Question about HP Jornada 525 Pocket PC
Hard reset... Does anyone know how to hard reset the HP525 pocket PC?
    Master:
  • 450 Answers
While holding down the power button, press the reset button on the back. This will hard reset the 525 but you will loose everything in your ram.
Posted on Sep 12, 2005
SOURCE:
I have a touchpad pda that has a bad battery and i lost my password since its a long time since i used it it is a dell axim x50,how do i get the battery and charger since both burst due to an electric...
A "soft" reset clears all open programs and "reboots" the Pocket PC. When the Pocket PC powers back up, you'll start with all active programs closed and the device ready to use. This procedure is intended to reset the Pocket PC if it is malfunctioning or has become bogged down. This reset is also sometimes necessary after software is installed. A soft reset is the Pocket PC equivalent to restarting your Desktop or Laptop. The Dell Axim X50 and X50v can be soft reset by pressing the recessed button on the rear of the unit above the battery. A "hard" reset wipes the RAM and returns the Pocket PC to its factory specs. In effect, the Pocket PC will be just as it was when you purchased it. All data entered, preferences set or software installed (other than ROM updates) on the Pocket PC after purchase will be lost after a hard reset and will have to be transferred or reinstalled via ActiveSync. The Dell Axim X50 Series Pocket PCs can be hard reset by performing the following procedure: With the X50 turned on, press and hold the power button at the top of the unit. While holding the down power button, use the stylus tip to press the "Reset" button mentioned above. Allow the screen to fade to off. Release both buttons. The unit will power back on and display a menu to confirm the hard reset request. The Axim will be hard reset, just as it was when it left the factory hope this helps
May 06, 2011 | Computers & Internet
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
How to formate i-mate jame
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 1234 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos
Feb 17, 2010 | i-mate JAM Pocket PC
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
My Dell x51v Axim suddenly no longer communicates thru ActiveSync. Even though it is firmly connected with a USB cable, ActiveSync will no longer recognize it. I have uninstalled and reinstalled...
First try a "soft reset" - this clears all open programs and "reboots" the Pocket PC. When the Pocket PC powers back up, you'll start with all active programs closed and the device should be ready to use. This procedure is intended to reset the Pocket PC if it is malfunctioning or has become bogged down.
The X51v can be soft reset by pressing the recessed button on the rear of the unit above the battery.
Try to reconnect with your PC. If that fails - on the Axim - go to start - settings - connections - usb to pc and untick enable advanced network functionality - then see if you get a connect.
If you are still not getting a connection you will have to try a "hard" reset. However be aware that a "hard" reset wipes the RAM and returns the Pocket PC to its factory specs.
All data entered, preferences set or software installed (other than ROM updates) on the Pocket PC after purchase will be lost after a hard reset and will have to be transferred or reinstalled via ActiveSync / Windows Mobile Device Center.
The hard reset is performed through the following procedure;
With the unit turned on, press and hold the power button at the top of the unit. While holding the down power button, use the stylus tip to press the "Reset" button mentioned above. Allow the screen to fade to off. Release both buttons. The unit will power back on and display a menu to confirm the hard reset request.
Make sure you have downloaded and are using the newest version of microsoft activesync.
Try the reconnect and let me know how you get on.
Hope this helps. Please do rate my answer. Thanks.
Sep 04, 2009 | Dell Axim X51 Pocket PC
How to hard reset hx2490b
Recovery Procedure for HP iPAQ hx2750, hx2490, and hx2790 Pocket PC Series:
To perform a Hard Reset on the iPAQ Pocket PC by pressing and holding the Calendar and iTask buttons (1 and 4).
2. While holding down the Calendar and iTask buttons, use the stylus to lightly press and hold the Reset button, which is located at the bottom of the iPAQ Pocket PC, for approximately two seconds.
3.. Release all buttons.
4.. Connect AC power to the iPAQ Pocket PC. The handheld Powers On,
performs the normal boot sequence, and automatically restarts system.
Oct 30, 2008 | HP iPAQ HX2490 Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
Oct 16, 2008 | Computers & Internet
HP iPAQ hard reset
Scroll down on this page to find the ipaq 5000 series:
http://www.pocketpcaddict.com/forums/pocket-pc-tips/14964-how-hard-reset-your-pocket-pc.html
(H5450 and H5455 are the same ipaq)
Jul 25, 2008 | HP iPAQ H5455 Pocket PC
Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
HP Jornada 525 Pocket PC Logo
94 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
