Question about Oster 3071 Rice Cooker
I had a burnt wire smeel and the cooker turned off.how to fix it.
  • 1,254 Answers
There could be something "blown " inside. have a close look underneath for screws so that you can undo and have a look at the components inside. Check for burnt wiring or terminals. Replace a s required. These type of cookers also have an overheat device which may have tripped if it overheated. You will need a multimeter to check if that has "open circuited"
Posted on Jul 31, 2011
SOURCE:
My oven smells wen cooker gets warm
What kind of smell? is is like an electrical smell similar to a burnt motor or transformer or electrical wiring or the smell of burning food. If it is a food smell, cleaning the cooker might resolve it. How old is the unit?
Sep 12, 2012 | Belling Kitchen Ranges
The rear tail lights stay on all the time
sounds like a bad headlamp switch. frist take off the clamp shell around the steering column and then disconnectt he head lamp switch and see if the light go out? then if they do smell the switch real close and see if it smeels burnt. if so that is youtr problem. get back to me.
Jul 02, 2011 | 2005 Nissan Altima
Car hesitates
check on ur a/tf fluid if its low top it up . if the level is okay then smell the atf if smeels like something burnt change ur gearbox . check level when engine is running .clean the stick and dip it several times to get the actual level
Jul 26, 2010 | 1998 Honda Civic
Burnt out rice cooker
hello mam
please follow these steps to fix it
1.check the power cord
2.check the power supply at the terminals of the cooker this can be done if you open the lower cover of the cooker.by using the multimeter or a testlamp.
3.by using the multimeter check the continuity of ON/OFF switch. by doing these tests you can find the fault and can rectify it.
Oct 08, 2009 | Rival RCS200 20-Cup Rice Cooker
Think belt is bad. Can't get front panel off
most maytags have belt on bottom (underneath) tilt back and check, drain pump pulley is in one corner, motor in other. pump has bearing that usually freezes up. take belt off and check rotation of pump. (motor is adjustable, pump fixed)
Apr 26, 2009 | Washing Machines
Neff cooker not heating up
Hi, it feels like your oven element has gone.
switch it off from the mains, open the door and remove the screws fixing the back panel. You will find a round two turn element. Unscrew the element fixings and check the element for burnt marks, corrosion. If you have a multi meter, turn it to buzzer and use the meter leads to test the element connections. If it doesn't buzz, it's dead. Just needs replacing.
Cheers
Feb 15, 2009 | Neff U1721 Double circotherm Electric Oven
Indesit gas cooker, odd smell
Indesit Cucina cooker
My tenant is complaining of burnt metal or burnt rubber smells when the oven is hot, it is perfectly clean and only two years old
Nov 26, 2008 | Indesit K344GX Gas Kitchen Range
Cooker keeps tripping the electricity supply.
If the main oven is electric, disconnect the heater element and try, if no trip operqates. then replace element.
Nov 22, 2007 | Belling CookCenter 151 Dual Fuel (Electric...
Oster 3071 Rice Cooker Logo
111 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Irene Tulloch
Marvin
Marvin
qtp2t4474
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
