Tray' promble,incomplete printing
Hi!
I posted a probles earlier saying my printer is double printing the pages then u said it might be a trays' problem so what you think it might be a problem about the tray? again it cant print the whole document of more than one page it will need me to press enter after one or two copies untill the whole document is printed.
Solution please
  • ksthabi Sep 03, 2008
    Hi!
    Model: HP color laserjet 2840
    I am not sure with the letter setting, you know i am just a user who only acquiring the knowledge
  • William VITULLO May 11, 2010
    I was wrong, it isn't a problem with the tray.
    The problem might be elsewhere.
    Can you tell me again what is your printer model ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
Are you sure it is set for LETTER, sounds like you have Letter size paper in the tray but the setting might be different
Posted on Sep 02, 2008
Hi how do you print double sided please
This printer does not have a duplex unit and cannot print double sided prints automatically.
The only way to print double sided is to print page 1 and the insert the page back into the printer tray with the page upside down and then print page 2. Repeat this for the other pages.
You need to do a test print first to work out which way to insert the page upside down in the printer paper tray so the printed text is aligned correctly on both sides of the page.
Nov 29, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Prints one page double sided, then goes to error light and stops printing
what is the error ?
does it says Paper jam, Open the print cover and remove paper jam..
If this the error repeating then make sure,
1. u r not overfilling the paper tray
2. put the printer on a hard surface (not on a half out surface)
3. from now on be gentle with the paper tray.
4. unplug the printer everytime u r done or atleast overnight.
thanks
Jul 30, 2010 | HP LaserJet 1320 Printer
Im trying to print a document in word thats about 200 pages and i just want to print only 4 of them and whn i print it says it prints in the box but nothing comes out the printer but when i try another...
Alrite now, firstly, since you need only 4 pages of the 200pg document, go to File > Print > Select page range (e.g. 1-4, 51-54, etc)
Then print and make sure you have pages loaded in tray 1.
You can also have papers in tray 2. If MS Word does not respond, then change the drivers to UPD (http://www.hp.com/go/upd), the system may have legacy drivers or An earlier version of firmware.
Rgds,
Nikhil
Sep 11, 2009 | HP LaserJet 4250n Printer
Brother MFC-9840CDW says no paper when trying to print. there is paper, it will make copies and test page, but beeps and flashes no paper when printing. Says "reload paper in MP tray", I've taken out all...
I had this problem trying to print from MS Word in a template I downloaded. I found this link and it worked perfectly. I'm using Word 2010 so I had to adjust accordingly. It's for a slightly earlier Brother model but that did not affect my using it.
Jul 15, 2009 | Brother MFC-9840CDW Laser Printer
HP 2430 jams from optional tray 3 only.
Hi Rich,
I've had this problem too. I believe it's the post that holds the drive gears wears or becomes loose causing timing problems.. Unfortunately there's no spare parts available for the optional tray. You would have to purchase a whole optional tray.
Mar 11, 2009 | HP LaserJet 2430dtn Printer
Print Problem Go Light Flashing wont print till pushed
Sounds like its waiting for a manual feed. Check the paper you have in the tray and that the selectors on the tray are properly positioned. Once that os done, on the computer side hit the start ICON on your desktop, then control panel, then printers and faxes. Double click on your 2100 print driver to open it. Go into properties and make sure it says "automatic" for tray select. Hit the advanced key and check that it says letter or whatever paper size you have in the tray.
Verify the other settings and then save it.
That should solve your issue.
Aug 07, 2008 | HP LaserJet 2100 Printer
Printing problems - i can only print manual feed...
the manual tray is the is the one above the tray,
1-either your tray is set incorrectly must be set to Letter/Plain
priority is tray 2 not tray 1
tray one is the by-pass / manual
since this printer does not have a screen on it everything is setup through the PC.
print a configuration page and you will see all the settings
Aug 05, 2008 | HP LaserJet 1022 Printer
Ricoh CL3100N
Have you setup for double-sided printing?
Jul 15, 2008 | Ricoh Aficio CL3500N Laser Printer
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Paper Tray
Hi there. You can select the tray you want to use when you print in the print dialog page. Depending on the driver you're using, the driver of the printer might save the last used tray as the default one. Else, you might wanna go into control panel - printers, go into your printer's properties and look for the printer's default properties in the advanced tab. There, you might be able to set the default tray to be used for future prints. Hope that helps ! cheebster.
Jun 18, 2007 | HP LaserJet 4000 Printer
49 people viewed this question
k24674
jasbo
jasbo
