Question about HP Jornada 520
Using USB to sync Jornada 520
I have a Jornada 520 which uses a serial connection, but my new laptop does not have a serial port. Is there a serial > USB adapter or cable I can use to sync my 520 with the USB port? Thanks.
adib
  • 450 Answers
SOURCE: USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Posted on Sep 12, 2005
0 characters
1 Points
I have a hp jornada 520 but have lost the serial cable forpc where do i purchase it
The HP Jornada 520 Series Pocket PC has been discontinued, and some of the accessories may be difficult to locate. They may be available in one of the following ways:
The Part No. for your Serial Cable = F1819A
Hp Internal Crew No. for your Cable = F1798-80014
Regards,Waqar.
Aug 16, 2009 | HP Jornada 520
Hp jornada 720 handheld pc
Try a older version of active sync. 3.0 or 3.1
heres 3.1
http://www.tucows.com/preview/32548
Feb 17, 2008 | HP Jornada 720 Pocket PC
Jornada 520 e.book error
Try this link that describes the error you are seeing... http://support.microsoft.com/default.aspx?scid=kb;EN-US;q271300&GSSNB=1
Sep 14, 2005 | HP Jornada 520
Will Dell Axim sync with Outlook 2000 on Windows 95?
It should if you have USB on the W95 machine. ActiveSync is compatable with W95. It worked for me with Outlook 98 on a Win95 laptop synching to a PC2000 PDA (Jornada), however I was using a serial cable.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Serial port
there used to be serial-to-USB converters available... Perhaps you can get one of those. Then you could try top setup your IrDA device (InfraRed, if you have one) for your ActiveSync Connecttion.
Sep 12, 2005 | HP Jornada 525 Pocket PC
Jornada 547 rebooting W2000 E-PC
there is a patch/hotfix out from MS for this: 252795 wich cures that problem and adds the IrCOMM protocol to your Windows2000 (it was missing there before).
Sep 12, 2005 | HP Jornada 547
Jornada 568 Sync Problems
All you have to do: Select Device Manager, select "Universal Serial Bus controlled". Re-install the USB driver from Active-Sync CD. That's it.
Sep 12, 2005 | HP Jornada 568 Pocket PC
Jornada 680 won't sync over network
Hi. Put your desktop ip-address into your network card wins-address field (on your Jornada) Works for me :)
Sep 12, 2005 | HP Jornada 680 Pocket PC
Syncro Jornada 525
You can buy a USB cable for your Jornada. HP and thrid party vendors sell them. I bought one that has a cigarette lighter adapter to charge the Jornada also.
Sep 12, 2005 | HP Jornada 520
HP Jornada 520 Logo
60 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
ka4iup
ka4iup
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
