I can provide the radio wire colors and each function of the wires by color.
2001 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Infiniti QX56 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Purple
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Green/White
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: To the right of the steering column behind the BCM.
Left Front Speaker Positive Wire (+): Blue/White
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White/Black
Right Front Speaker Negative Wire (-): Blue/Black
Left Rear Speaker Positive Wire (+): Gray
Left Rear Speaker Negative Wire (-): Black/Yellow
Right Rear Speaker Positive Wire (+): Orange/Blue
Right Rear Speaker Negative Wire (-): Red/Blue
This is the wiring codes 2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink Car Radio Accessory Switched 12v+ Wire: Brown/Red Car Radio Ground Wire: Black/Dark Green Car Radio Illumination Wire: Orange/Dark Blue Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: Dark Green/Red Car Stereo Amplifier Location: Located behind the glove box. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Dark Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Violet Right Front Speaker Negative Wire (-): Dark Blue/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Light Blue Right Rear Speaker Positive Wire (+): Dark Blue/White Right Rear Speaker Negative Wire (-): Dark Blue/Orange
1993 Nissan Maxima Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red/Black
Radio Ignition Switched 12V+ Wire: Blue
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Yellow
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
pls rate because noone has been rating hope this helps
here are the factory wire colors and what they do.
1999 Ford Escort Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red Car Radio Accessory Switched 12v+ Wire: Blue/Black Car Radio Ground Wire: Black Car Radio Illumination Wire: Red/Black Car Stereo Dimmer Wire: Green Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: White/Orange Car Stereo Amplifier Location: Under the driver seat. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Violet Left Front Speaker Negative Wire (-): Blue/Orange Right Front Speaker Positive Wire (+): Blue/White Right Front Speaker Negative Wire (-): White Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): White/Blue Left Rear Speaker Negative Wire (-): Red/Blue Right Rear Speaker Positive Wire (+): White/Green Right Rear Speaker Negative Wire (-): Blue
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
1990 Mazda 626 Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red Car Radio Accessory Switched 12v+ Wire: Blue/White Car Radio Ground Wire: N/A Car Radio Illumination Wire: Red/Black Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 4′ Car Audio Front Speakers Location: Dash Left Front Speaker Positive Wire (+): Blue Left Front Speaker Negative Wire (-): Blue/White Right Front Speaker Positive Wire (+): Blue/Red Right Front Speaker Negative Wire (-): Blue/Yellow Car Audio Rear Speakers Size: 6 1/2′ Car Audio Rear Speakers Location: Side Shelves Left Rear Speaker Positive Wire (+): Blue/Red Left Rear Speaker Negative Wire (-): Blue/Green Right Rear Speaker Positive Wire (+): Blue/White Right Rear Speaker Negative Wire (-): Blue/Green
