Question about Zebra QL420 Thermal Printer
Issue while printing with QL420 Mobile printer.
QL420 printer takes jobs coreectly, but while printing it skips or jumps randomly from the jobs and prints less number of jobs rather than specified number.
please give replay back asap--its very urgent.
SOURCE: Printer won't print
Printer doesn't print, just feeds the label.
Check your Labels and Ribbon, ensure you have the right ones.
If you have the right ones, here's what you try.
Hit the "setup/exit" button once. Then hit the "+" button repeatedly until you get to Print Meth. It will say Thermal Transfer. That setting can be changed by hitting the select button and the + button. Change it to Direct Thermal Transfer. Then use the setup/exit button to Temporary save the changes. You can change it back to Thermal Transfer doing the same method.
You will get an error, because the ribbon is in. But you can see it it prints.
Try going to the manufacturer website and read the manual about the printer.
If the printer feeds ribbon and doesn't print, more then likely it's a print head problem. When I mean it doesn't print, I mean from the printer control panel without the computer connected.
If you cannot figure out how to print the internal print fonts or setup from the Zebra 4m+ printer, you again need to go to the manufacturers website and read the manual.
Did a little research, appears that I can get a rebuilt print head for about $400. Instructions to install should be with the print head, if not reverse engineering.
Posted on May 12, 2008
PABLOCSA
  • 1124 Answers
SOURCE: LP2844 printer only prints after reboot
Probably you have some conflict on your printer ports. Go to your installed printer (Printer folder) and select one of them, >> righ click >> go to properties >> Ports
and see which port is taking the first printer, which is taking the second one and which the third one. It is problably than 2 of them are using the same port. (Virtual USB)
Posted on Oct 03, 2008
  • 17 Answers
SOURCE: Configuration settings do not save in 'Permanent' mode
Q1# do you have printer driver? what kind of driver ur using? is your driver from www.zebra.com? Q2#what software u are using to print? Q3#ask the programmer of the software if there is a command that control the settings of the printer Q4# is the software DOS or windows program
Posted on Mar 20, 2009
SOURCE: Printer issue in printing
Hold the button down for a set of four flashes.
http://zebra.com/id/zebra/na/en/documentlibrary/manuals/en/printer_manuals/lp2844z_users_guide__en.DownloadFile.File.tmp/980410-001B_2844-Z_UG_en.pdf
Posted on Apr 29, 2009
  • 185 Answers
SOURCE: I am having problems with Zebra printer MDL#ZM400
Try entering the Menu system and exiting, whilst exiting and instead of saving permanent, cycle around to load defaults. once you have done that make sure the settings are as you need such as Thermal Transfer etc and save permanent. You won't have a problem after that. If you do I would be checking the page setup in the software to make sure it fits the lables.
Posted on Jan 25, 2010
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
Print, particularly black, is inconsistent. Keep
Follow www.kodak.com/go/itg and try the step by step solution.If issue persists,Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Dec 24, 2009 | Kodak ESP 5 Printer
After Print job the printer skips and goes to next tearoff
check you manual, set the printer back to default. or it might be with the program your trying to print with. try print a test page using your driver. if it still the same. uninstall and reinstall it back to your computer to restore it to its default value
Oct 05, 2009 | Matrix Okidata Microline 320 Printer
Canon Pixma ip1500 is printing but very wierdly. random lines will not show up in black. If i change the color everything is fine but black will skip lines and such. Please help! Can't turn in job...
Your printhead is plugged and needs cleaning. If you remove the inks and then the printhead, you can wet and fold a paper towel and just dab the printhead gently on the wet towel. When you see a solid black line on the paper towel your printing should be improved.
Jun 23, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Printronix P5210 line printer HOF problem
If you are using a printer that has IGP enabled, you can set the printer to automatically go to the next TOF at the end of the print job. Only if you are using the Graphics portion (printing bar codes and graphics). The option is "Auto FF at ^PN" and you would Enable it.
Dec 29, 2008 | Printronix Line Matrix P5210 Printer
ZQL420+ is printeing an extra blank label with each good label.
Check if you have " send Form Feed after each file" is enabled (or yes) in your print queue
Nov 20, 2008 | Zebra QL420 Thermal Printer
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
HP Photosmart 3310 All-in-one printer, printing issues
This is a software error in your computer, you would need to uninstall the drivers and software and reinstall to repair it.
Feb 26, 2008 | Office Equipment & Supplies
Zebra QL420  Thermal Printer Logo
97 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
