Question about Whirlpool Refrigerators
Amrican fridge freezer keeps tripping the electric. i changed the fuse and tried running it from a different socket but still it trips. is there something else that could be causing this to happen
  • ollieconnell Sep 03, 2008
    got a technician out but his answer is not what I wanted to hear. He said to bin this fridge and get a new one stating that water has got into the internal flume, is this possible and if so can it be fixed?
  • 958 Answers
If the unit is tripping the electric breaker, then there is a short in the unit. if you know how to use a resistance meter, you can trace your unit.
short could be coming from the power cord itself, check for broken wire and maybe touching the ground or the body of the unit.
next check your compressor. this is the biggest load of your unit. if this is shorted to ground, then it will trip your electric.
be care full on plugging the unit if you are not sure that you found the shorted wire, it might trip again.
if all of those still does not correct your problem, check the mullion heaters. but the connections of these heaters are sometimes very hard to find to check. their are hidden and only technician can sometimes find them.
tnx 4 using fixya
drcool
Posted on Sep 01, 2008
  • francis rivero Sep 03, 2008
    if the water is dripping on the drain and shorted the electrical. you can repair the drain so that there would be no water dripping to the comressor electrical.
    first, clean all bunt wires or dry all the water soaked electrical that is causing the electrical to trip. use hair dryer if possible to make sure that everything is dry. use some sealant to repair the drain ( flume ) so that no water would drip again to the enderneath.
    replace any part that was burn if there are. ( relay, overload, capacitor )
    then test again your refrigerator if it would no longer trip your electrical power.
    compressor would not right away be damage by outside problem. you could probably still save your refrigerator.
    tnx
    drcool
Find out why my freezer is shorting
Is your FREEZER is plugged into a wall socket which is protected by an EARTH LEAKAGE UNIT or RCD [Residual Current Device] ???
Most manufacturers advise NOT to have this type of appliance connected through an RCD as the start load required when the COMPRESSOR "kicks in" is quite large [especially in larger fridge/freezer units] AND will quite often TRIP your RCD. These appliances are better connected to a separate electrical circuit if at all possible and not protected by an RCD.
Sep 20, 2014 | Refrigerators
Fridge/freezer keeps tripping
Try to plug into different circuit, if it trips that breaker on the board then the appliance is probably at fault.
I must assume that you have not acquired something plugged into the same circuit as the fridge.
Sep 26, 2017 | Beko Refrigerators
My freezer keeps overloading our switch board, whats wrong?
The freezer has a compressor which will draw quite a lot of current in the first half-second when it starts.
Either: Your freezer has a electrical problem and needs to be fixed,
Or: there is already too much drawing on the circuit that you are trying to add the freezer to, and the freezer is more than the circuit breaker will allow.
First try powering the freezer from some other socket on a different circuit (use a long cord), or unplug a few things that are nearby (in most houses, there will be several wall sockets on the same wire in each area of the house).
If the freezer runs fine from a different socket, or when you unplug some other stuff, then the problem is you are overloading the circuit you were originally trying to add it to.
If you can't get the freezer to run on any socket without tripping the circuit breaker then probably the freezer has an electrical fault and best you get a real electrician to check it (safety first!).
Oct 02, 2012 | Freezers
REFRIGERATOR KEEPS TRIPPING THE GFCI OUTLET
A GFCI detects shorts in an electrical system and isolates power to prevent that device from harming other components upstream. GFCI's do go bad so that possibility exists. However, I would recommend trying to plug in your refrigerator into another outlet in your kitchen that has a different GFCI plug. If it does not trip then the GFCI needs to be replaced. If you do not have another available GFCI outlet and you plug it into a regular outlet, your breaker for that service line MAY trip. Better off testing with another GFCI. If your second GFCI trips, then the problem is with your refrigerator...meaning you have a short in your refrigerator. If you think this is something you can troubleshoot...BE CAREFUL!!! Always unplug your refrigerator before going into the components of the refrigerator. One thing you can do is turn both the freezer and refrigerator temperatures OFF or to their lowest setting. Plug your refrigerator in and see if the GFCI trips. If it trips you have a major short...probably in the bottom of the refrigerator. If it does not trip, turn the freezer temperature on first and see if it will run without tripping the GFCI. If it runs, then turn the freezer temp OFF. Then repeat the process testing the refrigerator components. Ice makers have been known to generate shorts in the system as well. There are various ways to troubleshoot a fridge. If you do not have the required electrical troubleshooting skills then PLEASE call a service technician.
Nov 30, 2017 | Jenn-Air Refrigerators
Hello We have a gaggenau 2 door fridge freezer,SK 533. And it keeps tripping out the electrics. We have tried running it off a different fuse box and still it happens. Can u help?
Sounds like the defrost element in the freezer has failed in spectacular form, this is the most common fault for tripping power, or it could be the thermostat but this is highly unlikely.
If you can, gain access to the element by dismanteling the panel inside the freezer, the element will run at the base of the cooling cores with a wire at each end (black) and an earth point (green), check with multi-meter, on earth and one on black, check both ends of black. You should find you will have a flow through one of the ends that will indicate a short curcuit, replace the element if faulty.
Regards Russ
Dont forget to vote and if you need more help, email me at wgheaven@yahoo.com.au
May 08, 2011 | Gaggenau Freezer RF461700
Lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Mar 10, 2009 | Refrigerators
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
THE MAYTAG fRIDGE/fREEZER BLOWS OFF I.E. IT SWITCES ITSELF OFF AND THE MAIN FUSE TRIPS OFF. THE PLUG FUSE NEVER BLOW OFF THOUGH.AFTER COUPLE OF DAYS,WHEN WE PLUG IN THE THE FRIDGE/FREEZER IT WORKS FINE AND...
what's the model number,i don't understand what you're asking,are you saying the fuse keeps popping in the house fuse panel?or the fridge stops running and the house fuse is ok.what is i.e.
Feb 07, 2018 | Maytag Refrigerators
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Refrigerators Logo
248 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
