Question about HP Jornada 525 Pocket PC
Display I'm the jornada 525 new user, I find that the resolution of it just 256 colors, Does anyone have any software can upgrade the colors to 65,536. because recently I'm using Compaq aero 2130, its color is 256 too, but Compaq sent me a software to upgrade to 65,536 colors,It's very beautiful for view photo and movie.I holp you can help me to solve this problem
    Master:
  • 450 Answers
Unfortunately, hp does not have similar software posted on the Jornada website: http://www.hp.com/cposupport/swindexes/hpjornada531628_swen.html that would change the 256 color display to any other option; sorry!
Posted on Sep 12, 2005
SOURCE:
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
I have problem with color setting
· open Control Panel and select Display menu and open it
· Then select Settings Tab from where you can change resolution and Color quality as 32 bit /64 bit
· ]Or you can click on Advance where you can set DPI
If you want to switch in 256 color
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don
May 22, 2011 | Computers & Internet
I need to know the monitor resolution & refresh rate on my HP Pavilion Pentium lll 8756C computer.
Video Attribute Properties Video graphics PCI local bus Controller Intel 810E (on motherboard) Video memory 11 MB shared memory, integrated graphics, not upgradable Feature connector (game/joystick) Yes Resolutions: 640 x 480: 16/256/32K/64K/16.7M colors
800 x 600: 16/256/32K/64K colors
1024 x 768: 16/256/32K/64K colors
1280 x 1024: 256 colors s.gif
Feb 17, 2010 | Computers & Internet
Unable to change color depth...
Ok I think i found your problem. You don't need to install any drivers.
Switch your display to 256 colors To switch your display to 256 colors
Some games and other software programs require that your monitor be set to 256 colors, or they run better in 256 colors. Many of those programs will switch your monitor to 256 colors automatically when you start the program. For those that don't, follow the steps below if you want to switch the display temporarily while the game or program is running.
  1. On your desktop or on the Start menu, right-click the game or other program that you want to run in 256 colors, and then click Properties.
  2. Click the Compatibility tab.
  3. Select the Run in 256 colors check box.
  • The screen will revert to your default color quality when you close the program.
  • Try switching to 256 colors if your software program shows the wrong color or the graphics redraw slowly.
  • If your software program appears in a small window in the center of your screen, you can increase its size by changing your screen resolution temporarily. Follow the procedure above, but in step 3 select the Run in 640x480 screen resolution check box. Your screen resolution will revert to its previous resolution when you close the program.
  • The Compatibility tab is available only for programs or games located on your computer's hard disk. It is not available if the program is stored on a floppy disk, compact disk, or a network.
Please rate this if it fix your issue
May 30, 2009 | eMachines W3611 PC Desktop
I need technical support
You need to try what it says try lowering the or color depth try 1024 X768 256 colors if that doesn't work try 800 X 640 256 colors Right Mouse click on the desktop where a Icon isn't go down to properties regular click go to settings change the screen resolution and color depth and color quality to above suggestions apply changes try your movie
Johnlgrn
Dec 27, 2007 | Computers & Internet
Can I update jornada 525 to poquet pc 2002 ?
Unfortunately, the Jornada 525 cannot be upgraded to Pocket PC 2002. The Pocket PC 2002 operating system requires a handheld with a StrongARM processor. The Jornada 525 has a Hitachi SH-3 processor.
Sep 12, 2005 | HP Jornada 525 Pocket PC
Jornada 525 has trouble start
this is a vary old product that nobody uses now. its like DoDo bird.
why use this device, there is no service support at all on it.
if compelled to use legacy devices,
ask at HP so they can all be shocked, posting for this.
here they are, REAL HP.
https://h30434.www3.hp.com/
we are NOT HP at all here,
Sep 20, 2017 | HP Jornada 525 Pocket PC
Syncro Jornada 525
You can buy a USB cable for your Jornada. HP and thrid party vendors sell them. I bought one that has a cigarette lighter adapter to charge the Jornada also.
Jornada 525 and Windows Media Player 9
Only a hint. Did you check the small print via the downloads for Pocket PC on the Microsoft web pages? If you download from the regular OS pages they don't mention that certain Pocket PC generations are not supported. I noticed this but only on Media Player downloads fom the pocket PC pages but it takes time to find this more detailed info. http://www.microsoft.com/windowsmobile/resources/downloads/pocketpc/defau lt.mspx
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
HP Jornada 525 Pocket PC Logo
85 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
