Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Water will not drain from the top drawer of my F&P SS
Hello
Sorry don't know the model number ~ only 18 months old) No error codes come up, let's you complete the cycle as if has emptied but water is still sitting in the basin of the drawer.
Please advise
  • donsie Sep 01, 2008
    Yes ~ filter is unblocked, Have taken the trays and racks out and lifted up the turn arm at the bottom.
  • 78 Answers
Have you unblocked your filter?
Posted on Sep 01, 2008
  • Klutch Davis
    Klutch Davis Sep 01, 2008
    the pump itself then is probably the problem. basically water falls to the bottom then goes through a corse filter, down a little hose/pipe to a fine filter then the pump pushes the water out through the hose you have going to your drain etc. check these places and hopefully you can find your problem.
FF error code - fills up & won't drain
sorry but we have the same problem that the sears repairman had no model number gives us no choices . suggest you buy a new machine, but not Sears brand as they seem to be going out of business world wide
Oct 26, 2017 | Kenmore Washing Machines
There is water left in the fisher paykel dishdrawer after cycle. it is a single drawer. it is not displaying an error. how do we get the water out?
I need to know which model you have, so I can walk you through this. Or close drawer, push start, the unit will drain first, when done draining, push stop or pause before filling starts, then power to shut down. This will get rid of the water only. I would check the drain hose and all drain sources for obstructions, this unit has a time drain and if obstructed, it will leave water in the unit. Is this a double drawer? Is the problem only seen in one drawer (lower), need model number to unit stand what problem you may have.
Good Luck
Aug 21, 2011 | Dishwashers
I have a Kitchen Aid 2 drawer dishwasher and its about 2 years old. My problem is the top drawer will not drain during wash cycle. The bottom drawer drains fine. model number KUDD03DTSS 10
You may have clogged pump to the drawer. open drawer, lay on your back under the dish drawer, removed the black cover (3 screws) remove 2 screws to the pump and allow the water to drain out into a bucket or bowl. make sure the pump can turn easy. Reassemble and test unit again. If fails, replace pump.
Pump
I hope this helps, good luck
Aug 14, 2011 | Dishwashers
Fisher & paykel fault "F1" is displayed on the top
hello
F1 means the flood sensor senses water at base of machine at PC board.
You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
good luck
Jul 27, 2011 | Fisher and Paykel 23 in. DD603H SS...
I HAVE A TWIN DRAWER MACHINE ABOUT 5 YEARS OLD THE TOP DRAWER IS WASHING DISHES BUT LEAVING WATER IN THE BOTTOM OF THE DRAWER WHICH I AM NOW HAVING TO EMPTY MANUALLY HOW CAN I FIX THIS PROBLEM
Have you tried running the rinse cycle to check if the water drains out?
If you are not getting any fault codes, then it might be simply a matter of cleaning the base filter plate and the sump. The user manual will tell you how to do this.
If that does not help then post a comment along with the model number of your fisher and paykel double drawer unit and I will suggest further diagnostics.
Jan 29, 2010 | Fisher and Paykel Dishwashers
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
After 2 minutes top washer blinks. Water does not drain
When I opened the top drawer the water seems to be accumulating in the drawer and no water is draining. The drain tube appears normal and not kinked in any way.
Jan 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Jun 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Maytag Neptune Front Loader - E2 error code
The first time my E2 code came on the washer won't rinse or spin. I checked the drain pump to make sure it was working. (1) Take the back off and pull the two drain lines off pump. Be careful the line going to the drain has a backflow flap, make sure you don't tear it.
(2) On the other side where it drains from the washer to the pump is where I found a bobbie pin that had collected lint and was blocking the drain flow.
When it can't drain the E2 code comes on to let you know it won't rinse or spin.
Make sure to unplug machine before removing back,
Hope this helps everybody with E2 problems.
stude
40stude@bellsouth.net
Nov 29, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
173 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
