Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6548A Transmission R&R
I have my transmission replaced 5 months ago. Now the repair man said that it needs to be replaced again, but I don't want to pay another service fee. Maytag sent me the parts. How do I get instructions on replacing it myself and is it worth it?
  • 943 Answers
Hi thanks for the question johnfmi would let the tech do it only 5 months ago it should be all covered under warranty thanks the appliance doc
Posted on Sep 13, 2008
Should water back up into the tub upon spin completion on maytag atlantis
No, If water is coming back, the sewer is cloged up or is a big posibility that the washers transmission is not spenning at all. it may sound like is agitating during the wash and spinning during the rinse. To check it, put soap inside the drum if it doesn't get disolved after the cycle is done. The transmission needs to be replace. Is costly you may want to shop for a new one.
Jul 19, 2014 | Maytag Atlantis MAV6000 Top Load Washer
Greese slinging in a big circle under machine on a maytag atlantis
I once had grease leaking under my new Maytag washer, and it turned out to be a leaky transmission. This was on a new machine too, so don't think it can't happen.
Call the lonely repair man who never works !!
Lots of luck to you. Hope you get your machine working clean again real soon.
Mar 14, 2014 | Maytag Washing Machines
I have a Maytag Atlantis top load machine. It is 7 years old. I have very dark oil dripping from under the machine at the bottom edge of the front. I am assuming the gear box is gone but wanted to confirm...
Sorry to confirm your suspisions but its leaking oil from the transmission and its exxxpensive to replace the transmission. And sad but true the good ole days of dependabilty of the maytag is gone espically since 5 years ago Maytag was bought by Whirlpool. a Whirlpool is a good machine but nothing was good as the old Maytag's
Aug 16, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Wont spin
Sounds like the transmission seal had failed sometime back and has leaked the lubricant causing the transmission to overheat and now possibly seizing the gears, if this is the case the transmission will have to be replaced. Depending on the age of the washer, (5 years or less) you should contact Maytag to see if they will compensate you by way of furnishing the new transmission for free, but you will be responseable for the labor charge from a tech to do the replacement.
If they will not cover the part, you will probably be better off to replace the washer than to invest in the cost of a new trans and labor.
Good Luck !
Mar 21, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Washer transmission & brake bad - replace or not?
kenmore elite washer,but first if you want to try to fix it yourselt look on ebay,put make and model number and see what comes up,i got a new transmission for $70 took my time taking apart then reassemble and it was pretty easy,let me know how you do-mike
Oct 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
How to replace gears myself?
Just went through an agitator problem with my MAV7700AWW Atlantis. You are talking about the main (bottom) agitator, not the corkscrew part up top, right? If so, you can check this site to see how to access parts inside your washer. I found it very helpful: http://www.geocities.com/maytagrepairwasher/
I too, had visions of replacing stripped gears, but after searching the internet for a few days, decided to buy a new transmission, replace it, and then tear in to my old one and repair it and then have the original for a spare.
I found a NEW transmission and tub seal kit for under $120 including shipping to my door.
If you have an Atlantis, then the following information will be very helpful. Otherwise, you may find that you have a transmission that can be serviced more easily.
When I finally got the old transmission out I was very happy with my decision. I cannot see how it comes apart - no screws, bolts, clips, or clamps. It is an upper and lower half that appears to be gooped together by a blue sealant. The new transmission appears to have the halves crimped together - maybe it is a serviceable part, but it is not very user friendly.
If you decide to tackle the job, I can offer a few tips on alternative tools and also on disassembly of the brake.
Mar 09, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
288 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
