Question about Acer PD523 Multimedia Projector
The acer pd523
Has the bulb 1100 hours of life. Recently we experiment on the screen the effect of a broken glass, but it got fix after I clean the projector with an air compressor, i guess it helped cleaning the filters.
now the projector works, looks fine with songs, but every time we are trying to show some video, the coloring, quality is not good any more like the beginning.
is the lamp that is bad with 1100 hours, or what else could be the problem?
can some one help me? thanks
I tried changing the contrast, bright and everything possible from the menu.
  • 1 more comment
  • milandred Sep 07, 2008
    I got an answer that I had already told I done it, so I can't take that answer.
    haven't tried changing the bulb, but I would comment after I change the bulb, if it works.
  • milandred Sep 25, 2008
    ok...
    I just spent $383 dollars in a new pd523 bulb, but the problem still there....
  • Acer Master
  • 1,879 Answers
It is definitely the lamp. Too much heat (caused by blocked air filters) damages it.
Posted on Sep 03, 2008
    President:
  • 1,263 Answers
When you cleaned it with compressed air you might have jarred loose a connection on the board. i would take the unit cover off and look to see if you jarred a chip on the board or there is a bad connection of some of the capcitors. if this doesn't work try and change the bulb.
    Genius:
  • 1,142 Answers
Try to open the unit and the clean it as it has mirrors in it that might be dirty which needs a cleaning.
What size bulb goes in the oven
Seems that regular bulbs really don't like the high heat or getting splattered with cooking juices, shatter at the first contact with liquid. Think you better spend the couple of extra $$$ and not have to clean up a shattered glass mess in your oven.
The GE Reveal 40-Watt Appliance A15 Light Bulbuses neodymium glass to filter out dull yellow rays for enhanced, vivid results. The bulb is an ideal choice for use in household appliances like microwaves, refrigerators and ovens.
Light output: 320 lumens Energy used: 40 watts Life hours: 1,000 hours Ideal for use in many household appliances such as microwaves, refrigerators and ovens Unique neodymium glass filters out the dull, yellow rays of regular soft white bulbs for enhanced, vivid results
Nov 17, 2014 | Cars & Trucks
Lense hours
Hello muhammad
Projector's lamp life is said to be, not with the lens life. Lens is made up of glass. But lamp will go weak. the life of lame will depend on how much time the projectior have used. Normal life of Panasonic projector bulb spans between [1800 to 2000] continous use. It means, if we take the low life span of the bulb as 1800 Hours [1800/24=75 Continous days]. If we use it for 4 hours a day, the bulb may last for [1800/4=450 days ie 1 Year and 85 days] OK.
Dec 12, 2011 | Panasonic Videoprojector PT-LM1E...
Bluish image appearing on screens
It sounds like the projection lamp is beginning to show its age. How many hours of use does the unit have on the bulb? The bulb are typically rated for about 800-1600 hours of use before they go bad. The bluish image on the screen image is a typical tell-tale sign that the bulb is going to need replacing.
Most of your better projection units will have an internal time counter of the bulb life from the time the unit is first used or when a bulb is replaced. Check to see if your unit has this feature, if so it will show you on the screen display what is the total number of hours on the bulb and the estimated remaining hours of life.
Be aware that the replacement bulbs are NOT cheap and usually will cost you several hundred dollars, I have seen bulbs for professional projection units used for large convention/presentations have bulbs costing as much as $500.00 USD.
One other last thing to check is to clean the lens of the unit both inside and outside. To clean the inside, you will need to remove the bulb (be sure to wear a rubber glove as the oils from your skin will cause the lamp to blow, (causes a hot spot)). Then using a cleaning wipe, just as one used for cleaning microscopes or glasses, wipe the lenses. The discoloration might also being caused by dirt and oils on the lenses.
I hope this shed some light on your church's projection problem.
Sep 19, 2009 | Panasonic Office Equipment & Supplies
Infocus 4805
You may have got finger prints inside the unit. Use alcohol and a paper towel or q tip/swab to clean all the glass surfaces including the bulb. You should never touch these bulbs because the oils from your hand will decrease the life of the bulb. Also make sure you put all the parts back and that they are tight. Last item is the lens may screw for focus.
Aug 29, 2009 | InFocus ScreenPlay 4805 Multimedia...
I dont have a manual for Acer PD523 Multi media projector
You can download the manu for this from this link, just sign up and its free to download any manual from this site
http://www.retrevo.com/support/Acer-PD523-Projectors-manual/id/843dj481/t/2/
Feb 28, 2009 | Acer PD523 Multimedia Projector
PD523 no picture, led blinks
Hy !
Seems to be the colorwheel. When a segment is broken, the unbalanced wheel causes vibrations. Costs approx. 100-150$. Take away back and top so you can see if wheel is not complete.
Good Luck!
Jul 07, 2008 | Acer PD523 Multimedia Projector
Eiki lc4300 projector
check to make sure your lamp is completely in and connected properly, and the lamp door is closed completely, if still no light, pull the lamp out and make sure it is not broken from transporting it or handeling it.
Making sure you do not touch and glass portion of the lamp or surroundings. only touch plastic or "metal using clean dry paper towel for metal contact" as skin oil can destroy a lamp.
"If this dosen't help please reply for more help before marking a bad suggestion, thanks"
May 08, 2008 | Office Equipment & Supplies
Panasonic PT-L557U Bulb Life
lamp hours can only be displayed by connecting two test points in side the projector. in normal operation, a message will be displayed on the screen when the lamp hours = 1090. when the lamp reaches 1100 hours, the projector will shut itself off. when you do replace the lamp, be sure to reset the lamp time in the setup menu (this is covered in your manual).
Dec 14, 2007 | Panasonic PT L557U Multimedia Projector
Hour glass as picture
It is possible that your television needs to be degaussed. Gaussing occurs in televisions that have magnets, (usually speakers) placed to close to the unit. A degaussing coil can be purchased at a good electronic supply store. Simply follow the instructions that come with it. If this does not fix the problem, the television will require repair by a qualified service center.
Jul 25, 2007 | Samsung PCL541R 54" Rear Projection...
PD523 lamp icon
sounds stupid, but its not the mute is it? cant check as my acer is in bits at the moment!!!
Aug 10, 2006 | Acer PD523 Multimedia Projector
Open Questions:
Acer PD523 Multimedia Projector Logo
223 people viewed this question
Top Acer Office Equipment & Supplies Experts
Electro Med Services...
polytek
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
