Question about HP Office Equipment & Supplies
Every time I want to print something it says it can not find printer and I have to re load the program disk, go through the whole set up and I am getting pretty cheesed off as this is time wasting
    Genius:
  • 2,785 Answers
Plz scan your pc for viruses and reload the drivers
Posted on Sep 01, 2008
I`m using HP Photosmart C3100 Series. The problem with my printer is that it doesn`t print the whole page, only half of the document was printed and then it will ask you to load another paper then it...
This sounds like the printer driver has become corrupted. Try unplugging the printer, and removing the drivers (from Add/Remove programs in control panel (XP) or Programs and Settings (Win7)).
Once the driver is removed, reboot the computer, and put the original driver disk back in the computer, and plug the printer in when prompted by the HP software.
Jul 23, 2011 | HP Office Equipment & Supplies
My printer is working but notting is printing on the paper
1st check ink cartridges if its a new printer the ink heads will be taped if so then it wont print. run the print heads program to set and align the heads. when donr it will print out a paper with lots of **** but thats ok now its set up to print. run the disk it came with to load it to computer. make sure that the printer your are using is the one that is marked on your computer to use. under start pick printers and select from there. add paper in the slot and make sure all openings are open on the printer. it should work fine.
Mar 30, 2011 | Canon BJC S500 InkJet Printer
Right i have new laptop have loaded up disk for printer, and when i click print on laptop it prints something else that i printed last time i used the printer. it is a bx300f thankyou
Check what is in your print queue before printing. If a document fails to print completely it may remain in the print queue even if you turn the laptop off.
Feb 16, 2011 | Office Equipment & Supplies
Printer is printing 1st five lines, is dragging the next three, and off and on dragging the remainder of the letter...HELP!!!!!
If your print something, try to close the program to print all the whole printing page if is works. What is your printer name and model? My epson printer coming like this stoping at halfway but when i close the program I use, it will continue to print.
Jan 05, 2011 | Office Equipment & Supplies
Printer was working two weeks ago now i try to print it would not cut on
Make sure the printer is plugged in and turned on.
Make sure that printer is set to default.
go to control panel - click printers - make sure it has a right mark on it - if it doesnt, right click printer icon and choose set as default.
If it doesnt work, try uninstalling and reinstalling the printer driver.
You can uninstall the driver using the printer driver disk or from add/remove programs.
Hope it helps !
Thanks.
Sep 08, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer Disappears from file and won't print from any "print" area
go to www.hp.com and get a fresh print manager driver,
sometimes, the wireless connection hiccups(from your router/wireless device) caused by power glitches..you have that router on a power strip?
got backup for your computer?
Feb 20, 2008 | HP Photosmart C7180 All-In-One InkJet...
Printing not responsive
It maybe the spool settings are incorrect. You can easily uninstal the printer to set back to factory default, by uninstalling in add/remove software and disconnecting printer from usb port.(It may say documents are pending, ignore and delete) Download driver from here if you have lost installation disc. http://esupport.epson-europe.com/FileDownload.aspx?lng=en-GB&ID=27566&data=237EA0F2CDB90E9EFC108A9D38B0E2A2E601901E3494AEE9FAF7F774D281BE84 Install driver then re connect printer when prompted or after installation has completed. Try again and hopefully it should print first time.
Jan 20, 2007 | Epson Stylus CX4800 All-In-One InkJet...
Printing problem
This error message indicates that the printer memory is full. You might be sending too many documents to print at the same time. I would suggest dividing the number of documents/pages into smaller groups so the printer can take the load. Hope this helps!
Feb 22, 2006 | Xerox 6100/DN Laser Printer
Ben Johnson
