Turn the printer off. b. Open the front cover. c. Hold down both buttons while powering on. d. Release the buttons when the error light stays on solid. e. Close the front cover.
Mar 20, 2009 | Dell 1700n Laser Printer
Dell 1700n Ready/Data light blinking (secondary fault)
Ok, try this--1.power off printer 2. open front door 3. press and hold continue and cancel buttons 4. power back on 5. wait until light sequence stops om error 6. power off and back on.
this resets factory defaults on the printer..
Nov 11, 2008 | Dell 1700n Laser Printer
DELL Laser printer 1700/1700n
All flashing lights for the Dell 1700 series (1700, 1710, 1720 including those that have n or dn as part of the model) printers is a service related error. When double pressing the continue button twice quickly, the printer will give a secondary error code, narrowing down the printer part being effected. It is possible to even narrow the error code down even futher by double pressing the continue button and taking note of which combination of lights come on, wether they are steady or blinking. Most generally when this series of printers, when you get all flashing lights, something major is going on with the printer. It could be pointing to the fuser, or main board, etc. You can call dell warranty support and they will help narrow down which part is being effected. Most generally, what is being effected is not cost effective to get fixed if you are no longer under warranty.
Sep 18, 2008 | Dell 1700n Laser Printer
My dell 1700n Laser Printer Paper Jam Light stays on
The sensor is stuck open or closed. It needs to move back and forth between the sensor. Check the paper path for the sensors.
Aug 29, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Logo
426 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
