Question about Mitsubishi WD-52525 52" Rear Projection HDTV
WD 52525 mitsubishi - how to I get a copy of manual and check balist - or dm board?
Help to obtain copy of service maual for dlp wd-52525
how do you access balist and check it for 300v?
  • sullivanao2 Jan 23, 2009
    I replaced the lamp but no picture. The red lamp light still comes on.
  • Mitsubishi Master
  • 8,617 Answers
You can get the service manual at the following link. Its under the mitsubishi category listed as the V26 DLP service manual.
http://servicemanuals.vstore.ca/
Posted on Sep 04, 2008
The timer light is continuosly blinking when i plugging in the tv (mitshubishi wd-5252) and won't reset?
Thats one of the famous capacitor issue most likely. Thats the V26 Chassis DLP and usually that symptom is caused by failed DM and Power Board capacitors. There is a repair kit that will work in alot of cases with that symptom. Its called The V26 Chassis DM / Power repair kit available at the following link with detailed instructions http://tvrepairworld.com/mitsubishi_repair_kits
Apr 03, 2013 | Mitsubishi WD-52525 52" Rear Projection...
How to replace the dm in wd-52525
The DM is the second board inside the Chassis block directly underneath the FMT board. But replacement DM boards if still good are very expensive your better off replacing the 4 capacitors that fail on the DM.
Blinking green timer light will not go out even after I push the reset button.
Thats usually caused by failed capacitors on the DM and the Power boards. You can get the V26 Chassis DLP DM/Power repair kit which contains the caps for both boards and the CD with instructions. Its available from www.tvrepairworld.com under the Mitsubishi repair kits category.
Aug 23, 2011 | Mitsubishi WD-52525 52" Rear Projection...
AFTER A POWER FAILURE GREEN TIMER LIGHT WILL NOT STOP BLINKING. HAVE TRIED TO RESET TIMER, UNPLUGGED POWER SOURCE. THIS IS A MITSUBISHI DLP WD52525
The Capacitors on the DM board need replaceing. The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the capacitors and the CD with instructions.
Dec 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green light
The DM has caps on it that are easily changed if you can solder, a google search should lead to many forums with the proper instructions
Aug 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd 62525 honeycomb pictues
The DM board wont cause that symptom. The DM only directs power that is recieved from the PWB to the ballast fans and etc. That sounds like a problem with the FMT. capacitors 1000uf @16volts numbers C8F21, C8F22, C8F19, and C8F27. those will cause distortions in the video on the V26 chassis. Let me know if you need more info
Mar 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52725 Timer light is blinking and will not stop.
This part will cost you about 650 to 800 bucks my friend. if you have any soldering skills, and can follow directions, I posted a DM board fix. it may just be four small capacitors. Now this set that was used in the fix is not exactly like all the other Mitsubishi TV sets that still have a DM board, but if you can locate the DM board, follow the rest of the repair. if you do not know how to solder, do not take a chance, as this part is way too expensive to be experimenting around with. Get the Capcitors(there is a link there too for the capacitors)and take the DM board to a service shop, as this should not cost you a lot to have a pro do this for you. The DM board fix is located here: http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good luck
May 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
293 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
