Question about Vestax CDX-05 Turntable
Scratch works only on pause
Hi!
I can scratch only when pause button is pressed. When I press play again I can't scratch at all.
The problem is with the tiny button that tells the CDX that the platter is engaged. Take the face of the unit off by unscrewing the screws of on the circumference of the bottom of the unit, then locate the copper T shaped piece touching the spindle of the platter. Unscrew the little circuit board (this houses the on/off soft switch for the scratch mechanism) covering the bottom of the T and the T itself. Try powering the unit up and play a CD with the scratch mode activated. Push the grey soft switch to see if the music stops and move the platter back in forth to see if it scratches. If so, all you have to do is bend the copper T trigger to a position where it hits the soft switch just right; off when you don't have the platter pushed down, and on when you do. If the scratching doesn't work when you push the grey switch down, you have a problem I don't know how to fix. Hope this helps!
Posted on Jun 18, 2010
  • niceday2ride Jul 18, 2010
    This solved my problem, thank you. It's tricky and a bit of a pain in the ***, but it works.
I have the same problem ....i just got mine today very veyr dispointed ;(
Posted on Sep 20, 2008
My fisher n paykel draw dishwasher wont start it has three buttons a (on/off )(play/pause)(lock symbol) wat do i press to make it all start,
First press the ON/ OFF button to see if the display lights up. Once you select the program from the panel then press the PLay/ Pause button to start the cycle. Pressing the key button will prevent accidental pressing of the ON/ OFF or the Play./ pause button when the dishwasher is running. It is a child lock button. To turn it off (if you have selected it) press Keylock button again.
Dec 15, 2013 | Fisher and Paykel Dishwashers
Numark ndx400
1 of yor tak switchs are faulty either cue or play button or maybe even the scratch button replace all 3 that should solve
Aug 03, 2013 | Music
Operating manual for Plain Lazy Alarm Clock iPhone/iPod Speaker Dock
No instruction manuals for the 'Plain Lazy' ipod docking station/alarm clock found on line :-( So after tinkering with the buttons for quite a while, II have worked out how to set the clock. Press & hold the play/pause button & at the same time press the skip back button once....let go of both buttons. Then immediately press the play/pause button again once & the clock numbers will start flashing. Press the skip back button to adjust the hours & skip forward button to adjust the minutes. Press the play/pause button to set!
Aug 04, 2012 | Audio Players & Recorders
I purchased a Uniden model D1688 and I don't know how to put favorites into the phonebook.
Entries can be added from the base or the handset. The CID button is on the right of the control ring; the phonebook is on the left of that ring.
If you want to add a number from the Caller ID list to the phone book, press CID and use the up/down arrows to navigate to the call that you want to add. Then press Menu/Select. Select the line Store into Pb and press Menu/Select. You will be at the Edit Name Screen for the phonebook.
To enter a new item from scratch, press the Phonebook button. Then press Menu/Select and select the Create New submenu. Press Menu/Select and enter the name of the contact using the alphabet on the key pad. (For C, press 2 three times.) Press Menu/Select and enter the phone number as it is dialed (including a 1 if needed). If you need to add a pause in the number, press Redial/Pause. However, the entire number must be less than 20 digits (including the pause). Press Menu/Select again. If you enter the number from the handset, you will be prompted to select a ringtone to always use when you get a call from that number. Press Menu/Select again. Then press End (on the handset) or Play/Stop (on the base) to exit the menu system.
Uniden has the manuals available at their site, either from the product page or the support page. All DECT phone manuals are here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manuals are listed in numerical and alphabetical order. The direct link to the D1688 manual in English is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1688-2om.pdf .
I hope this helps.
Aug 30, 2011 | Cell Phones
ION Discover DJ mixer "Scratch/Search" switch
plug in the turntable first, then start the program.
if all lights are lit try again .
hope it helps
Dec 24, 2010 | ION Audio Discover Dj Turntable
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
Player gets paused by itself
simple problem.
remoove front panel and clean pause micro push button with cleening solvent.or you donot use this button remoove the button bu usind soldering iron.
the problem is with this the swich contact witout pressing the button because of dirt inside it
nuwan
Jan 09, 2009 | Electronics - Others
Denon Dns3000's One doesn't scratch or spin in scratch mode
i have these same decks, the contacts come loose from the cicuit board.... so you have to take it apart and solder them back into place.. did it once and never had problem again. i also retro fitted the platters with tiny tiny screws and its feels like a direct drive turntable! i'm looking for some old 3000's to buy... holla back if you want to sell yours or know anybody who want to sell thris!!! djleff@hotmail.com
Dec 27, 2008 | Denon Dns1000 Table Top CD Player CD...
How do I make a philips dvdr5570h region free.
Yes I phoned Philips and they told me to switch the recorder on, press home on the remote, press the play pause button and enter 519121212005255 then press play/pause button again.You have to do it all quickly or it will not work.
Nov 24, 2008 | Televison & Video
Axis 9
i have exactly the same problem, its annoying
1 thing which works is holding the button down then spinning the deck round, let go, turn off the scratch button, press play and turn on the scratch button again
Jan 15, 2008 | Nu Mark AXIS 9
Vestax CDX-05 Turntable Logo
269 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
