Question about Char-Broil 7000 Quick Set Gas Grill
Please help weak flames in grill only blue tips will not even leave grill marks
    President:
  • 1,263 Answers
Have you cleaned the burners? if they are not clogged your regulater is the problem and should be replaced asap. don't use the grill until you have replaced the regulater if that is the problem.
Posted on Sep 01, 2008
Our Uniflame Grill has a round outer burner and a round inner burner. The outer burner has a large orange/yellow fllame. The inner burner has a small blue flame. Is it normal for the inner burner to...
Bob, your wife is partially correct. However, both burners should have blue flames with orange tips. Cleaning the burners and the their venturi valves, should solve the problem. When I say cleaning them, I mean removing and cleaning them.
Hope this helped you and Happy Grilling!!
Jun 27, 2011 | Uniflame FG2204C Grill
I have a 3 burner spirit grill. I can light the grill, but only burner 3 gives me a nice even line of blue flame. Burner 2 seems to be the worst with oranges flames on the right and left end. Burner 1...
Charcoal and grease build up can restrict even the best gas burners , my suggestion is to clean your gas burners with a burner tip tool . You can purchase these at Lowes or Menards . Here is a website for you to visit to get the ideal . http://www.metaltech.com.sa/victor/tips.htm
Goodluck
Electrician by Trade
Feb 18, 2011 | Weber Spirit? E-310 Propane Grill
The grill is 6-7 years old.. The flames are orange and leaving sud on the food..
sound like this is insufficient air in the flame...
if you can, lift burners out, spray them with oven cleaner and leave for several minutes, use wire brush and clean them under the water. pat them dry with paper, check if all holes are free of rust, fat and debris, clean as required. this should restore your grill burners to nearly new condition, return airflow back to normal and restore your flame to blue.
wear faceshield/googles to protect your eyes and gloves to protect your hands while you do that! and better you do not wear your sunday best either... oven cleaner is strongly caustic and can burn holes in the fabric and bleach it.
if you find this advice helpful, please do not hesitate to leave comment and give me your vote4, thanx!
Jul 28, 2010 | Weber Summit Gold B (NG)
Can't get a decent flame after lighting the grill.
Sounds like you need a trouble shooting checklist! Click on my username, scroll down my profile and click on my tips and tricks for trouble shooting gas grill lighting issues. Hope one of then helps.
May 17, 2010 | Thermos Stainless Steel Gas Grill
Weak flame on webber q200 grill
Remove connection to tank, reconnect, open valve slowly, when you open valve to fast the tank valve has a shutdown in it, it thinks something is wrong and shuts valve down. Always open tank valve slowly when using.
Also your tank valve could be sticking causing this problem, to fix replace tank.
Feb 25, 2010 | Weber Q200
MY PORTABLE GAS WEBERHAS A WEAK FLAME FROM THE
The regulator is probably bad and nees to be replaced.
Jan 01, 2010 | Weber Gas Go-Anywhere Grill
The pilot light on my kozy world ventless wall heater goes out after it burns for a while. Even quicker when the blower kicks on.
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Oct 26, 2009 | The Companion Group Kozy World Portable...
Low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
Mar 14, 2009 | Weber Genesis Silver B Grill
Had a new gas hob installed but two of the gas burners only have a very low flame even when turned to high. One of the others has yellow flame tips even on low and is leaving marks on the bottom of the...
propane or natural gas? if it was converted inproperly it will leave soot on your pans. also you will see flames when you bake with it or broil.
Nov 01, 2008 | Kitchen Ranges
Char-Broil 7000 Quick Set Gas Grill Logo
143 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
