Question about Samsung SGH-d807 Cellular Phone
My Phone Won't Vibrate
It just stopped working. It's about two years old, and when i press the side button to turn the volume to vibrate, it doesn't vibrate, even when called. this model isn't at cingular anymore, either, so i can't just replace it. please help!
    President:
  • 1,263 Answers
Go in your security feature and set to default, then program the parameters of your call answer options an and receiving options hope this will do the trick...please rate this
Posted on Sep 01, 2008
My phone won't ring anymore model Huawei H868c
The volume keys are located at the right side of the phone. Press the top button to increase the volume. Hope that works.
Oct 07, 2015 | Huawei Cell Phones
My Apple I phone will vibrate on incoming calls but my ring tone will not come on
If the switch on the side of the phone is flipped down (red showing) then it is set to silent/vibrate mode. If that isn't it, then go to your home screen and try pressing the volume up button on the side of your phone several times until it reaches the desired volume.
Mar 10, 2015 | Apple Working Black Att Iphone I Phone 3gs...
I own LG VX8360 and can't figure out hoe to turn ringer on. Can you help me?
To restore the ringer it will depend on what mode your phone is in:
Vibrate Mode:
Sets the phone to vibrate instead of ring.
To set Vibrate Mode, with the flip open, press and hold the # key .
To return to Normal Mode, press and hold the # key again.
Sounds Off Mode:
Quickly deactivate your phone's sounds when you're in a place where phone sounds would be disruptive.
From standby mode with the flip open, press and hold the lower side volume key for 3 seconds. To return
to normal sounds mode, press and hold the upper side key.
Airplane Mode:
Turning on Airplane Mode will disable all wireless communications.
1) With the flip open, press the Menu key.
2) Use the Directional Key (top center of phone) to scroll to 'Settings and Tools'.
3) Press the 6 key for Phone Settings.
4) Press the 1 key for Airplane Mode.
5) Use the Directional Key to highlight a setting, then press OK.
On/Off
Mar 30, 2010 | LG VX8360 Cell Phone
Phone locked on vibrate only
The trick is NOT to use the "settings" menu, but instead press the volume button (on the left side of the phone's body) up, until you get into the "volume" mode and out of the "vibrate only" mode. then you can set the volume however high you want it.
Jan 26, 2010 | Samsung SCH-u340 Cellular Phone
LG env3 alarm clock vibrate
Yeah, I had that problem too. I thought my phone was broken. -_- My old phone from Verizon is like 4 years old and I JUST got my enV3. On my old phone, I'd have to set the alarm's ringtone to "no ring." But, on my enV3, "no ring" literally means NO ring, no vibration, no notification, no nothing. On the enV3, in order to set your alarm clock to vibration mode, all you have to do is make sure you "master volume" is in vibration mode, but you have to set your alarm's ringtone to something other than "no ring."
Oct 20, 2009 | LG enV3 VX9200 Cell Phone
SAMSUNG SPH-M540 MOBILE PHONE
Unlock the phone first then hold down the Star button.. it worked for mine :) hope it works for you
Dec 18, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Samsung sgh-a300
hold down the # button for 3 seconds. when the vibrate turns off, just keep pressing the volume up on the side of the phone,
good luck
Jan 14, 2008 | Samsung SGH-A300 Cellular Phone
Jabra Vibrate Feature
from the manual at http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_NA_EN_491.pdf
Call vibrate*
• Call vibrate is automatically activated when you turn on your headset.
• To disable the call vibrate feature, press the answer/end button and
press the volume down (-) button at the same time.
• To reactivate the call vibrate feature, press the answer/end button and
press the volume up (+) button at the same time.
Dec 19, 2007 | Jabra BT350 Bluetooth Headset Headset
Samsung SGH-d807 Cellular Phone Logo
48 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
