I have a numark idj2, i can get music media off itunes the media records to my itunes libriary and ipods but will not go into the numark idj2, some of the media appears on the numark libriary but when you go to play it never gets off pause and if you keep pursueing the song the machine goes into error and shuts off, yet the tune plays off itunes and off ipod.
    Master:
  • 763 Answers
Try to look on the settings maybe on a manual of it. it has to be a configuration for this.
cheers
CHARCOIS
Posted on Sep 01, 2008
  • Charris Suaybaguio
    Charris Suaybaguio Sep 01, 2008
    try this link it might helpful
    http://www.numark.com/idj2
    cheers
    CHARCOIS
    see the documents and downloads from above link. you will find some manual, overview, tutorial, etc.. you should have pdf reader for this before you see what contains of each docs.
    President:
  • 1,263 Answers
Are the files that you have compatable with your new device. sometimes certain devices can't read the format of the file. not all mMpeg or Jpeg files are compatible with different devices do you have a usb cchord that came with your device and a cd to install the driver in the computer?.... my suggestion is to down load all files from the ipod to your computer. install the driver and the computer will be able to sync your files and their format to your new device...please rate this good luck
I have an ipod touch 2nd gen and it wont recoginize anything when docked with my IDJ2? Confused??? I put a flash drive in a USB port they all come right up!!
connect the ipod to PC..... first make sure you have the latest Itunes (http://www.apple.com/itunes/download/) 10.2.2 now plug ipod to PC..... Itunes should pop up automatic... now check to see if your ipod has the latest firmware for its generation (ipod touch 2gen) if not update it, this should also help the docking problems...now (always always eject your ipod, do not ever ever just unplug the ipod)
have fun feel free to comment on the help
May 15, 2011 | Numark iDJ2 - DJ iPOD Mixer Docking...
How to use the profile view on idj2?
all i did was go to the numark librarian and used the advanced option
Oct 21, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Video won't work using the s-video connector.
Which iPod model are you using? Not all iPod models support video with the iDJ2. Check the iPod compatibility matrix document at www.numark.com/idj2 to see if your model is supported.
Sep 13, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
My ipod touch does not work if i plug it into the dock or even the USB ports... WHY??
If it is a 2nd Generation iPod Touch it is not supported for use with the idj2. Look at http://www.numark.com/idj2 and review the iPod Compatibility Matrix for further info.
Aug 12, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
I just got an idj2. I downloaded the firmware. I went through the library process, though I'm not sure what that really did other than take a ton of time. I hooked my ipod touch (16 gig) to the idj2 and it...
Dan... I hate to be the bearer of bad news...
Located at http://www.numark.com/idj2 there is a link called iPod compatibility matrix v1.6 this link tells you which versions of the iPod work great with the idj2 and which versions of the iPod make you want to pick up your idj2 and smash it against a brick wall. Sadly, the iPod Touch falls into the "smash" catagory.
Generation 1 iPod Touch devices can only be used in "DIRECT MODE ONLY" which means you can use them like a cd player or as a music source on 1 channel of the mixer of the idj2.
Both Generation 1 and Generation 2 iPod Touch devices are not supported to be used with the idj2 in "MASS STORAGE MODE".
Jun 10, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Can't get the ipod touch to play on the docking station
I had the same problem. Look at the documentation site of Numark
Ipod touch isn't supported for mixing (1st gen is supported for Direct play)
Source:
http://www.numark.com/stuff/contentmgr/files/2/dd1ffd47d0ee2aec5d8ef3afa92e0992/file/ipod_compatibility_numark_v1.6.pdf
May 16, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Tracks playing at the wrong pitch and speed
This sounds like a difference in the sampling frequency.  Music recorded at 48Khz must be played back at that frequency or there will be a significant difference in speed and pitch during playback at 44.1Khz. I first noticed this when it occurred to me when recording on digital audio tape.  Ipods and minidiscs and mp3 recorders can record at high sampling frequencies like 48K.  Cds are all recorded at the standard 44.1K sampling frequency.   Check the source of your recordings and it should follow a pattern that leads to your current results.       I do not have enough information  on how your music was transferred to tell you more at this time, but I am very confident that differences in sampling frequencies of your source material are causing the pitch differences you are hearing.   Without knowing exactly the sampling frequencies of each piece of equipment you used to record these songs it will be next to impossible to give you a very specific solution, so I hope the info. I have shared helps you to figure it out.  Best regards and good luck!   Michael Mittelsdorf
Jan 12, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Numark idj2
ok try this do you have a master rest of the idjr? if you do use it and see if this will re initialize the device.
Sep 01, 2008 | Audio Players & Recorders
43 people viewed this question
 Grubhead
Grubhead
