Question about HP Jornada 568 Pocket PC
Can't synch, only connects as guest
Everything was okay until my laptop (WinME) crashed and went out for repairs and came home reformatted. I've reloaded ActiveSynch 3.5 for P/PC 2002 and during the setup opted to synch with two pc's. That may be the problem but now I can't connect and synch. It reads a connection but is unable to synch. At the "connection tab" on the jornada it tells me I need to reset the configuration or something like that. The Help files are no help. I want to go back to the original settings but I can't not even deleting ActiveSynch and reinstalling. I can't transfer files or load anything into the jornada. Any thoughts? Please? Thank you.
    Master:
  • 450 Answers
I have had this happen to me at work. You need to backup your Jornada on the computer that works to sync (VERY IMPORTANT) and then hard reset the Jornada (which wipes it clean). Make sure that you put the name back into the Jornada identification (it will be wiped out by the hard reset). Then try to synch on the computer that can't synch except as Guest now. It should sync fine. Then you will need to sync on the computer that works to sync to restore the backup file. Then you will be back to normal. It is a pain. I don't know why it happens but I know this solution worked for me. Let us know if it works for you.
Posted on Sep 12, 2005
SOURCE:
Cannot connect to anything other than guest on router
Reset to factory default.Here is how ->http://www.fixya.com/support/r11153882-general_routers_reseting
Jun 30, 2013 | Belkin Computers & Internet
I have a Gateway NE71B laptop that no longer connects to the Internet.
Suggest contact guy. tell guy you are taking laptop to repair shop.
Tell guy he is paying for fixing it.
End of story
No? A small lawsuit should change his mind.
Regards,
joecoolvette
[We are LIABLE for everything we do, and everywhere we go ]
Mar 15, 2013 | Computers & Internet
Dell 1558-2182 boots about 1-3 hours. It hangs on screen "Welcome" for 1-3 hours. Safe mode runs ok When I try to log on guest account laptop reboots When I run PSA (Pres-boot System...
before changing disk, you can try reformat and re install.
The disk may be okay and you are having windows problem especially
because safe mode works okay.
Aug 03, 2011 | Computers & Internet
I have an acer laptop. From XP operating system, I upgraded my laptop to Windows 7 just a couple of weeks ago. At the start, everything went fine and normal. But 2 days ago, when I turned on my laptop, i...
if you upgraded it through an internet connection there's a possibility your windows OS will crash, better or try to reformat it with a windows installer dvd.
Jul 08, 2011 | Computers & Internet
My laptop always crash and the only way to recover it is to re format it.i already do almost everything like change the hardrive.memory.it willrun for a few days and then crash again.we thought at first...
Hello.
This is a tough one.
My first thought is that if you reformat your laptop and it crashes, sounds like a hardware (most common: memory or hard drive) problem.
But, you've tested / replaced the memory and the hard drive. Be certain that you have the correct memory for this laptop. Also, run hardware diagnostics.
When you reformat, don't add anything. Just the operating system. Boot it and test for awhile to see if the operating system is stable. Then, add software one at a time and test each time. It may be a long process, but it's possible that your software may be infecting your system.
Hope this helps.
Jul 11, 2010 | Computers & Internet
Can't sync to the mp3
Okay, 57dlt, here's what to do:
Make sure all of your songs, images and other media are on your PC. If not, you will lose them, and will have to obtain them again.
Go to settings->format, them press play, and leave your mp3 player alone for a few minutes. when it's done, the mp3 player will be wiped clean of everything. Once it's been wiped, go get the newest windows media player, then put all of the songs and images you want into the synch list, and let it synch until finished.
you will have all of the files you want on it, with no extra space being used up.
Guest: connect your mp3 player to the pc, then open it in my computer. go to the photos folder, and delete whichever ones you plan on getting rid of.
Feb 10, 2009 | Memorex MMP8595 MP3 Player
Hp Pavillion restore problems
It Could be a bad stick of RAM I have seen a bad stick cause all kinds of problems.
Try booting with another stick of ram and see what happens.
Good Luck
wwiz
Oct 26, 2008 | Computers & Internet
Data seems to be lost and it crashes
have u tried turning it on in emergency connection mode ( press the reset buton connect it to the pc then hold the power buton while holding the o enter button) u can reformat it then. after you reformat it u will have to reinstall the firmware (u can get this from iriver.com). it should work after this:P
Aug 08, 2006 | iRiver H10 MP3 Player
Help with Avantgo
You don't really need for it to. You can go to setting on your Axim, then to connections, and use the avant go connection, to connect, and synch with avant go that way. You can synch to avant go that way, with any internet connection. If it's connected to active synch as a guest then you can't synch with active synch also.
Sep 14, 2005 | Dell Axim X5 Pocket PC
HP Jornada 568 Pocket PC Logo
75 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
