Question about Palm m130 Handheld
Windows XP, Palm m130, & Outlook 2003 - Sync problem
I just switched to Windows XP and now my Palm to Outlook sync doesn't work -- I've been on the website and done all that is recommended, to no avail. When I hit Sync on my cradle -- my computer makes a "ding-ding" noise -- a much lower tone than the little jingle it plays during a successful sync. The sync attempt seems to continue, and after a few moments the computer dings again and the palm says "The connection between your handheld computer and the desktop could not be established. pelase check your setup and try again." Any ideas?
    Master:
  • 473 Answers
I posted this same problem 8/11. I am confused with reference to USB when we are using a serial connection. For me the problem happened with IE service Pack 2 XP update. All things were the same one day to the next, but I get this same message - unable to connect. My troubleshooting was to download the latest versions of desktop and OS for Palm, but I can't get the new OS to the palm without being able to hot sync. I would like to do a system restore to the date before the upgrade so I could at least sync the new OS to the palm. Corporate guides prevent me from doing that.
Posted on Sep 12, 2005
    Master:
  • 473 Answers
It sounds like the computer is noticing the USB activity (from when you hit the HotSync button) but for some reason it can't find the correct information/driver. I'd first try a soft reset (stick a paper clip or the end of your stylus may screw off to reveal a pin, in the hole at the back of your palm) Don't worry, it won't delete your info UNLESS YOU HOLD DOWN THE POWER BUTTON (SO DON'T). Once it's booted back up, try the hotsync again. If that doesn't work, you may need to find the usb driver for your palm and reinstall it. This could just be copying a file from disc, or reloading your Palm Software. Good luck
No driver for Z22 compatible with Windows 7
windows 7 is new and not compatible with many software so you may not get to sync your palm Z22 by using windows 7. You need a model that is compatible with windows 7.
Jul 05, 2010 | Palm Z22 Handheld
How to sync palm data with Itouch? I have all my contacts & calendar on my Palm Zire. How can I get the same data over to my I touch in a Windows XP environment ?
You can sync to Outlook on the PC and then get the Outlook data onto the iTouch. If you have a newer PDA, It's install CD has a Sync options menu item where you can switch between Palm Desktop and Outlook. If you no longer have the original install CD or have an older device Pocket, Copy from Chapura.com It will move the Palm Desktop records to Outlook.
Mar 08, 2010 | Palm Zire 31 Handheld
Tx will no longer sync with outlook 2003 or outlook 2007 calendars. Software reinstalled, tx reset, latest updates for syncing with outlook 03 and outlook 07 loaded, still won't sync to outlook calendar...
I would recommend contact the palm free chat. Here is a link for that. I have a TX and have used the chat feature myself and always with good results. Scroll to the bottom of the page and then you will see Palm chat. From there click on chat now and follow the directions. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/supportservices/page_en.html
Nov 18, 2009 | Palm TX Handheld
Can't sync Toshiba Pocket OC e335 with Outlook 2000 in Vista
I installed outlook 2003 instead of outlook 2000 that came with the pocket pc
Mar 25, 2009 | Toshiba e335 Pocket PC
Palm M515 and compatibility with Vista Home Premium
I was having a similar problem with my M515.  I had originally installed the Palm Desktop from my CD, which was an older version.  When I totally uninstalled the old version and installed the newer version from the Palm website I was able to do a successful sync.  I'm using Windows Vista Ultimate and Palm Desktop version 4.1.4
Oct 24, 2007 | Palm m515 Handheld
How can I hotsync both ways?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 11, 2005 | Palm Zire 31 Handheld
Tungsten E and Outlook 2003 sync problem
yes I moved my files to a new machine and reinstalled palm (which of course also created the dreaded multiple copies of many palm contacts, when palm discovered older archives, but that is another story!) I wouldn't mind that if the palm pilot would just sync with outlook 2003. It synched with Outlook 2000 on my old machine.
Sep 11, 2005 | Palm Tungsten E Handheld
How do I get outlook & my palm to sync?
Hi, if u want to sync with outlook , u would either have to buy the installiation disc from palm online store or call up tech support , it will cost u, or if you want u call also chapura and buy the outlook conduits from them , u dont get the outlook conduits on the website . In the installiation disc u get the outlook conduits . Regards
Syncing with Outlook 2003 problems
Download the Outlook Security Add-in from this site: http://www.mapilab.com/outlook/security Advanced Security for Outlook is free for commercial and non-commercial use. I have testet it with Windows XP and Outlook 2002 SP3 syncing with a Palm Zire 31 and it works fine.
Sep 11, 2005 | Palm m505 Handheld
Outlook on IBM T42
You never mentioned your drivers, they could be out of whack. Try updating them or get a Microsoft compatible driver. Check the device manager for problems.
Open Questions:
Palm m130 Handheld Logo
158 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
