Numark idj2 all itunes library i have are on my computor, they go from my itunes libriary to my ipod. the idj2 is a ipod plyer that plays and uses one ipod. In order to use this machine with one ipod you must load your media to the idj2 which can take a couple of hours or more to update, Once this is done you are able to load a song to one side and play it load another song to b side review it and play it after the side a finishes. Some tunes have titles and they appear to load to a side you are going to play but when you go to the play mode there is nothing or the tune woill not get off the pause mode and if you keep pursueing the machine will go into error moe and shut off. a program disk to load soes not come with is machine. It is suppose to take your media off your ipod and play. songs play on computor and the ipod but not the idj2
  • 1 more comment
  • davidem162 Sep 01, 2008
    the machine is new and does not appear to have a reset, it appears to have somekind of hard drive to retain the information of media on the machine. if an ipod is not connected to the machine no media can be played, how doe you get all your itune librairy to make all your music into the appropriate format so they will play on other devices.
    no reset feature buttons anywhere
    this is my secound machine and it does the same proublem the first one does
I have a Denon AVR-589 and the Numark IDJ2. Instead connecting the IDJ2 to the ipod audio slot of the receiver, connect it to the CD Player/VHS audio slot. Then play around with the cue and master controls of the IDJ2. At least this solution worked for me.
Posted on Nov 02, 2008
    President:
  • 1,263 Answers
Ok try this do you have a master rest of the idjr? if you do use it and see if this will re initialize the device.
Posted on Sep 01, 2008
  • 1 more comment
  • Ronald Mueller
    Ronald Mueller Sep 01, 2008
    do you have a default option on it? it should be in your security feature. please rat this fairly
  • Ronald Mueller
    hmm if you have no trouble with the library on you othere device and it plays everything like it should . then i would suggest that you take the device back and get a replacement because there is no plausible reason for you to have this trouble. i'm sure you have read the booklet that came with the device. even though the device is new it still could be defective it's happened before. good luck
  • Ronald Mueller
    well i don't have a definitive answer for you this has me stumped your more than welcome to ask someone else i'm sorry i was unable to help you at this time
Idj2 wont recognize ipod after ejecting during library making
Did anyone come up with a solution to this? I'm having the same problem.
May 26, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
I have a numark idj2, i can get music media off itunes the media records to my itunes libriary and ipods but will not go into the numark idj2, some of the media appears on the numark libriary but when you...
are the files that you have compatable with your new device. sometimes certain devices can't read the format of the file. not all mMpeg or Jpeg files are compatible with different devices do you have a usb cchord that came with your device and a cd to install the driver in the computer?.... my suggestion is to down load all files from the ipod to your computer. install the driver and the computer will be able to sync your files and their format to your new device...please rate this good luck
Sep 01, 2008 | Audio Players & Recorders
The system wont load all of my songs. I used the library tool and it loaded 800 out of my 1000 songs
some songs are protected files and wont load. i know dude, i cant play 15% of my library. very frustrating. apple made no friends on that one.
Dec 26, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
I just got an idj2. I downloaded the firmware. I went through the library process, though I'm not sure what that really did other than take a ton of time. I hooked my ipod touch (16 gig) to the idj2 and it...
Dan... I hate to be the bearer of bad news...
Located at http://www.numark.com/idj2 there is a link called iPod compatibility matrix v1.6 this link tells you which versions of the iPod work great with the idj2 and which versions of the iPod make you want to pick up your idj2 and smash it against a brick wall. Sadly, the iPod Touch falls into the "smash" catagory.
Generation 1 iPod Touch devices can only be used in "DIRECT MODE ONLY" which means you can use them like a cd player or as a music source on 1 channel of the mixer of the idj2.
Both Generation 1 and Generation 2 iPod Touch devices are not supported to be used with the idj2 in "MASS STORAGE MODE".
Jun 10, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Still asks me to download librian
The idj2 doesn;t search off your ipod. you have to put libraries together with the librarian tool.
Here is a manual for your idj2 it's clear and will tell you how to import a library to your computer for search and play.
send me your email and I will send you a manual i downloaded steveb661@yahoo.com
May 18, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Can't get the ipod touch to play on the docking station
I had the same problem. Look at the documentation site of Numark
Ipod touch isn't supported for mixing (1st gen is supported for Direct play)
Source:
http://www.numark.com/stuff/contentmgr/files/2/dd1ffd47d0ee2aec5d8ef3afa92e0992/file/ipod_compatibility_numark_v1.6.pdf
May 16, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Library questions
Librarian 1.50 / IDj2 fimware 1.09
Read the other Q & A's, about IDJ2
Regards,
Jack
Jan 29, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Uploading problem
Some things you have to do yourself... It only takes some work to get it right.
For using ipods or harddrives/USB sticks with the IDj2, your best off with creating Numark libraries. This makes the IDj2 quicker when searching/loading tracks.
This can be done on your Mac or PC with
librarian 1.50/IDJ2 1.09(a)firmware combination. If you havent updated your IDJ2 yet, do so. It's the most recent verion, and fixes most problems...
Files can be found on www.numark.com/idj2. Look around in this page. There is also explained how to update with a FAT formatted USB stick.
If you have created a library before, Itunes won't update this library, cause it's made by Numark. Itunes and Numark use both a different database.
If you run Librarian, it will still see the Ipod playlists, and add them accordingly in your Numark database, and can be recalled in the IDJ2.
If you have created libraries with Librarian 1.33 or on the IDJ2 with firmware before 1.09. You have to remove the whole libary, and recreate one with Librarian 1.50.
Mostly there is a directory on the device called " .library ". You can throw this away, and recreate a new library.
Good luck and happy DJ-ing.
regards,
Jack.
When docking it takes too long transfering data from ipod to idj2
if you have a PC, you're better of preparing a library for your USB/IPOD devices with Librarian 1.50, but only if you are running 1.09(a) firmware on the IDJ2. This is the preferred and quicker way...
Do an upgrade if this is not done yet. Go to
http://www.numark.com/contentmgr/showdetails.php/id/1230/tt/5
for downloading the files.
When rerunning the librarian(for instance when adding tracks), choose normal mode. It will add every playable track. (you could try this out on an USB stick with some tracks on it for testing purposes).
If this doesn't work, you could have a corrupt library, and have to rebuild(choose advanced in Librarian). Also, when you have created with earlier versions of IDJ2 firmware, then you have to rebuild the whole library.
Numark stated on their forums, when connecting a device, to never choose update, but load instead. It can use mp3/wav/non secured aac files, but not wma..
If there are any other questions, you can also send an e-mail to numark. They are reasonably quick with their responses.
regards
Jack
Dec 26, 2008 | Numark iDJ2 - DJ iPOD Mixer Docking...
My IDJ2 is unstable
not sure what it can be, but if you used librarian before, be sure that you are running librarian 1.50 with fw 1.09(a). If you have created a library with 1,33, then you have to create the library again with the 1.50 version. Don't use USB powered drives. Mostly they overload the USB port, with al sorts of weird problems. If you have one of these, use an USB powered hub to remove the load of the IDJ2 port. You could test with an USB stick, for a few hours..
regards,
Jack.
Dec 23, 2008 | Numark iDJ2 - DJ iPOD Mixer Docking...
169 people viewed this question
 Grubhead
Grubhead
